Question about Samsung SC-D453 Mini DV Digital Camcorder
Samsung sc-d453 Memory Stick
Hello, If you have this camcorder and looking for an answer about the memory stick? Well, the memory stick is only to store picture files and not video. It took me awhile to fiqure this out. So, before investing in a memory stick, be sure to find the cheapest one.
  • 903 Answers
SOURCE: Taking still photoes with the memory stick.
1. Set the mode switch to MEMORY STICK. 2. Set the power switch to CAMERA. 3. Press the PHOTO button and hold it. **If you do not wish to keep the still photo, wait 2 seconds until the picture releases. 4. To keep the image, pess the PHOTO button once again within 2 seconds after releasing the button. The still image is recorded to the Memory Stick. **Audio cannot be recorded onto the Memory Stick.
Posted on Sep 07, 2005
  • 903 Answers
SOURCE: My Camcorder Says "Protection" And I Cannot Record
A picture of protection tab in protection position
  • 763 Answers
SOURCE: Sc-D453 dosn't connect to my computer
you need a driver for that to be able to recognize your camcorder on your computer.
after you download the driver, install it to your pc and it should be recognizable after you done it.
as for editing, windows moviemaker is a good software for editing but i prefer to use Ulead Movie maker, Ulead Producer or anything about Ulead because its so easy to use for editing and saving a movie or video files from your camcorder. you can also use your usb for connecting the interface with your camcorder and pc. hope that helps you and thank you for using fixya. dont forget to rate thanks!
Posted on Oct 17, 2008
  • 763 Answers
SOURCE: My SC-DC163 camcorder does nothing when I try to upload videos to my PC.
the way you can transfer your videos on your computer is by using USB cable and install the driver to your computer. You can upload your videos by saving it on ULEAD products. As far as i know you cant transfer videos from disc to your memory card unless it was been converted but you cant view or watch it on your camcorder itself only computer can play this because your camcorder is not able to play such converted files.
Posted on Nov 06, 2008
  • 56 Answers
SOURCE: I recorded a video on my samsung sc-dc 164
how did you transfer the video from the card to your PC?
did you connect the camcorder to your PC or did you use a memory card reader?
if you can play the audio then what you need is the right video codec for the unit
try searching for video codecs through search engines
make sure that the software that you are using to play the video plays the file format of your video,
try using roxio, then connect the camcorder to your computer via USB, make sure that the drivers are installed, play the video through your camcorder then use roxio to capture it real time instead of the usual "copy-paste"
Posted on Jul 02, 2009
SOURCE: Memory Card Problems
According to the samsung website " Samsung camcorders manufactured in 2004 and later can be used with memory sticks up to 1GB. Anything over 1GB is not guaranteed to work. "
I have the same problem. Video works fine on my 256MB card but not on my 4GB or 8GB cards. It would be nice to know if anyone has success with a particular card >1GB.
Posted on Jul 31, 2009
0 characters
1 Points
What is a memory stick
Click Wikipedia for info about memory stick, a full page info about memory stick versions, images etc.
Jan 15, 2010 | Samsung SC-D353 Mini DV Digital Camcorder
What type of memory card does the SC-D353 Mini DV Digital Camcorder use ?
i currently us a Lexar memory stick duo adaptor. with a memory stick pro duo inside of that.
Aug 20, 2009 | Samsung SC-D353 Mini DV Digital Camcorder
Memory card error
did you already formated your memort stick? try to remove your memory card from your camcorder and insert it again. look for the settings on your camcorder. it might cause the problem. hope that helps!
Aug 17, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Not recording
i have a camcorder just like yours. by the way im not using memory stick because its pretty easy to use a dv tape.
try to switch from the menu your storage device like dv to memory card or stick. format it to your camera and computer. hope that helps!
Jul 28, 2008 | Samsung SC-D353 Mini DV Digital Camcorder
Memory stick
this site has all types of memory for all equipment you could search here for it. memory
Mar 03, 2008 | Samsung SC-D353 Mini DV Digital Camcorder
Samsung scd103 camcorder memory card
From the manual:
“Memory Stick PRO” can not be used with the SCD103 MODEL.
You MUST use only a memory stick, not the PRO
Nov 18, 2007 | Samsung SC-D103 Mini DV Digital Camcorder
Sep 30, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Samsung SC-D453 Mini DV Digital Camcorder Logo
212 people viewed this question
Top Samsung Video Cameras Experts
Pieter Vleeshouwers
Chris Hunt
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
