Question about Air Purifiers
Lack of power on an ionic breeze 1637 model, bought via sharper image
The unit is about 4 years old. When dirty it crackles and you clean the systems 'blades'. When I did so the last time, I used my typical cleaning fluid (a gentle eyeglass cleaner), then rewiped with water lightly. I always let it fully dry before reinserting the blade section of the system back into the main unit. This time when I did so and power on the unit - Nothing. No lights, no crackle, etc. If it were a computer, it is almost like the power supply coincidentally got tripped or something? Is there an internal Breaker or Reset ability on these models? Thanks so much...
  • Anonymous Jun 08, 2008
    Same problem..probably the power supply..no doubt hopeless
  • Anonymous Jan 24, 2009
    I just bought one and it won't turn on.  Right out of the box.  Nothing...
SOURCE:
SOURCE: Ionic breeze Quadra S1637
What is a grid and what is a grill when referring to the Ionic Breeze Quadra?
Posted on Aug 26, 2008
  • 62 Answers
SOURCE: Sharper Image Design Ionic Breeze GP Professional Series Mod 1861
I posted a solution to a similar problem I had with my Ionic Breeze GP. I was able to replace a bad switch and get the unit working again. Please check the following Fixya article for details on my fix:
http://www.fixya.com/support/t123864-ionic_breeze_3_0_repair
Posted on Nov 13, 2008
  • 6 Answers
SOURCE: Ionic Breeze Quadra won't turn on
Okay, after working on my Ionic Breeze Quadra I have fixed it. My problem was it wouldn't turn on even though the fins were clean.
1. Unplug
2. Turn the machine upside down (there are 4 screws holding the bottom stand on) remove the screws
3. once bottom is off there are 2 screws sideways helping the hold the 2 sides together. Remove those 2 screws.
4. Turn the machine uprgiht and remove the middle fins (the ones you clean)
5. Remove the 4 screws that are deep in the 4 holes when you look down inside (you can't see the screws, I had to feel for them with a phillips head narrow screwdriver)
(it will be easier if your screwdriver has magnetic head for next step.)
6. after removing the 4 screws gently work lose the top (part that has the little lights and turn on push switch)
7. turn the breeze on its side, you will find about 5 or 6 tiny screws holding the two sides of the outside louver case together. Remove all these screws. You will be thankful for the magnetic end, I have small fingers and still had a problem catching the little screws.
8. You don't want to remove both sides, just one side is fine.
9. Being careful of the wires (I left that side alone) I worked from the wire free side and using a bottle of rubbing alcohal and lots and lots of q-tips I gentle cleaned off all the gunk on all the little metal pieces at the bottom of the breeze (on the inside where the wires are). Clean as good as you can, you will find the metal pieces covered with what looks like tar but it comes off with the alcohal.
10. Using a can of 'canned air' like you'd use for a computer, gently blow the rest of the breeze parts getting all the dust away but being careful not to damage the electronics. (there are a lot of little computer boards). I didn't find any dust in the electrical parts in the very bottom of the breeze, just above where the fins are and some at the top where the controls are.
11. I cleaned the 1/2 I took completely off with some rubbing alcohal, gets that **** off pretty good but didn't mess with the side with the wires, just blew the dust out, gently cleaned a bit and on the outside.
12. To put back together, first I gently put the outer middle pieces together and then gently put the control top back on and replaced those 4 screws. Then I put the 10 or 12 tiny screws back into the middle, then the 2 screws in the bottom sides and 4 screws putting the stand back on. I stood it up, plugged it in (make sure its dry) and turned it on and the light came on and it is working great.
I've had mine for 3 years so I think they occasionally need a thorough cleaning. Except for the canned air I bought nothing else. Everyone has rubbing alcohal and q-tips in their homes. When I first started I didn't know how to dismantle it and tried to clean the inside with long q-tips but it was too hard. Those little metal pieces in the bottom make some sort of connection to the fins we pull out and clean so I guess they need good contact.
I hope I've helped all of you with the problem of the Ionic Breeze Quadra and I suspect any other iconic breeze type machine by sharper image pretty much comes apart the same way and may have the same problems. I don't know how to post this so that everyone can see it as a general solution. Maybe you guys at FixYa can help with that. --- Harry Potter Without the Wand (and a female to boot!)
Posted on Mar 08, 2009
  • 170 Answers
SOURCE: Who repairs the sharper image ionic breeze GP
This is a repair that someone I know didafter reading a post on the net.....regarding Quadra repairs....and here is a link for repairs....its all one link....so type it into your browser or paste it.....
http://www.airpurifierrepair.com/ProductDetails.aspx?ID=34&ProductId=591
Remove the grid assembly.
Remove the 4 screws holding the top on.
Gently remove the top as there are wires connected to it.
Once removed, find the microswitch assembly on the side. There will be 2 green wires going to this assy board (PCB).
Examine the bottom of this board. On both my units, the PCB wascorroded badly on the trace that runs from the center lead to the wireconnection. This will cause the microswitch to quit working.
What I did was soldered a wire from the center contact of themicroswitch (center piece coming through the board. There should be alarge solder pool) to the wire connection at the edge of the board.This just 'goes around' the corroded PCB trace.
