Question about Goodman Heating & Cooling
When my heat pump starts, my HPS security light goes out, then comes back on again. The problem just started about two weeks ago. Any help?
  • Goodman Expert
  • 252 Answers
The compressor is probably pulling so much electricity on start up that it goes too low for the light. You could have a "hard start kit" installed on the condenser which will make it start easier. May or may not solve your problem but the "hard start kit" will extend the life of your condenser anyway! (Yes, it's a good idea for any unit that does not have one - most residential units do not.)
Posted on Apr 26, 2009
Oil light on
There is a recall on some oil pumps call give Vin number to see if it yours if not change oil pressure switch if not it electrical wiring short been recalls on that too wires taking to much heat from headlight electrical problem and cause wire to melt plastic coating on electrical wires call a short pss new oil pumps to be put on is costly but a recall on oil pump plug too very difficult to remove without damage check internet for technical bulletin that came from Suzuki
May 28, 2014 | 2006 Suzuki Forenza
Samsung DMT - 400 delicate light blinking
follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 09, 2013 | Dishwashers
How to fix the security light cause it wont let me start my car it is a GMC Jimmy 4x4, 4.3
try locking all the doors with the key .if that wont work.turn the ignition multible times on off ect.if that wont work disconect the battery.reconect and try it .the alarm is cuting youre fuel off good luck hope this helps you
Mar 29, 2013 | Buick Cars & Trucks
I have 98 sonoma 4 cycl 5 spd. 2 or 3 moths ago i had to replace the starter. the about 2 weeks ago the starter began to continue to start the truck even after it was running. so i would turn the truck...
Its the ignition starter switch not the ignition key switch part of it i beleive is mounted down by the fuse box.Go to www.rockauto.com and you can see a picture of it maybe that can help you find it.Could be down around bottom steering column.
May 16, 2011 | GMC Sonoma Cars & Trucks
Someone attempted to steal my 1998 Savana Conversion van, I had the steering column replaced and now it still won't stay started, and a security light is on the dash board. Is there a fuel pump reset...
Hi, the security system has to learn the new key resistor in the new column. If you try to start it, leave the key on for 10 mins, the security light will go off. Turn the key off, try to start it again, and release the key. The light will come back on again. Wait another 10 mins, intill the light goes out again. (leaving the key on). This has to be done 3 times total of 30 mins. When the light goes out a 3rd time, the vehicle should start, and run. Remember to turn off the headlamps, heater, radio, etc... as they consume power, and you do not want to kill the battery. Good luck...Coop
Dec 24, 2010 | 1997 GMC Savana
Car over heating also
check your fins on the radiator and your water pump also check the thermostat
Aug 19, 2009 | 2005 Ford Futura
Service engine light keeps coming on
need to scan for codes and find problem code some part stores do for free
Jul 06, 2009 | 2004 GMC Envoy
94 Jeep Cherokee Sudden Electrical Failure
major suspect here is a bad ground... you likely loosened or compromised it when at headlamp bucket area.. remove battery again and check for its negative side to be secure adn all otehr wiring there to be clean and secure..good luck and advise
Mar 13, 2009 | 1994 Jeep Grand Cherokee
Heating & Cooling Logo
75 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
