My barcode reader won't scan - light works, electricity works
Hi, I can't make my barcode reader work. It shows light, and is clearly connected to the computer - men it doesn't scan my barcodes. Any ideas? /Eva
  • billybarcode May 11, 2010
    What make and model is the scanner? Each scanner is different, but most defaults do not specify a host. Most likely you have not enabled the HOST parameter.
  • Oscar Suarez
    Oscar Suarez May 11, 2010
    What model of scanner is it? It will need to be programmed to send the data through the right output (USB, PS2, Serial etc)
    Problem Solver:
  • 3 Answers
Bad laser needs to be sent in for repair
Posted on Dec 01, 2009
Hi, I need to know how to program the DB Power barcode scanner model # BCE0008
Unfortunately, this is all I can find for instructions.
Operation Instructions:
1. Connect the USB receiver to the host (e.g.: PC)
2. Pull the trigger to start the scanner. It works on two beeps.
Notes: 1. The charging port on the scanner is for battery charging only. Do not connect it to data cables.
2. The LED light at the scanner bottom is on and red under charging and off when charging is finished.
3. During working, the scanner will auto shut down in case of not in use for 20 second.
4. The receiver was paired to the reader at factory. Do not pair again unless necessary. When self pairing is needed, please first read the code CHANNEL SETTING. (Before setting, please reset the receiver until the light turns long green. Reset it to the light off when setting is finished.
Package Including: 1 x Wireless Barcode Scanner 1 x Receiver 1 x Charging Cable 1 x Instruction
Sep 08, 2016 | DBPOWER 2.4GHz Wireless Handheld Automatic...
Why doesn't it scan?
usually you need to configure the reader to tell it what kind of barcodes you want it to read and how to interpret & output the codes to your computer (whether you need prefix or suffixes to your codes( for automation))
the user manual for the reader has some bar codes to configure the settings for the scanner.
Jan 27, 2016 | Zebra Symbol LS4278, Bluetooth, Blood Bank...
MC9190 will not scan a certain barcode, but the MC9090 will, what could be the problem?
Firstly you need to know exactly what 'symbology' or type of barcode you are trying to scan. E.G. 128CODE, ect.
Once you know this make sure 'DataWedge' is installed and go to the settings section of the software.ensure that the type of barcode you are printing is selected in the settings. After this is should work.
regards
Dave (Pen Mobile) Germain
Jan 28, 2013 | Zebra Symbol Technologies MC909X-G Series...
Scanner won't scan library barcodes.
The barcode reader is something that the backup software typically uses to identify which tape it is dealing with.
So typically your backup software can already natively read the barcode and therefor you don't need any other software.
The linked barcode reader is probably for reading a barcode that was provided via a picture (from a scanner or camera). This has nothing to do with the barcode reader that can be part of a tape library. NET UPC Barcode Reader
Dec 14, 2012 | Datalogic QuickScan I QD2100 Wired Wand...
Hello, I have the Motorola LS3478-FZ barcode reader and am having a strange problem. This is a wireless reader, and the cradle is plugged in via USB. The reader seems to scan any barcode I give it,...
Hello Mathew,
the USPS barcode is the GS1 128 (Code128) that will help you by activating accoring to the manual. Please be sure that you enable all lenghts of the Code128 barcode. That is probably the issue.
Aug 19, 2010 | Zebra LS3478-FZ Handheld Rugged Cordless...
Ls2208 Barcode Scanner program for .NET
here is the Barcode Scanner Program right now, it seems like being able to scan barcode with Symbol Ls2208 handheld device.
if it is not workiing, go to this barcode website to find more compatible software for Ls2208, i am sure you will find the proper one.
NET Barcode Reader Barcode Reader ASP NET Barcode Reader VB NET Barcode... Barcode Components NET Barcode Generator Reader Java Barcode Generator...
Jul 28, 2010 | Symbol LS2208 Handheld
Ms9535 bt not reading barcodes.
I'm using the same Barcode reader, the Metrologic MS9535 VoyagerBT.
The brief humming noize is called a "Rasbery tone" in the manual. It means that the barcode reader is not configured to read that kind of barcode, a barcode Code if you will.
There are many types of barcodes so you have to go to the Metrologic Website and get the Barcode Configuration tool to configure your barcode reader to read the type of codes you will be using.
Alternatively there is a book with configuration barcodes you can scan to configure your barcode reader manually.
Sep 28, 2008 | Metrologic Instruments MS9535 VoyagerBT...
SYMBOL MC9090 - LASER READER NOT WORKING
You may need to replace the scan engine - I can help you out with this (or any other issues you may be having).
Contact me if you need anything:
Ian
DC Solutions
ianv@dcsolutionsonline.com
Aug 11, 2008 | Symbol MC9090 Barcode Scanner
Symbol LS 4007i
Barcode readers are autonomous (no computer interaction required for them to work) readers beep to confirm that the barcode is valid, unfortunately this does not confirm that it has made it to the computer, you need to ensure that the driver & capture software is installed properly, check that the device is showing correctly in device manager. Gareth
Jul 23, 2007 | Symbol (LS4005I-I090-0000Z) Handheld
Computers & Internet Logo
703 people viewed this question
David Payne
David Payne
