Question about Ahead Software Nero Express 6.0 (NERO6OEM) for PC
Power calibration error - Ahead Software Nero Express 6.0 (NERO6OEM) for PC
  • yogurty2 May 11, 2010
    exolain or retrain
Merde
Posted on Jun 24, 2009
Opc error.. it wont record any source..
Web search "optimum power calibration error". The manual incorrectly calls it Optimize Power Control on Page 2. It has nothing to do with the source and all to do with the media and how the laser calibrates to it.
Sep 20, 2011 | JVC XL-R5000BK CD Player
Power Calibration error
powe calibration error reffers to lens laser power
in other words the laser doesn't have enough power to write CD/DVD at specified speed
try to clean the lens (there are special CD-s for that)
and try to burn the cd or DVD at slower speed
but slowly your cd writer is dying
Jul 08, 2009 | Sony Computers & Internet
Dvd burning abort everytime because of "power calibration error"
you can try changing power plug or just get your device cleand some times when to much carbon gets into points the currents is effected...
Jun 01, 2009 | Sony DRU 510A DVD±RW Burner
CANNOT WRITE CDS
Had a drive that did the exact same thing myself. You'll need to replace the CD drive. It's cheaper than having it repaired.
May 30, 2009 | Intel Computers & Internet
Error Code at 786 (16)- Code 037303 (Medium Error, Power Calibration Fail (Cd Burner is Dirty)
i had the same problem, first when i burn movies i was using fujilim dvd+r after 10 movies burned i use maxell dvd-r i burn just 3 movies then i had a error (Error Code at 786 (16)- Code 037303 (Medium Error, Power Calibration Fail (Cd Burner is Dirty) after doing a lot of things to fixed and research thounsands of webpages one told me to use a diferent dvd then i buy sony dvd+r and now everything work perfect, maybe it helps, write me if you need help.
weddie2006@univision.com
Jun 20, 2008 | Toshiba Computers & Internet
Error 0F0100030C099F on hp5000
found this maybe can help i dont know
I tried the fix of :
This may be an error finding the mark encoder. The mark encoder is the
white plastic piece on the left end of the roller. Replace the lense cover
first. If the error remains, turn the printer off, and place a piece if black
tape over the hole at the left end of the drive roller, this will block the
mark encoder from the line sensor and should trigger a 010092 error during
power on. When the 010092 error comes up,
press enter to continue past the error. After the printer comes ready, remove
the tape, and run a scan axis calibration.
To run the Scan Axis Calibration:
1. Enter "Device Setup".
2. Enter "Utilities".
3. Press the UP arrow and ENTER keys simultaniously,
4. Select "Yes".
5. Enter "Service Calibrations".
6. Run the "Scan Axis Calibration".
May 30, 2008 | HP DesignJet 5500PS InkJet Printer
POWER CALIBRATION ERROR
Power Calibration error indicates that the drive hasn't been kept clean and is unable to guarantee a good write to disc...
I recommend a wet and dry CD/DVD Cleaner disk with Alcohol on the wet side (Like Tape Head cleaner liquid) and let it dry for a minute then run the disc again... if it still happens the drive is on its way out.
May 25, 2008 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Power Calibration Error.
first re install your nero .and
A) Power Calibration is controlled by the recorder. Before any write operation, all recorders must do a 15 step power test to determine the optimum power for writing to the CD; this is called "Optimum Power Calibration"(OPC). And during the write, it continues to do this test to get the best write throughout the whole CD; this is called "Running Optimum Power Calibration" (ROPC). This whole process is controlled by the recorder, though initiated by programs such as Nero. There is an area on the inner part of the CD for the test and test data info to be stored. You can use this area up to 999 times.
So, when you receive the "Power Calibration Error" or "Power Calibration Area full" error message, then the cause will be either poor media, poor Power, or a defective Recorder.
POSSIBLE SOLUTIONS:
1) A might enable the OPC on this medium
2) Try another brand of CDR or CDRW media.
3) Also try different power connectors, and for recorders, do not share power with other devices. It needs its own power connector. If this occurs with an External recorder, the power source in the chassis could be the cause. Take the recorder out of the external chassis, and connect it internal, as a test.
4) Try different configurations, such as taking the CDROM to the Primary IDE bus as Slave, and have only the recorder connected to the Secondary IDE bus as Master.
5) Send the recorder in for Service.
Here is the direct Link: http://www.nero.com/en/632181809668074.html#23
I Hope this helps,
Feb 12, 2008 | Ahead Software Nero 6.0 (60045) for PC
Problem copying a movie onto a lightscribe hp dvd +r media disc, using my hp dvd940e dvd writer
The semaphore timeout period has expired refers to the fact that the driver is no longer communicating with the device and failed. Each time a CD Burner is setup for a CD Burning session the burner hardware will perform a 15 step power test to determine the OPC for a Blank Media Disc, OPC meaning Optimum Power Calibration. This test also takes place during the CD Burning process so the CD Burner can determine the best burn speed and method for the disc; this test is called 'Running Optimum Power Calibration'. Although the test is performed by the hardware of the CD Burner, the device initializes the CD Burning Software for the test to take place. This is one reason why your software may report the "Power Calibration Error" or ?Calibration Error Full?. With Power Calibration errors they can be caused by different factors and sometimes difficult to locate, especially if the errors are at random. Below are the known factors that will cause the Power Calibration Errors and how to check each factor, it is important that each point is considered if wanting to get to the bottom of the error. Power Calibration Errors can occur when OPC or ROPC tests for the media disc so the condition of the disc, brand of disc and even the firmware for the CD Burner can be the cause for the errors occurring. A device such as a CD Burners can have different problems if there is a power consumption issue with the system and the Power Calibration Error is just one of those problems. If using either an internal or external CD Burner make sure to disconnect all other devices, except the hard drive and Burner, before attempting to burn a disc. Double check all cables for any faults and if possible test with a 2nd Data Cable. It is also advisable to disconnect the power connection for the CD Burner and test with a spare connector. If you have no trouble with other discs, use them and put to one side the lightscribe, other than that try the burner in another pc or with other burning software, as you can see it's quite ridiculous what problems burners can create.
Jun 13, 2007 | HP DVD940e Burner
this can be a complicated issue to solve, so go to the link below and see if there is any advice that is rellevant to you http://www.cd-burner-help.com/power-calibration.htm
Jun 03, 2007 | LG (8526B) CD-RW Burner
Ahead Software Nero Express 6.0 (NERO6OEM) for PC Logo
188 people viewed this question
Top Ahead Software Computers & Internet Experts
Martin Murray
SHIVAJI YADAV
SHIVAJI YADAV
Are you an Ahead Software Computer and Internet Expert? Answer questions, earn points and help others