Worked fantastic on both ionic breezes and took about 5 minutes for thesecond one. The first one took over 2 hours just to find the problem.
I hope this helps.....good luck...thanks for rating my effort....the Fang.
Posted on Apr 01, 2009
localwonder
  • 6784 Answers
SOURCE: I have several ionic Breeze air purifiers that have problems
Unfortunately, there are no repair depots that are available for use since Sharp Image has claimed bankruptcy. these product are very unique in design and, the actual repair parts are no longer in stock. the suppliers went under when Sharp filed for bankruptcy.
You may be able to repair the wiring by ordering the identical gauge from you local electrician but, that's about it. most of the hardware is no longer available.
Posted on Jun 18, 2009
Hi I need a new bar for the model # S 1637 sharper image quadra.
Are you talking about collector gid, the 3 bladed bar? If so I recently saw some for sale on Ebay they were used but would still work for you. Search for Sharper Image Ionic Breeze and that should get you close enough to where you will see icons of the parts.
Dec 15, 2010 | Sharper Image Ionic Breeze® Quadra® 4.0...
Sharper Image Ionic Breeze Gp Silent Air Purifier
Ionic Breeze machines are no longer being supported. Sharper Image recalled the product several months ago after it was proven by Consumer Reports and the EPA that the product wasn't cleaning the air and can be harmful to use. Sharper Image took legal action and lost.
The Consumer Product Safety Comission is going to make a decision on all ionizers by the end of the year. It's looking like all ionizers will no longer be sold in the U.S. regardless of who makes them.
Aug 05, 2008 | Sharper Image Air Purifiers
Sharper image ionic breeze air cleaner
There isn't one. The reason why Sharper Image went out of business is because the Ionic Breeze was proven to be ineffective product and harmful to use in some cases based on Consumer Reports data as well as data from the EPA. They sued Consumer Reports, lost the case, and had to pay all the legal bills.
The Consumer Products Safety Commission is going to making decision on all ionizers by the end of the year. It's quite possible that no one will be selling them anymore.
There is thread I left in the Ionic Breeze section about the EPA data on ionizers and the harmful effects of using them as well as a link about what happen to Sharper Image.
This product should have been regulated a long time ago. Orek and few others are going to be pulling the plug on them real soon.
Jul 15, 2008 | Sharper Image Professional Plus Ionic...
GP Professional Series Ionic Breeze - Simply Quit Working
Sharper Image models are no longer supported because they have been recalled since they were proven to be ineffective.
Here is a link about the Chapter 11
Here is a link for the EPA about ionizers
Jul 06, 2008 | Sharper Image Professional Plus Ionic...
SHARPER IMAGE AIR CLEANER HAS STOPPED WORKING, NO BREEZE COMING FROM UNIT AND BLADES ARE NEVER DIRTY. THE "ON" LIGHT IS ON.
Sharper Image no longer supports Ionic Breeze machines. They recalled them a few months back since Consumer Reports and the EPA has determined that they weren't working and can even cause health hazards during usage. Sharper Image sued an lost forcing the company in bankruptcy.
The Consumer Products Safety Commission is going to make a decision on sales of all ionizers in the U.S. by the end of the year. It's looking like you won't be seeing these around much longer.
Jul 06, 2008 | Sharper Image Ionic Breeze Air Freshener...
Ionic Breeze Silent Air Purifier GP
Ionic Breeze products are no longer being supported because Sharper Image has gone into bankruptcy because the units were proven to be ineffective for cleaning the air by Consumer Reports magazine and by EPA studies. In face they have proven that ionizers can be harmful to use if you have breathing problems.
Here is an article about Sharper Image
Here is the EPA article
Jun 30, 2008 | Sharper Image Professional Plus Ionic...
Ionic Breeze Professional Series Table Top Model
you need to clean the unit entirely, but be prepared, it will eventually do it again and again until it finally stops working all together. I have sent three back in one year and now they won't do anything since itis longer than the 1 year warranty. No wonder theyare bacnkrupt; selling worthless ****!!
Mar 09, 2008 | Sharper Image Ionic Breeze 3.0 Air...
I was able to find the power-on switch to be defective. The switch is a momentary normally off switch constructed of two contacts on a printed circuit board1.gif. After five years, the surface of the switch contacts became oxidized and no longer made electrical continuity when depressed. I rewired the two wires to a new momentary switch and both my Ionic Air Cleaners are working again.
Feb 18, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Sharper Image GP Silent Air Purifier with Ionic Breeze s1730
i have 2 units, and had this same issue happen 3 times. Tonight it happened with a forth, last time i had to talk to management to get it replaced outside of warranty. Ionic breeze has major quality issues, and I would NOT buy anything else from sharper image. They also reduced the warranty from the original model drastically. for the price these were, they should be covered lifetime to show their commitment to their product. there is also a class action lawsuit against sharper image, for their false claims for the product...i believe sharper image chose to settle.
Oct 31, 2007 | Sharper Image Professional Plus Ionic...
Air Purifiers Logo
248 people viewed this question
Top Air Purifiers Experts
Marvin
Marvin
Michael Youngman
Michael Youngman
Are you an Air Purifier Expert? Answer questions, earn points and help others
