Question about Canon Pixma iP6210D InkJet Photo Printer
Ink cartridge I have just replaced the inkcartridges and the black will not print. Is it a printer problem? Or, is it a cartridge problem? I went into the printer properties and did and cleaned the printer head, and cleaned the cartridge heads.
  • Anonymous Sep 26, 2007
    Ah ha! I thought so. I did'nt have problems until I had to replace the cartridges.
    Thank you.
    geekgrammie
  • Anonymous May 03, 2008
    I am having EXACTLY the same problem... so I don't know if it's the cartridge or the printer itself....
    Problem Solver:
  • 35 Answers
No, it's not printer fault. It is a cartridge error. Try to exchange your cartridge with your purchaser.
Posted on Sep 24, 2007
SOURCE:
New cartridges, letters in misalignment and double struck words
What Causes a Printer to Be Misaligned? ' Chron.com
smallbusiness.chron.com > ... > Setting Up a New Business Basics
A printer that has alignment problems will not print documents accurately. images and text ... Install new manufacturer's cartridges in the printer. If the cartridges ...
How to Replace & Align Canon Ink Cartridges ' Chron.com
smallbusiness.chron.com > ... > Computers
Misaligned cartridges cause poor overall print quality by producing print lines slightly... Remove the new cartridge from its packaging and remove the colored ...
PDF]Stylus Photo R300 / R300M - Product Information ... - Epsonhttps://files.support.epson.com/pdf/r300__/r300__pg.pdfEpsonEPSON Stylus Photo R300 Series - 1. Printer Parts ... asterisk (*). The printer also works with plain paper. Cartridge. Part number. Black. T048120 ... Letter. SCR1001. PremierArt Matte. Scrapbook Photo Paper for Epson. Letter ..... Unwrap the new inkcartridge. .... misaligned, align the print head (see page 11). Related ...[PDF]Epson Stylus NX430 - Quick Guidehttps://files.support.epson.com/pdf/nx430_/nx430_qr.pdfEpsonAfter you set up your Epson Stylus® NX430 (see the Start Here sheet), turn to this Quick. Guide and ..... Load letter- or A4-size paper in the sheet feeder. 2. Press ... Use the following list when you order or purchase new ink cartridges: Note: We ..
Jan 05, 2016 | Office Equipment & Supplies
I want to disable messages about the inkcartridges.
Sadly not. The HP Photosmart C7280 insists on having a full set of cartridges installed in order to print. It does this because the printheads are actually part of the printer itself and can sustain damage if they pull air into the printhead.
The out of date message is also non-negotiable I am sad to say.
Feb 05, 2013 | HP Photosmart C7280 Laser Printer
My Kodak esp 3200 series printer wont acknowledge the new black ink cartridge I just put in. Now it is saying-" black inkcartridge needs replacing-replace black ink cartridge".
Is this a genuine ink? If not then try removing and inserting a few times. If this does not work then unplug printer, leave for a few minutes then plug in and turn on. Some non-genuine inks (and some genuine) just do not ever work though.
May 30, 2010 | Kodak Esp 3250 Allinone Multifunction ( ...
What is the cartridge number of HP 4335 all in One Printer
the part number is hp 21 black injet print cartridge part# c9351aa, hp 22 tri-color inkjet print cartridge part# c9352aa cartridge for everyday printing and the high volume printing cartridges hp 27 black inkjet print cartridge part# c8727aahp 22xl tri color inkjet printer cartridge part# c9352ca; these cartridges is for hp officejet 4355 all-in-one inkjet printer
Nov 21, 2009 | HP Officejet 4355 All-In-One InkJet...
Refill inkcartridge 17 of lexmark x2250 don't work
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Apr 28, 2009 | Lexmark X2500 All-In-One Printer
Pixma mx310: error message check ink u163 will not delete after replacing colour inkn cartridge cl 41. unable to use printer.
Ink has run out. Replace the ink cartridge and close the Scanning Unit (Printer Cover). If printing is in progress and you want to continue printing,press the Stop/Reset button for at least 5 seconds with the inkcartridge installed. Then printing can continue under the ink outcondition. The function for detecting the remaining ink level will be disabled. Replace the empty ink cartridge immediately after the printing.The resulting print quality is not satisfactory, if printing iscontinued under the ink out condition.
Thanks for using Fixya
source : http://support-au.canon.com.au/contents/AU/EN/8200172900.html#6
SAM ANDERSON
Sep 26, 2008 | Canon Office Equipment & Supplies
Black ink
filling up the ink cartridge of the printer will cause an issue that the printer will be damage.HP ink are very unique and designed to be able to attain the good quality of print..filling up inkcartridge will make the warranty of the printer to be VOID...
Aug 27, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Faint Printing
It could be a old ink cartridge was installed even if you just bought it check the date.The jets maybe clog from the previous ink cartridge if it was not used often.If the date is good I would go into the utility settings on the printer and do a print head cleaning.
Aug 04, 2008 | Canon PIXMA iP2000 InkJet Printer
INK REFILL
get a new printer...this one is truly unhappy
Jul 29, 2008 | Epson Stylus C46 InkJet Printer
Other compatable cartridges
Cartridge Description
Zone 1
small black inkjet print cartridge
HP 94
small tri-color inkjet print cartridge
HP 95
large tri-color inkjet print cartridge
HP 97
photo inkjet print cartridge
HP 99
Jan 15, 2008 | HP PSC 2355 All-In-One InkJet Printer
Canon Pixma iP6210D InkJet Photo Printer Logo
134 people viewed this question
Clive
Clive
old marine
old marine
Ekse
