Question about HP DeskJet 845c Printer
HP Printing Problems
Hp845c keeps printing filename and other details on each sheet
    Master:
    Sergeant:
  • 461 Answers
Check your print setting and also ensure page set up on the document that you use is not include the filename to be printed
Posted on Sep 23, 2007
SOURCE:
Having problems printing Word documents - not problems printing from inteernet.
Dear
If you are printing internate page using IE, go to FILE-PAGE SET UP(choose page size, margin etc).
For image , background go to TOOLS-INTERNATE OPTIONS-ADVANCE-(scroll)PRINTING-CLICK on box- APPLY.
Thanks.
Feb 22, 2015 | HP Hewlett-Packard - Photosmart 7510...
Why does my hp laserjet 1020 keep printing 4 blanks after each printed sheet? HELP!
My solution already posted in FIXYA.. for the same complaint earlier.pl go through..
http://www.fixya.com/support/t10478324-printer_taking_two
You need to clean the paper pick up solenoid located at down right side ...gently remove & clean it as shown..best of luck..
Aug 20, 2014 | HP LaserJet 1020 Printer
Hp 2840 won't stop printing
power off the printer. removed the network cable only. power on until it display ready. now print a config sheet or menu map. if it print without error then connect the network cable and print config sheet again. wait and observed. if it will start printing garbage then KILL the print jobs queued on the printer. after deleting all print jobs power off and power on printer with network cable connected. I hope that will fix the problem. by the way. was there any error display in the panel display like "49.4C02". etc.
I’m happy to assist further over the phone at https://www.6ya.com/expert/gerardo_bdb2f65bdb2cdd4d
Feb 21, 2013 | HP LaserJet 2840 All-In-One Printer
HP PCS1402 keeps printing test sheet on start up
Have u recently changed ur ink cartridge ? If so the printer is printing an alignment page . Turn it off then on , so it prints the alignment page. load the alignment page on the scanner glass and press the "Scan" button to complete the alignment. Once the alignment has completed the alignment page will not be printed again until you change the next cartridge. See your user manual for details.
May 17, 2012 | HP PSC 2355 All-In-One InkJet Printer
My hp 1200 laserjet keeps on printing pseudo characters and not printing actual pages whats the problem with it?
Gibberish printing is almost always caused by one of two things:
1. The wrong driver is being used to send the print job.
2. The data cable (usb or parallel, you do not state in your question) is defective.
Check both of these and if that does not fix it post back with more details such as connection method, windows version, programs, the more details I get, the more likely I can solve your problems.
May 07, 2011 | HP LaserJet 1320 Printer
Paper feeder prints one sheet and sends several blank sheets out. It is also prone to develop a paper jam and envelopes do not feed properly
HP designed a quick and easy tool that diagnoses and resolves many printing problems: The HP Print Diagnostic Utility. HP recommends that you download and install the Print Diagnostic Utility any time you need to troubleshoot a printing problem.
Nov 04, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Hi i have a deskjet hp 845c printer.The problem i have is that the 3 lights keep flashing then the power turns itself off.Ive tried upluging it and changed the ink cartridge.Please can you help?
It is require servicing if you can open the cover and apply some lubricant oil on the steel rod it will fix the problem otherwise show it service center.
Nov 10, 2009 | HP DeskJet 845c Printer
Printer won't stop printing alignment sheet, following changing of ink cart.
my printer only printed 1 page out of 3 so now it wont stop. it pulls the paper in and comes out blank. this will keep going unless i turn it off. how do i reset my printer?
Aug 20, 2008 | Office Equipment & Supplies
Printing is printing blank sheet of paper
Lots of reasons here but usually it is because the software you are using to print is not compatible with the operating system anymore. Example: you used MS Photo Editor which was discontinued in 2003 and never supported under Windows XP. The one function that is broken is printing...it looks like it printed but a blank sheet of paper comes out. (exactly what you described)
Instead, use MS Picture and Fax Viewer or the follow-on product, MS Office Picture Manager.
If you remove the MS Photo Editor application under Control Panel/Software Programs then your picture files will open with a different (more print compatible and friendly) program.
Jun 21, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Printing
network cable,Thanks
Feb 23, 2008 | HP LaserJet 2430dtn Printer
HP DeskJet 845c Printer Logo
94 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
