Question about Nespresso Romeo E350 Espresso Machine
Large cup too large
I have had my Romeo E350 for about three years now, and I have until recently been able to use both the small cup and the large cup. When using the large cup function, I was also able to press it again to make the machine stop brewing. Now, when I use the large cup function it keeps on brewing until it either goes out of water, I turn off the main switch or when it has brewed enough coffee for five normal cups.
  • frispar Apr 22, 2009
    makes sense.
    Sergeant:
    Champion:
  • 219 Answers
Well as you said you have used it for 3 years. It is a machine so it too need the maintanence.
Call the mechanic, he will help you with this.
There is some internal problem with your machine,
Thanks!
Sandy
Posted on Apr 22, 2009
My Keurig B40 has three different size cup sizes available, but it dispenses the same amount of water for the medium size cup and the large cup of coffee. It's barely been used so It doesn&am
I realize you think it does not need descaling to to it 'not being used much.'
However you may have hard water and I would think descaling is definitely worth a try. There might be scale built up on the water level probes in you machine.
Descaling Details are listed below:
Brewer Model: Elite B40 ' Classic B44
Special Edition B60 ' Platinum B70
To begin, you will need the following:
• 48 ounces of undiluted white vinegar
• Large ceramic mug (do not use a paper cup)
• Access to an empty sink
PREPARE
Step 1:
Empty the water in the Water Reservoir.
Step 2:
Disable "Auto Off features."
FILL AND CLEAN
Step 1:
Pour approximately 48 ounces of the vinegar into the Water Reservoir.
Step 2:
Place a large mug on the Drip Tray Plate and run a brew cycle.
(DO NOT USE A K-CUP)
Just press the BREW Button. Pour the contents of the large mug into the sink.
Step 3:
Repeat the brew process without a K-Cup until "ADD WATER"
is indicated.
Step 4:
Now let the Brewer stand for at least 4 hours while still on.
Step 5:
Discard any residual vinegar and rinse the Water Reservoir thoroughly.
RINSE
Step 1:
Ensure the Water Reservoir is filled with fresh water.
Step 2:
Place a large mug on the Drip Tray Plate and water brew cycle. Pour the contents of the large mug into the sink.
Step 3:
Repeat brew process until "ADD WATER is indicated.
Step 4:
You may need to perform additional water brew cycles if you notice any residual taste.
Nov 20, 2014 | Keurig B40 Coffee Maker
How to programme it for larger cups of coffee
Press/Hold the large cup button until u reach the desired measure of your coffee... Release it when u think it is enough for your large cup..
Feb 09, 2013 | Nespresso DeLonghi Lattissima Plus...
How to reset keurig b40
1. There is some confusion over models. I've seen "B40" models and instructions with only one size cup button, both labeled B40. I own one stamped "B40" on the bottom, and it has two buttons -- small and large. FWIW, small = 8 oz, large = 10 oz.
2. These reset instructions from another site seemed to do something
What to Do If Your Keurig Won Brew Cup Barista
So.. this is what I did that worked for mine: 1) Hold down Auto-Off and LARGE cup at same time. (all lights should hold steady ON) 2) press SMALL cup while still holding Auto-Off and LARGE cup 3) Release all three, press LARGE cup again.. all lights should go off. 4) Unplug for about 5 - 10 second, plug back in. SHOULD WORK!
3. On *_my_* B40, remove the K-cup, close the door, fill the reservoir. Unplug and replug the B40. All lights should be off.
Pressing "Auto Off" and "Large Cup" together will turn on 3 lights (Heating, Add Water, Power) for about 3 seconds. Doesn't matter how long the buttons are pressed or what order they are released.
I tried lots of add-on combinations: e.g. press button x, press x multiple times, press x while lights are still on, press x after lights are off, press buttons x and y together, press x then y, press x and/or y while still holding Auto and Large, release Auto but not Large and press x, etc.
Nothing gave any confirmation that a reset was accepted. All lights always turned off after 3 seconds. Maybe Reset is only 1 step, i.e. Auto+Large together?
Jan 04, 2013 | Keurig Elite B40 Coffee Maker
All lights flashing on b40 keurig
My Bro didn't reset like above answers. Mine I have to press the large cup, small cup, and auto off at the same time, then release small cup and press it three times and bam it works now :)
Jul 21, 2012 | Keurig Elite B40 Coffee Maker
When we push the option Large Coffee instead of giving us a large cup it gives us a small cup and strong. We push the small coffee and also get a small cup. What can we do to fix it?
HI
It needs to be reprogramed. If some one holds a coffee button down to long it will reset itself back to small coffee.
Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button.
If that doesn't fix it, then you might need a new flow meter.
Jan 13, 2011 | Saeco Vienna Digital Coffee Maker,...
I press the large cup but it brews a small cup. What should I do to fix this?
I have have the same problem first thing in the morning. My first cup, I press large but with no K-cup; it comes out small or medium. I put the water aside (pour it back into the reservoir after it cools.) Then I brew a large cup using a K-cup, and it comes out the right size. I still want to know how to fix the problem, but at least this works for now.
Aug 11, 2010 | Keurig B60 Coffee Maker
Nespresso Romeo E350 Espresso Machine Logo
119 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
