Question about Philips DVDR3455H/37B
Dvd wont eject
Placed DVDR in player and it froze player. Can not eject dvd. Have also tried to find pin hole in draw to manually eject, but can't seem to find it. Can anyone help me. Thanks in advance
  • kakeko Dec 03, 2007
    i put a dvd in my recorder (philips DVD3455H) and it said 'not supported disc type'. Now when i press eject the whole thing jams up and nothing will work. Have tried unplugging it severel times but the disc is still in there and it wont eject and jams every time i try. Can someone please help me with this. i only bought it yesterday and really want to play with it. Is there a way of ejecting the disc with the power off???
Hi jodestar,
i am having the same problem with my player. how did you end up fixing yours?
Posted on Dec 03, 2007
Look at the bottom of the unit, under the disk drive. You'll see an open slot about 1 3/8" long. If you look in the slot, on the right (facing the front of the machine) you'll see a small (about 1/8" square") piece of while plastic. Insert a small bladed screwdriver to the right of the white plastic square and slide the square all the way to the left end of the slot. When you do this, the tray will open enough for you to pull it out and remove the offending disk.
Posted on Dec 25, 2007
How do I get a stuck DVD out?anks
Contact Philips customer support at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=us&userLanguage=en
Apr 14, 2015 | Philips Magnavox 26MD357B-37 26 in. LCD...
Cars player
Try this hold button 5 sec longer. If not DVD may be jammed in player. Some players have a release pin hole near the DVD draw. You will need a long wood/plastic pin to trigger it. Do not use metal pins. (shock)...
May 29, 2013 | Disney DTD1363-CAR 13" TV/DVD
The tray on my samsung dvd r160 will not open. There isn't a small hole to stick a pin in and open manually. I've taken the case off but can't see anything out of place John
Only computer DVD drives have a hole in the front for you to eject the disk. See on the under side of the player if there is a **** or slot with an arrow marking for you to use a screwdriver and push the eject mechanism. Do it with the player unplugged from the main power.
Sep 21, 2011 | Samsung DVD-R160 DVD Recorder
My Technika DVDr 2005 drawer will not open and has a DVD in place - how can I retrieve the DVD?
turn it off then unplug the dvdr then after a while plug it again and turn on, now press the play button after a while press the stop button then next is the eject button. if still the tray won't eject unplug the dvdr use a philip screw driver unscrew to open the cover. look for the plastic motor gear then manually turn it with your finger to eject the tray now you can get your dvd. place back the cover and plug the unit and then turn on to check if its working again and eject the tray. thanks i hope it will help you good luck.
Jun 13, 2011 | Televison & Video
The DVD wont eject in the rear entertainment system. I am trying to find an online Family entertainment system supplemental guide
is there a small pin hole near the draw? DVD players often have a manual eject lever you can operate by pushing a straightened paper clilp in the hole?
Jan 06, 2010 | 2006 Ford Freestar
My dvd drive wont eject since i ripped cd's on windows media player it froze and then wouldnt eject te cd
well on the CD drive u will find a pin hole which is used to eject the drive tray manually so use a pin and try to eject the CD.
good luck
Jan 05, 2010 | Acer (KV.16X04.007) DVD Drive
Dvd player will not open disc, display lock
Sound like it either has one or two problems, the door is stuck and or the door eject motor has failed. Look in the front to the player for a small paperclip like hole, and use a paper clip to manual eject the and engage the loading mechanism usually located under the door for most cases. Check you manuals troubleshooting section for manually ejecting a CD..
Please leave comment.
Oct 12, 2009 | JVC XV-N312S DVD Player
DVDR 3350H KEEP READING AND WON'T EJECT DISC
Look under the faceplate where the disc tray ejects and see if there is a small hole. If so, use a straightened paper clip to eject the disc manually by pushing it into the hole about an inch. If that works, then reset the power on the unit and try a nonrecorded type disc to see if the unit works at all.
Other than that, you'll have to take the unit apart to get your disc out.
Hope that helps...
Geno
Mar 24, 2008 | Toshiba RD-XS34 DVD Player/HDD Recorder
Stuck DVD
there should be a small pin hole in the draw of the dvd, put a pin r paperclip in the hole and push to manually open it.
Sep 16, 2007 | Samsung DVD-VR330 VCR and DVD Recorder
Philips dvdr 3320v picture freezing
Be sure there is plenty of space around the DVD player. I place mine on top of the cabinet without anything on top if it. Being enclosed seem to affect some DVD players. Also, dust frequently...
Jan 09, 2007 | Philips DVDR3320 DVD Recorder/VCR
Philips DVDR3455H/37B Logo
323 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
