Question about Coleman Pressure Washer PW0881800
The hose is leaking and I need another bottle that is Attached to the system.Model # 1210 Coleman Pressure Washer , it is an electric one. ''Clean Machine''
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: I have a Coleman #1210 Clean Machine AND need a
Hi Lance and welcome to FixYa. I am Kelly.
Most of the Coleman pressure washer parts can be found here:
http://www.arkansas-ope.com/Coleman_PW_Parts.html
I do believe the nozzles and wand your looking for are on the linked page above.
If the link is not to your satisfaction I can find a few more sites with Coleman Parts. Just respond here and I will dig again. The link provided just happens to be the most reliable.
Here is the number for Coleman so you can call them directly to get what you need:
1-800-445-1805
1-308-237-2181
Fax 1-308-234-4187
Thanks for choosing FixYa,
Kelly
Posted on Jan 26, 2011
Where does the detergent bottle go
It goes onto the wand itself. With the Pressure Washer off: If you have the wand unattached from the hose it works easier. Then separate the WAND into two pieces at the big joint in the center. Insert the bottle into the joint on the opposite end of the section that will be attached to the hose, (once you have the wand in two pieces you will see the same types of connections that are on the bottle.) then attach the other end of the wand to the bottle. Now reattach the wand to the hose.
Dec 03, 2014 | Campbell Hausfeld PW1750 Electric Pressure...
How to repair non-functioning detergent bottle
Are you really sure it's not working? Most of these only dispense detergent when the lowest pressure spray head is attached. If that's not the problem then the next most likely thing to check for is a blockage in the tubing that connects your detergent bottle to the main unit. If this was not fully rinsed out after the last time it was used, any residual detergent remaining in the line will often solidify which results in blocking the line. Good luck
Nov 10, 2014 | Greenworks 1700 PSI 1.4 GPM Electric...
you may have a strainer in the wand simply unscrew the wand and look for the clogged strainer it protects the nozzle from getting any dirt
Jul 30, 2013 | Garden
I have a Coleman #1210 Clean Machine AND need a Flat spray nozel.\r\n Lance lanceanderson12@earthlink.net
1-800-445-1805
1-308-237-2181
Fax 1-308-234-4187
Kelly
Jan 26, 2011 | Coleman Garden
I have a Coleman 2750 power washer that just idels when you pull the handle. Why is it not reving up with pressure?
Possibly has leaking seals or there is a blockage in the gun or hose. remove the hose first and see if it is putting out enough water.
Jul 31, 2009 | Coleman Pressure Washer PW0881800
Keeps filling with water
The water level in a washing machine is determined by the pressure switch. The switch is located behind the load selector, water level, load size (has various names depending on model and manufacturer) knob on the operator console. If the switch malfunctions, the water will not shut off and the washer will overflow.
Now...before assuming the switch is defective, a common problem that occurs is the small air hose on the pressure switch coming loose or leaking. This air hose attaches from the wash tub to the pressure switch. The pressure swtich senses the change in air pressure as the tub fills and shuts the water off at the selected level. The following link explains:
http://www.fixya.com/support/r762094-washer_overflows
To access your pressure switch, unplug the washer and open the operator console. Look for a clear plastic hose. If it is NOT attached, you may have found your problem. Reconnect and test operate.
If it IS attached, check the entire length of the hose all the way to the wash tub for any cracks of leaks. In addition, remove the electrical connection(s) and check for corrosion. Clean if necessary.
If all these preliminary steps don't solve your problem, replace your pressure switch. Read through the link I provided and let me know if you have any questions. I hope you find this information helpful.
Jun 12, 2009 | GE WJSE4150B Top Load Washer
Washer tub overflows and wont stop
Jun 10, 2009 | GE WBSR3140DW Top Load Washer
No propane flow to grill using bulk bottle system.
the office that is open on the bottom of the burner sound like a spider has taken home to.. the hole.... This happened to mine. a small pipe cleaner or wire will break it up...try that. also did you feel the top of the tank regulator and see if it has froze. try turning the tank upside down and turn the unit on.... this may also help by forcing the spider debris out.
Jun 05, 2009 | Coleman Roadtrip Grill LXE 9949-750
Coleman 1210 power washer no water comes out of gun
I've never used it before what plugs in where, the 1210 powermate, Pictures would help
Jun 01, 2009 | Coleman Pressure Washer PW0881800
Need instruction book for coleman powermate clean 1500
The hose connection I believe is for hooking a hose up and running it into a bottle of cleaner. The cleaner is mixed with the water when it is sprayed, The knob on the bottom adjusts the strenght of the solution. Most washers have the same setup.
Apr 09, 2009 | Garden
Coleman Pressure Washer PW0881800 Logo
174 people viewed this question
Top Coleman Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Simon Flummox
Simon Flummox
Are you a Coleman Garden Expert? Answer questions, earn points and help others
