A/C - Passenger side cold, Driver side hot
2002 Dodge Grand Caravan 3.8L. Passenger side AC blows cold air, drivers side is hot but eventually cools down after about 15-20 minutes. Is a sensor that controls one of the doors in the vent?
  • 3,361 Answers
Probably a bad vacuum line not opening the damper vent.
Posted on Apr 22, 2009
Driver side blows warm air and passenger side blows cold, why?
This is an attempt to answer. My Dodge Grand Caravan has a sliding control for the heat/cool setting. It is marked driver and passenger so one can direct heat/cold where it's needed most.
Most likely you have already checked this out, but worth a try!
Oct 30, 2016 | Cars & Trucks
My 2011 dodge durango citadel has cold air blowing on drivers side AC and warm to hot on passenger side ac
Dual air. The actuator is bad. It is between the fire wall and HVAC plenum. The dash has to be removed along with the plenum. Costly job at the garage.
Feb 03, 2016 | 2011 Dodge Durango Citadel
I have a 2008 Toyota Corolla and heat on the left side and the right side is cold, what to do?
Heat is blowing on passenger side, but cold air ... - RepairPal
repairpal.com > Questions > Dodge > Ram 1500 > 2002 Dodge Ram 1500
Dec 7, 2009 - When I turn on the heat, the passenger side is receiving warm/hot air but ... blow hot air on the drivers side and it would get cold right away. about a week ago... I have a 2008 Dodge Ram 2500 SLT. ... Regardless of the settings cold air blows from the left vent and on the floor on driver and passenger sides.
Temperature Blend/Recirculation Doors May Fail and ...
repairpal.com > Problems > Jeep > Grand Cherokee
2008 Jeep Grand Cherokee143,000Visitor. I get cold air on driver side and warm air on the passenger side. Upvote (29) ... right side air is always at the coldest. no heat on the right side and air temp will not change, left side works good. .... Models: · Honda Accord; ·; Toyota Camry; ·; Honda Civic; ·; Acura TL; ·; Toyota Corolla ...
Heating and AC Temperature and Air Delivery Mode Do
Jan 16, 2016 | Toyota Cars & Trucks
96 dodge grand caravan... blows cold on passenger side when heater on, as well controls reversed. cold is hot nad hot is cold
SOMEHOW I BELIEVE YOUR TWO INTAKE & RETURN HEATER HOSES THAT FEED THE HEATER CORE HAVE BEEN REVERSED. EITHER THAT OR a plugged heater core
Feb 10, 2013 | 1996 Dodge Grand Caravan
My heater does not blow in floor in a dodgeram 1500
the heater vacuum motor and lines needs to be checked.Also get the blend door checked.
NO HEAT ON FLOOR VENTS
As per your problem mentioned. There are few solved help links to troubleshoot these problems. Go through the list and Click the link below:----
2000 Toyota Avalon: No heat on Passenger Side?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
No heat on Oldsmobile Silhouette?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
Hot air on the driver's side vents only?
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
Temperature gauge does not move and no heat when heater is ON?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold?
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold?
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
Ford F150 Ac only blows through defrost vents?
http://technoanswers.blogspot.com/2012/01/forf-f150-ac-only-blows-through-defrost.html
Dodge A/C come out of defrost vents only?
http://technoanswers.blogspot.com/2012/01/dodge-ac-come-out-of-defrost-vents-only.html
Ac vacuum line on dodge cummins?
http://technoanswers.blogspot.com/2012/01/ac-vacuum-line-on-dodge-cummins.html
Ford ranger AC blows cold through defrost vents instead on cabin vents?
http://technoanswers.blogspot.com/2012/01/ford-ranger-ac-blows-cold-through.html
2005 Chrysler PT Cruiser: A/C Blows Warm?
http://whoisbyme.blogspot.in/2012/06/2005-chrysler-p8t-cruiser-ac-blows-warm.html
2009 Mercury Grand Marquis: A/C blows Cold From Defrost Vent Only?
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
AC not blowing through Vents on 2007 Chevy Trailblazer?
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
Passenger side temperature is warm air out of dash vents?
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
No heat from vents
Heater blows cold?
These will help.
Thanks.
Nov 28, 2012 | 2006 Ford Taurus
Dual AC not cooling on driver's side. Is there a fuse for this?
There are two blend doors with actuators in models with separate controls for driver and passenger in the HVAC unit. Apparently the driver's blend door is broken/jammed, or the actuator is not working. You'd need to check a service manual to determine how hard it is to get to and repair the driver's blend door.
Jan 18, 2018 | 2005 Dodge Grand Caravan
96 grand caravan passenger side heat problem. There is a dual temp control, it works properly for the drivers side but the passenger side always blows HOT no matter what the temp control is set. The...
The wire on the back of the control is most likely broken, I had the opposite (drivers side allways cold) I dissconnected the solid light green wire and now have hot air all the time, I disconnect it in the summer for cool air, the part is very expensive, $70.00 at a salvage yard!
Jan 08, 2010 | 1996 Dodge Grand Caravan
Heating & Cooling Logo
731 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
