Question about Craftsman Garden
I have a craftsman 16.5hp 42in lawn tractor it runs good for just a few minutes then it spits and sputters and dies out. i have changed the spark plug,air filter and fuel filter and still havind a problem need help
  • jrcollin Apr 23, 2009
    dennymulford that was not the problem with the fuel cap vent i am still having the problem any other suggestions would be great.
    Problem Solver:
  • 14 Answers
Make sure fuel pump works, the little bubber valve inside can come off causing poor suction? If you blow air in the tank, and that makes it run more , fuel pump is like a double check valve. Allowing gas to move only forward towards the carb.
Posted on Nov 01, 2013
    Genius:
  • 1,055 Answers
I had the same problem the vent hole in the fuel cap was plugged
Posted on Apr 23, 2009
Was mowing the lawn about 20 minutes then mower stopped. It is a craftsman platinum 7.25
sounds like the spark plug may be fouled or the fuel filter or carburetor is dirty.
Sep 17, 2016 | Craftsman Garden
Craftsman lawn tractor
you may have a safety switch that has went bad or came unhooked. unplug and test for continuity. also under the hood you will see a fuse, check to see if that has blown. if all that is good you may want to unhook the coil try to start it and see if it has fire. it is possible the coil has went bad. hope this gives you an idea where to start
Aug 16, 2013 | Garden
My craftsman 42in rider quits after about 30 to 45 minutes. The carb solenoid is good and the gas cap is venting ok. I have to wait about 20 to 30 minutes before it will start again. What should I check...
try the coil,does it get fire to the sparkplug after it quits and what color is the spark? blue spark is good, red is weak fire, and not enough to fire the engine up.
Jun 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Runs good for a few minutes then acts like it runs out of gas.
have you checked to see if the fuel filter line has been changed in a while ? If not change this , if you are still having problems could be the float or the jet within the carb
Jul 25, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman garden tractor stalls after running for about 20 minute
do you have the right fuel filter? some are for pressure and some are for gravity feed, the pressure type (fuel pump) wont flow the gas correctly. another possibility would be the coil.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Spitting and sputtering
mine did the same, I found out that the high speed jet was clogged, I pulled the fuel line off the filtor(going to the carb), stuck the line into a mixture of half gas half carb cleaner, I fanned it up and in 2 or 3 minutes it started running well, hope this helps.
May 20, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a Craftsman lawn tractor 21.5 hp, model no. 917.272463. The engine starts well, but while running it spits and sputters every second or so, whether at idle or at full throttle. I changed the fuel...
Try changing the its oil-seals. The problem lies there. It may be damaged or the oil-seals are now smaller than its is used to and it is because of the heat. The oil-seal are rounded things that are made of rubber.
May 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
18hp/ohv craftsman 42in wont crank
One thing to check, see if there is a piece of root stuck under the tractor there is interrupting any of the security features from allowing the tractor to start. It might be a small piece that stops a plunger from engaging.
Mar 26, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
264 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
