Question about Lexmark OfficeCenter X3350 All-in-One Printer
How do I to change the cartridges on my lexmark printer?
I know you have to lift up the top but when I do I don't see the cartridges
  • 628 Answers
Normally when you lift the cover, the cartridges will shift to the middle or someplace where you can replace them easily. If your printer isn't doing that, then there must be some internal problem. When you lift the cover, is there any indication on your computer or printer? If not, then the cover switch may be bad. Another thing you might check is the printer software on the pc. Is there provision to place the printer in change cartridge mode?
Posted on Apr 22, 2009
I have a Lexmark Z2390 inkjet printer and have just purchased new ink cartridges but do not know how to change them can you help ?
hello,here is how to replace or change ink cartridges: 1. make sure the printer is turned on. 2.lift the top cover or access door. sayurisan20_19.jpg
3.press down on the cartridge level to raise cartridge lid. sayurisan20_20.jpg
5.for new inks,remove the tape from the back and bottom of cartridge before you install it.DO NOT REMOVE NOR TOUCH THE COPPER CONTACTS OR NOZZLES ON THE CARTRIDGE. sayurisan20_23.jpg
6.insert black cartridge in the left slot and the color in the right. 7.close the lid and make sure it is closed properly. sayurisan20_24.jpg sayurisan20_25.jpg
you can align them to improve print quality by clicking on start,all programs or programs and then click on the lexmark folder,click maintenance,align cartridges,then print.
Jun 09, 2011 | Lexmark Office Equipment & Supplies
Where is the printer cartridge on the lexmark 5650
hi first do not switch off the machine simply lift up the top half of the machine from the front there will be a marking and usually oval shape where your hand should fit lift up the ink cartridge will then move to the centre lift the grey latch and remove the cartridge you need to replace take the new cartridge and remove the seal and fit in position relock the latch and close the the top half of the machine it should recognise the new cartridge remember lexmark do not work with refilled cartriges and that the replacement instructions comes with the new catridge as well as in the printer driver tools under maintenance you will find it under printers on your pc good luck
Nov 23, 2010 | Lexmark X2500 All-In-One Printer
I dont know how to change the ink cartridge on my lexmark 5500-6600 series
just near the control panel lift the top portion of the printer which is the flat bed scanner assembly and that should give you access to the ink station
Aug 05, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    I cant find the ink cartrage on this printer to replace help
    I don't have your model Lexmark, but on my X4530 you have to lift the top scanning bed up, then the cartridges will settle to the middle for changing. Make sure you have the power on when you lift it, and you should see the cartridges in the middle of the printer. Good luck, hope this helps.
    Jun 05, 2010 | Lexmark X7170 All-In-One InkJet Printer
    How to get to cartridge to change it I can't figure how to lift top to get cartridge
    Perhaps this User Guide(for Lexmark X2450, X2470 and X2480) link to the Lexmark website will help. Just clink on this link: http://www.lexmark.com/publications/pdfs/2007/2400/ug_en.pdf. Scroll to Maintaining the Printer, Page 42, for changing/installing cartridges. In some cases, even when the printer is on and you lifted the scanner unit cover, somehow the cartridge carrier won't go to the center for loading position. Just unplug the printer from the power source. With the scanner unit open, hold the solid white strip in the middle inside the printer. Other end of it is connected to the cartridge carrier. Slowly drag the carrier to the center for loading position. Change the cartridges. Close the cover. Plug printer back to power source. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
    May 05, 2010 | Lexmark X2470 All-In-One InkJet Printer
    Hi need to know how to open my printer and get to where i need to put the new cartridges in it i have a lexmark x1185 please help me
    The entire top of your printer lifts up. (Scanner unit.)
    Refer to this setup guide:
    Lexmark X1100 Series Setup Guide
    See steps 6 through 9.
    Once the lid is lifted, there are locking tabs on each cartridge. Squeeze and lift up. You can then lift up and out on the cartridges. Reverse the procedure to install the new cartridges.
    NOTE: Make sure the printer is ON during cartridge removal and replacement.
    Thanks for using Fixya.
    Nov 05, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
    How do i change the black ink cartridge on a lexmark x2580 printer
    With printer on and connected to computer do the following:
    Open top cover.
    Fix top cover on open position, using the plastic sustain part located on the right side inside the printer.
    Wait for ink carriage for taking position in the middle of the printer rail.
    Open cartridge top cover.
    Pull cartridge toward yourself and snap it out.
    Do the same in reverse order to fit new cartridge.
    Remember to remove cello tape strip from new cartridge nozzle.
    Do alignment procedure after replacement.
    Sep 11, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
    Where are print cartridges located in the Lexmark 1200 series so that I can change cartridge? Got printer at a sale and don't have manual.
    I have a Lexmark X1270 and this is probably the same as yours.Lift the top (not scanner lid!) and with power on the cartridge containers will locate centrally for you to access,once located these coloured containers have a hinged lid,pull the lid upward to remove cartridges contained within.Hope this helps.
    May 11, 2009 | Lexmark X1270 All-In-One InkJet Printer
    Install Ink Cartridge
    Swith on the printer. Open the printer top cover. It is called flap. Now press upwards the cartridge's top end. and lift up that. now take the cartridge out. insert the new cartridge the same way took the cartridge out. put the cartridge layer down. Now close top cover.
    Oct 24, 2007 | Lexmark X1240 All-In-One InkJet Printer
    Lexmark OfficeCenter X3350 All-in-One Printer Logo
    Top Lexmark Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
