Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Yellow blinking status light
Original lamp died. Bought exact replacement. Placed into position and replaced cover, Now, yellow blinking light. According to manual, 'cover is not placed or lamp cartridge is not seated'. Both seem good. Cover switched was checked ok. Could this be a bad ballast or is new bulb bad?
    President:
  • 4,402 Answers
I would make sure you have it seated correctly into the ballest some times the connector will come undun
Posted on Jan 18, 2008
My 73" mitsubishi dlp WD-73827 turns off and has a red status light blinking. I have replaced the bulb and the heat sensor... any answer to what else could be the problem?
It is helpful to have the sequence of the blinking red light. This may help:
MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927
Page 43
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "DEVICE" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
POWER
LED
STATUS
LED
LAMP
LED
Power
Status Condition
Off Yellow Off Low
Power Excess heat. Check Lamp Filter
Off or On Off Yellow No
change
120w usage time over 7000 Hrs.
150W usage time over 3500 Hrs.
Off Off Blinks
Yellow
Low
Power Lamp Cover open
Off Blinks
Yellow Off " Filter Cover Open
Off Off Red Stby Lamp did not turn On
Off Blinks
Red Off Low
Power Fan Stopped
Off Red Off " Circuit failure (short or DVI
connector unplugged)
Abnormal LED Indications
Error Codes "DEVICE" & "MENU"
Error Codes Description
12 No error detected
22 Recovery from Reset
32 Lamp cover is Open
34 Lamp abnormality
35 DM Fan failed (Chassis Fan)
36 Exhaust or Lamp Ballast Fan failed
37 DMD Engine Fan failed
38 Lamp temperature abnormally high. Remove Lamp to check filter.
39 DMD temperature abnormally high
41 Short is detected (Standby Power Supplies)
42 Lamp Fan failed
44 DVI cable between Format and Engine disconnected
46 DMD Temp. Sensor not detected (check DT connector))
47 DM Temperature too high
48 Engine power supply short detected
51 Speaker Drive circuit short detected
52 HDD excess temperature (V30+ & V31 only)
55 HDD Fan Stopped (V30+ & V31 onlyt)
Jul 18, 2014 | Mitsubishi WD Televison & Video
I have a blinking yellow status light on my mitsubishi 73837
blinking yellow indicates no lamp or the lamp door is open. if you had the back off you may have gotten the door switch aligned improperly. the door switch is located just inside the lamp door.
the lamp may also be bad.
lamp part# 915B403001
see website:
http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-73837
Apr 29, 2014 | Mitsubishi WD-73837 73 in. HDTV
Wd-60737 mitsubishi blinking yellow status light ?
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Oct 25, 2012 | Mitsubishi WD-60737 TV
I have the 60 inch mitsubishi dlp. There was a sound just like a light bulb going out. Then there was no picture or sound. I replaced the lamp and still no picture or sound. I hear clicks when trying to...
If the status led is blinking yellow its indicating that the filter cover on the side is open. If its the lamp indicator thats blinking yellow its indicating the lamp door cover isnt attached properly.
Sep 24, 2011 | Mitsubishi WD-52825 52" Rear Projection...
Just replaced lamp. when plugged in, power light
hello make sure the lamp is fitted securely and the lamp cover aswell
regards
shaun
Jan 16, 2010 | Panasonic PT-50LC13 50" Rear Projection...
I have a WD-62525 TV and I was getting a message
The lamp cover isnt secured properly that what causes the staus light to blink yellow.
Dec 30, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Yellow light keeps blinkingand the tv wont turn on
If the status light is blinking yellow it means the filter cover is open ( On the left side of televison)
If the lamp light is blinking yellow it means the lamp cover door is open. ( Behind front lower panel) If both covers appear intact the switches may be defective or not engaging properly.
Dec 11, 2009 | Mitsubishi WD-52525 52" Rear Projection...
KDF 50WE655
3 times blink means Lamp Cover is not placed back that was removed while replacing lamp, make sure lamp cover is fixed securely in its position.
Thanks.
Sep 28, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
TV was working earlier, today came home no green power light no nothing
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
471 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
