IBM xSeries 226 Server
Problem for IBM xSeries 226 Server
Raid w/ hard drive defunct
By itman on Sep 23, 2007
It says there is a hard drive that is defunct however the system does boot up but the application does not work and I think it is due to the oracle not being able to run. How to recover from the data corruption due to the drive failure?
Same Problem
Apr 06, 2009
-   I have a problem with my IBM Server xSeries 226. My server does not work when I start. I see the red light on the Battery FRU card and I config my server Raid 1 with 2 harddrives.
Please give me your advise,
I'm looking for the information from you,
Thank you very much!
my email: tuandoan1980@yahoo.com-   tuandoan1980
Feb 27, 2009
-   I tried to replace faulty drive and then rebuild processed but after complate the rebuild process drive goes to DEFUNCT with some FRU error i tried updating firmware and device driver but still no use, please help-   sydmali
Solution #1
posted on Oct 10, 2007
Somewhat Helpful)
enuro12
Rank: Wiz
Rating: 84%, 169 votes
Well lets make some assumptions
1. You have a Raid 5 System
2. You only have 3 drives in the Raid ARRAY
3. Only 1 drive has failed
To fix the problem you should only need to Replace the Failed Drive
Then start the raid management software or bios
Rebuild the array
If you have more than 1 drive failed in a RAID 5, and still must recover the data it is possible. But very expensive. Still fixable however.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for IBM xSeries 226 Server
Questions and Unsolved Problems for IBM xSeries 226 Server
Do you recommend IBM xSeries 226 Server?
Answer
Answer
how to install thhe rade drive to IBM X Series 226
Answer
Hi, When I go to install Server OS in my IBM server machine then I found some error regarding the... (More)
Answer
i have a raid controller (ServerRAID-61, Brodcom UNDI PXE-2.1 V7.5.14) on eServer 226. this morning... (More)
Answer
When I turn off the machine and turned it on again cause it crashed a lot repeatedly until weindows... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For IBM xSeries 226 Server:
Top Server Experts
Rank: Guru Guru
Solutions: 1351
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Server Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
