Question about Motorola Computers & Internet
Need XP driver
Have aquired a Symbol LS3070-i100US unit and need some software/driver.
Thanks for any help/directions.
  • 47 Answers
You don't need an XP driver...the system uses either a USB connection, Keyboard Wedge connection or Serial connection. There are some other versions available. The 3070 memory scanner is an older version, but, doesn't use "drivers" as such. The best thing to do is contact the Symbol/Motorola Help Desk at 1-800-653-5350.
Cheers.
Billy Barcode
Posted on Aug 04, 2009
I Have a new symbol scanner LS1902T-1000, whose software/Driver got missing, when i tried to read the bar codes, the unit beeps and a green light come on but I do not see any thing in the screen Please...
Hello Sabrina,
it depends much on the connection between the scanner and computer. The good sign is that the scanner is set correctly to scan the barcode. You need also scan the correct barcode for the connection art. Please scan from the Product Reference Guide the Barcode for USB, RS232 or Keyboard Wedge.
The Product Reference Guide is located at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880807apdf
Oct 22, 2010 | Symbol Cobra LS1902 Handheld
Gps will not aquire
It needs a software update.
Jul 01, 2010 | Northstar 952 GPS Receiver
LS3070 (ls3070-i000a) Handheld: My scanner stopped scanning. It beeps four times. ...
The four times beep means that there is an problem in the connection to the PC, please check the cables and configuration.
May 18, 2010 | Symbol LS3070 (ls3070-i000a) Handheld
MC 7090 MODEL OF SYMBOL: ACCESS MENU OR REINSTALL WINDOWS
I have had the some problem with this unit,but you can to solve your problem with reinstalling an OS ,go the motorola software, find OS and copy it on an sd card put it on your divise,and launch it.
Feb 01, 2010 | Symbol MC70
I have a Symbol LS3070 that has stopped sending a return after UPC-A scans. I added a suffix of 7013, and got no change. Any Ideas?
Scanning Scan Options, Data Suffix, Enter from Adobe pages 141 and 142 of 214 the LS3070 Product Reference Guide resolves this issue. The suffix is already set to 7013 so scanning the barcodes above should be all you should have to do to send the return or enter key after every barcode scanned..
Nov 16, 2009 | Symbol (LS3070-I100US) Handheld
I have aquired goldstargmk midi keyboard and hooked up usb
  • Some times the accessories (the keyboard) for the computer kan bee used as "standalone" you just insert the wire provided.
  • Other times you need a "driver" for the accessories can work. when you have that maybe you need a software for the accessories kan play
I found this site where you can find manuals to your keyboard :
http://www.user-service-manuals.com/goldstar-service-manuals.htm
I found this site where you can find a standart "how to do":
http://www.musiconmypc.co.uk/art_keyboard_connection.php
Good luck
Aug 25, 2009 | Computers & Internet
Im looking for a printer caBLE FOR A HP PRINTER MODEL NUMBER PSC500 AND OPERATING DISC
You need a bi-directional, parallel, IEEE 1284-compliant printer cable with
1284-C connector. Here is an example from Tiger Direct:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=331719&CatId=76
You can download the software from Hp. Go here:
PSC500 Support
Select Software & Driver Downloads. On the next page select your opeating system.
Follow the directions. There is not a software download fro all OS. For instance, for XP you will use the XP OS to install drivers.
There are also links to manuals on the suppert page above.
Thanks for using Fixya.
Jul 06, 2009 | Computers & Internet
Widows XP
(1) go to Hp.com - load load the necessary Xp drivers for your unit - burn them to cd - then aquire a replacement hdd - install Xp on that - install the required drivers and walla you have one hdd with vista and another with XP
Jan 21, 2009 | HP Compaq 6720s PC Notebook
Scanner symbol ls3070-i100US
These are the only drivers i could find that fit your description. Hope it helps.
Simple COM Port Emulation USB driver version 1.8.5
1.8.5 DRIVER Simple COM Port Emulation is one of the USB (Universal Serial Bus) interface modes supported by Symbol scanner devices. In this mode, a Symbol scanner...
123Scan Scanner Configuration Utility v2.7
2.7 UTILITY SOFTWARE 123Scan is an easy-to-use PC based application that will help you program your Symbol Technologies bar code scanning products. Allows easy scanner...
OPOS Driver for Symbol Scanners v3.24
3.24 DRIVER The OPOS Driver for Symbol Scanners v3.24 provides the tools necessary for scanning bar codes. OPOS (OLE for Retail Point-Of-Sale) is a standard programming...
JavaPOS Driver for Symbol Scanners v1.9.1
1.9.1 DRIVER  This driver provides the Java objects necessary to connect a Symbol barcode scanner to a host system based on the Java POS specification (a part of the NRF...
Oct 06, 2008 | Computers & Internet
Symbol ls3070
You can download the manual here :
http://www.gsv-service.com/download/ls3070.pdf
You're welcome, but don't just sit there clapping, throw money at me :)
Jan 21, 2008 | Symbol (LS3070-I100US) Handheld
Computers & Internet Logo
466 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
