Question about Sony PSP (Piano Black)
Cannot play games of the umd or memory stick
Games on the umd and memory stick will not play. after pressing the enter button the screen goes blank for a while and then get a message the game could not be started
    Problem Solver:
  • 14 Answers
You are trying to play backed up games which are only playable on a softmodded psp. Sorry, but they will not work on a non-modded psp.
Posted on Apr 25, 2009
When I switch on my PSP, it directly goes onto load the UMD game and when I try to quit using HOME button, the buttons and consoles dont work. Then I need to use the hold button after which though the...
Hi. Since you're in UMD Autoload mode, you need to configure that in the PSP Settings. To do this, turn off your PSP and remove your UMD. Now, turn it back on and it won't autoload your UMD since it wasn't there anymore.
Now, go to "Settings" and scroll down to "System Settings" and press X. Scroll down again the selection until you see "UMD Auto-Start" and press X. At the right side will appear the options "ON" and "OFF". Select "OFF" and press O button several times to go back to main screen.
Insert your UMD. Now, try playing games from Memory Stick. You may have to turn off your PSP and turn it on again to finally play homebrew...
I hope this helps...
Jun 07, 2011 | Sony PlayStation Portable (PSP) Console
My psp works really good but when i try to play games or movies it starts to slow down and flicker
1. Set “UMD Mode” to M33 driver NO UMD
The PSP firmware version was 3.71 M33 but is also tested with higher versions like 3.8 M33. These firmware versions should have the UMD mode to M33 NO UMD.
To set the following you need to go to the Configuration Page. To go there you need to:
i. Turn off your PSP
ii. Press and hold the R button. While doing that slide and hold the power button up. This would turn on your PSP. You should hold until the black screen appears saying “M33 Recovery Menu Configuration”
iii. If the PSP just turns on to the normal menu, just repeat the two steps above.
2. Set “Use VshMenu” to Disabled.
It is also in the configuration page. Use the steps above and you should be able to find it.
Now after these two steps, if you continue no further, your PS would run faster – but only for the menu screen. The menu would be fast and really responsive. However, try playing a game. You would notice that loading is still slow and the gameplay is still played in slow motion
3. Set the CPU speed to Default.
Now this is really important. The CPU may not really be used when playing music or in the menu screen but its very important when you play games.
There are two settings you need to adjust. Speed in XMB and Speed in UMD/ISO. For us normal users we just need to set these two to “Default”.
After this, your PSP should be running ok. However, I recommend that you do another step which would also help the performance of your PSP.
4. Free up memory from your Memory Stick.
You can do this using two methods. One, you could connect your PSP to your PC using a USB cable. Two, you could remove your memory stick and use a card reader. I prefer the second method but you may use any of the two.
Method Two: Remove your memory stick and use a card reader.
Freeing up memory is easy, if you know what files to remove. As my friend is not really using her PSP for music and videos, majority of her files are game files. What she does is that she just puts games that she really plays. I recommend doing the same for your PSP.
Game files are located at the folder named “ISO”. The game files have a .CSO file name extension. You don’t need to delete them. Just transfer them to your hard disk. That way, when you want to play them again, you just have to transfer them back to your memory stick.
But if you have music and video files that take up much space, I recommend that you look into those first. Normally you would like to have at least 500MB of free disk space. You’d need the space for your game saves.
My friends have done the steps above with ease and have solved their slow PSP problems. Most of them, if not all, had to do all four mentioned above. The first three usually solves the problem.
Mar 07, 2010 | Sony PlayStation Portable (PSP) Console
I can't get Valhalla Knights 2 to load on my psp
Update the system,....Alot of UMD games hang when they try to updeate from disc..If you download the update via internet and install it from the memory stick duo you should have no problem playing your game, the system will see that the firmware is up to par for the umd and will not do the system check so no lag time with loads...good luck hope this helps
Oct 11, 2009 | Marvelous Interactive Valhalla Knights for...
How do you copy games onto your memory stick on a sony psp piano black?
If you have custom firmware installed you can download umd dumper: http://www.psp-hacks.com/file/38.Just put the umddump and the umddump% in PSP,GAME and then put the umd you want to copy on your psp and on your psp go to game, memory stick and click x on umd dumper.Then when its done coping go to game, memory stick and there should be the game of the umd and you dont have to had the umd to play the game.
Mar 21, 2009 | Sony PSP (Piano Black)
I just purchased a sony used psp for my grandson.
Follow the directive below to;
Step 1. Put on your PSP and use the arrow keys to go to "Saved Data Utility". Scroll down to "Memory Stick" and press the O button to get into the games stored in your memory stick.
This would enable you play your games on your memory stick, but if you are still not able to do that then get a UMD to play games or verify the version of your PSP.
You can only play the games in the memory stick after the PSP has been hacked.
Regards
Mar 16, 2009 | Sony PSP (Piano Black)
PSP will not play games
What do you mean?
UMDs or Games saved in the Memory Stick?
If UMDs, your UMDs are scratched or the PSPs UMD Reader is damaged.
Games in Memory Stick, I don't know....
But if you play games and the PSP automatically enters the Home button, it's a virus. Fix it or Back up your PSP Files, and Reformat the Stick...
Apr 19, 2008 | Video Game Consoles & Games
PSP SCREEN FLICKERS AND GOES SLOW IN MAIN MENU
Ok...this sounds crazy but it happened to one of my PSPs. I updated the firmware on my system and the menu started stalling and taking a long time to respond. I shut the PSP all the way down....holding the power button until the light shuts off (about 4 or 5 seconds)...Hold the R button and power the system on again (you should be in recovery mode)...go to CPU speed and make sure it is either set at "Default" or "222"....I belive 222 is the default setting....also make sure the UMD is also set at "Default" or 222....if you're going to use the UMD.
Feb 06, 2008 | Sony PlayStation Portable (PSP) Console
Psp not working
This problem occurs when there is some problem with the firmware, it can be happen If you turn off the system or remove the memory stick during an update. If an update is cancelled before completion, the system software may become damaged. if so, you''ll have psp with blank on screen. try remove all plugin MS, Umd, etc, then press bright button of psp. if isn't work you need pandora battery to downgrading your firmware. hope this help.
Oct 29, 2007 | Sony PlayStation Portable (PSP) Console
Psp not saving or loading
Hi Spazza2,
Did yout try using the same UMD game your brother was using and see if the game format has anything to do with it?  Since you upgraded, the UMD game may be old, and might not work with Version 3.71. It sounds like your PSP is working just  fine other than that.
Oct 22, 2007 | Sony PlayStation Portable (PSP) Console
Sony PSP (Piano Black) Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
