Question about Garden
Replace con rod
How can I get the con rod off the crankshaft on my victor lawn edger thanks Stacy
2 Suggested Answers
jdlipscomb41
  • 157 Answers
SOURCE: Victor carby diagram
try looking on ebay.com they have alot of manuals on there
Posted on Oct 28, 2009
My 2007 1600 focus Hwda engine has a broken con rod. Is it repairable? If not, can I replace it with an SWDA one? Thanks.
The connecting rod can be replaced but as a set with a new piston and as long as no damage has been found on the crankshaft. If you are going to perform this repair, then best you do a complete engine rebuilt.
In this case, if yous SWDA is compatible, just swap them.
Jun 27, 2017 | Cars & Trucks
Lawn edger no compression
check for loose plug
if 2 stroke the rings may be stuck/broken
the sump seals at either end of the crankshaft are faulty
if 4 stroke the valve/ s burnt or stuck open
When asking questions , inclusion of make model year are a big help in getting a more exacting answer.
May 28, 2015 | Garden
Pull rope will not pull motor locked up?
If the crankshaft won't turn at all, either by the pull rope or by turning the flywheel by hand, it's usually because the connecting rod from the crankshaft journal to the piston is seized to the crankshaft. This is usually caused by running the motor with oil in the crankcase. Worst case you'll have to replace the crankshaft and con-rod. In some cases the journal on the crankshaft can be cleaned up and with a new con-rod you'll be able to use the motor again.
Feb 28, 2013 | Garden
My MYD edger breaks off the adjustment rod any fixes
I've broken two of them. I had a lot of vibration, and the blade was bent. I'm replacing the rod and the blade to hopefully fix the problem. If it breaks again, and I still have the vibration, I'll look at replacing the belt and possibly the pulleys.
Feb 10, 2013 | Mtd Garden
How can i check con rods on a pug 206
you would know if a con rod was gone in your engine it would'nt turn over the engine will be jammed. if you wanted to check them anyway drop the sump they are connected to the crankshaft which in turn is connected to the pistons. they are the rods joining the two together.if they are not broken they are ok
Dec 07, 2012 | Cars & Trucks
How can i tell if my crankshaft bearing is going out
Hi, if the big end bearing fitted within the con rod on the crankshaft fails it is accompanied by a knocking noise when the engine is running, when the engine is striped and the crankshaft is out, movment of the con rod in an up and down direction while grasping the conrod between finger and thumb indicates big end failure, youmay also notice while rotating the con rod that it locks up, more so in 1 direction. Visual damage bearing cage failure visible from within the oil cut out on the big end of the conrod,
Crankshaft main bearing failure, the main bearings are fitted within the engine cases 1 left and 1 right, failure of this bearing would be movment of the crankshaft ends within the cases, accompanied by a rough vibrating sound.when running,
Hope this helps paul
Feb 23, 2011 | 2004 KTM EXC 450 Racing
I have a homelite trimlite trimmer model UT20006 can you tell me which way the connecting rod goes by the part number on bottom rod bearing?
Check the piston itself. The piston skirt is "cutaway" on one side to clear the counterweights of the crankshaft. If it is installed the other way, the engine won't rotate completely as the weights will contact the longer skirt of the piston.
Sep 28, 2010 | Homelite Mighty Lite Lawn Trimmer
My stihl weedeater will not stop when i turn the switch off... why? thanks, victor
make sure the black wire is ground and the other wire is plugged in
Jun 26, 2009 | Garden
REplacing the pulling cord on a gas trimmer
those are usaully under your pull start cover and if its broke you can buy a new rope but if its broke near handle i would open it and retie it to save ya money. but remember to wind spring a little to keep tension on it before pushing it through the hole for handle.
Apr 17, 2009 | Craftsman Convertible 25cc. Gas Line...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
