Question about Canon PIXMA iP90 InkJet Printer
Paper Jam Error
Hello...I was trying to print some papers on my canon pixma ip90 and it continously reads paper jammed....( It wont print or feed the paper through) Is there anything I can do to fix it before I take it to a shop? Any help would be greatly appreciated! Thanks!
  • 5 more comments
  • Mrs Rosado Sep 24, 2007
    When the printer is first turned on its fine as far as the green light. then once i try and print it starts blinking green then orange and so fourth. Any suggestions?? Thanks!
  • ltgarcia Dec 18, 2007
    mine will feed about 1/4 inch, or 5 mm, and then will stop feeding paper.  the printer head will happily continue printing away spraying printer ink into the foam pad in the bottom of the printer.
    the IP90 does not have a waste tank, so that is not the issue.  I cannot locate any dirt or paper in the feed.
  • Anonymous Dec 28, 2007
    Same problem. Just bought it not long ago.
  • Anonymous Jun 12, 2008
    cannon ip90v
    green light flashing then orange after paper jammed cannot clear fault
  • aarexy Jul 17, 2008
    switch it on and off a few times, but still have the same prblom
  • mattfisher Apr 02, 2009
    I've tried the cancel/feed blink 3 times clean process MANY times, I've carefully taken the top half of the cover off the printer, nothing out of the ordinary. No paper or paper fragments.
    Where is this "sensor" located so I can give it an alcohol swab.
    I've also heard that there is an internal "bar" that could be bent. (To be honest, this computer has gone through airports nationwide, I don't doubt that this problem began with improper bag handling)
    Where can i find a manual or directions on taking apart my printer and doing diagnostic tests on it.
    I seriously wouldnt be taking this "printer battle" to such extent, but these are commercial printers. I have 5/13 that have this problem. It's beginning to occur to me how cheap these printers are. I don't want to just throw them away yet.
    Any suggestions?
  • Michael Furlong
    Michael Furlong Nov 07, 2013
    Same problem here. Bought the Canon Pixima ip90 on ebay after experiencing same unfixable problem with another one I owned. Final verdict...a previous paper jam resulted in cracking the plastic gear that's driven by the main metal gear. Not worth fixing.
    Problem Solver:
  • 10 Answers
Exactly as blan5640 said here there may be piece of paper or dust on the sensor try ro clean the sensor and reply whether you have pulled the jammed paper towards up/down of the feeder if you pulled it upward then the sensor would have broken
Posted on Sep 23, 2007
    Problem Solver:
  • 18 Answers
Check the paper feed section of the printer. it may be item stuck in the paper path. causing the paper jam senor to stay on. also it know for these printer to have a waste in full. this will stop all workings of the printer. as these printer only have small waste ink pad in them. Need to know if the printer is flashing just green or if it flashing green led then a orange one.
  • Brett Lancaster Sep 24, 2007
    if u had a paper feed error it would blink green. looks like u have a service error on the printer.
Please help with cannon PIXMA MP150 printer problem, when trying to print, It reads that paper is jammed but I've checked several times and no paper is jammed. Printer will not print due to this...
Hello and Welcome to FixYa!
Paper jam means their may be small bit paper jam in side
, actually there are some "micro sensors" that detect a paper jam. There will be tiny piece of paper inside those sensors, thus tripping the sensor and paper jammed keeps coming up.
To solve this first of all Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
, If you become sure that now really there is no paper, dust or foreign objects then Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any Canon Printers service provider.
I hope this solution helps you
Thank you for using FixYa!
Aug 04, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Paper will not start feed in on it own
Probably no paper jam, but put a ruler across the top across where the switches are, if it's bowed down some the frame has been bent. Any weight, luggage,etc placed on top can bend the frame and that restricts the paper path and you need a shop repair.
Jan 08, 2010 | Canon PIXMA iP90 Mobile Printer
Paper jam in Canon PIXMA iP90
one of your feed gears has poped out of placeor one of the teeth is broken,check the paper path with a flashlight you will probably see one loose.
Good luck
Aug 28, 2009 | Canon PIXMA iP90 InkJet Printer
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Printer jam
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-10
Jul 21, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon ip4300 Error code 1300
u have to reset ur printer try to hold ur finger on power button for more than 15 sec then turn it on again
Jun 09, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Paper won't feed
your receiving a jam because the printers are based on timing so if that paper doesnt follow its path it will cause an error what you might need to replace the pick up rollers
Feb 12, 2009 | Canon PIXMA MX310 All-In-One Printer
Printer keeps on jamming paper
Dear all,
I will try to help you. Paper jam error may be caused by some possibilities. So, please notice this indication:
  • If the printer status is READY immediately after Power ON then Paper Jam Error message appears while feeding the paper: Sheet Feeder Unit is faulty or any other material (such as broken paper) present inside paper path blocking paper end to reach paper feed sensor.
  • If Paper Jam Error messages appears immediately after Power ON: Paper feed sensor or logic board is faulty
Corrective action:
  • Remove the material from paper path
  • Replace Sheet Feeder Unit
  • Replace Paper Feed Sensor / Logic Board
Please rate me as Fixya if you find this useful for you. Thanks.
Source:
Canon Inkjet Printer Forum
Re
Sep 01, 2008 | Canon Pixma iP2600 Photo InkJet Printer
Canon pixma mp460
check for obstruction and paper thickness lever on the printer and try printing again.
Apr 14, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Canon PIXMA iP90 InkJet Printer Logo
272 people viewed this question
old marine
old marine
