Question about Sharp AR 201 Copier
AR-201 shows "check panel"
Thats all the problems it got. after that messege theres no any function in that.pls help me to repair that.
  • 163 Answers
Plese write the error codes coming on the display
Posted on Sep 23, 2007
5518 advanced clear
check fusing unit first and then reset error code.
Sep 19, 2013 | Sharp AR 201 Copier
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
Ar-160 display says "check panel" no more codes or functionality
tis problem is some of panel button is short i mean it is lock please open your machine panel board and service it . then solve your problem
Aug 02, 2009 | Sharp AR 201 Copier
Error Code F1 on Copier Sharp AR201
F1 means "shifter Motor Trouble". The motor that driver the shifting mechanism at the paper exit side is not functioning. The motor could be bad or there may be something binding the motor up. Take a real close look at the exit unit (where the paper comes out of the machine) and see if there is anything in the way of the shifter. It could also be a bad board issue - sending the wrong signal to the motor... or possibly a bad home position sensor for the shifter.
You could try taking the shifter unit out for a closer inspection - make sure its properly installed.
Hope this helps.
Apr 13, 2009 | Sharp AR 201 Copier
Incomplete copy
the paper is set to 8.5-11 and you are running letter r paper u must set the copier tray to the proper size
Mar 03, 2009 | Sharp AR 201 Copier
DISPLAY ALTERNATES "L" THAN "6"
Hello sir; this machine have a laser unit problem, replace it !
Feb 18, 2009 | Sharp AR 201 Copier
Display messege 4H how to solve pls
Its an error indicating the fuser isn't at the right temperature. It could be a thermistor that went out. It should be looked at to see what needs to be replaced.
Nov 19, 2008 | Sharp AR-5316 Advanced Digital Imager...
H and 3 Reading
This is a fuser (heating section) trouble code. It means that a higher than normal temperature was detected in the fuser. To reset you must press the following keys in order. Press the clear key, then interrupt, then the number 0 then interrupt. The display will change and you then enter the numbers 1 and 4 then press "print" the machine will then restart the warm up sequence. If the code reappears, your thermistor is bad and must be replaced. Only a technician can do this. Let me know if this helps. Aloha Bill Monroe
Sep 06, 2007 | Sharp AR 201 Copier
Sharp ar 201copier not working
L6 means that the polygon mirror is locked up. I have repairedthis many times in HP laser printers and is is relatively easy. The top cover needs to be removed and laser scanner opened. Then remove and clean the mirror asm. May have to replace the scanner asm. This will be expensive.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 01, 2007 | Sharp AR 201 Copier
Sharp AR 201 Copier Logo
200 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
George Mclaughlin
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
