Zebra Eltron TLP 2844 Thermal Label Printer
Problem for Zebra Eltron TLP 2844 Thermal Label Printer
TLP 2844 GAP sensor problem (I guess)
By szhu on Apr 22, 2009
My printer TLP 2844 print with wrong label offset, and every printed label  green button turn to red.
I try calibrate it, but it print only a row of printer information and green button turn red, after press it, the printer print another row of information and turn green button to red..
Zhu
Solution #1
posted on Aug 17, 2009
Not Rated)
samdeovels
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem. I found out later there was a small piece of label sticking against the sensor, thus blocking the sensor from sensing the end of the label. As soon as I removed the label (open the cover, it is on the top part) it immediately started to work as usual. Hope this helps.
Was this helpful?
Yes
No
Popular Solutions for Zebra Eltron TLP 2844 Thermal
Questions and Unsolved Problems for Zebra Eltron TLP 2844 Thermal
Do you recommend Zebra Eltron TLP 2844 Thermal Label Printer?
Answer
Answer
what is the solution for epson SX 600 FW getting fax print but after that it prompts for error as... (More)
Answer
My printer changes his font size.How can i change it to default?
Answer
I am not able to print properly jewellery label (tag) in zebra tlp2844. there are 2 tags in each... (More)
Answer
I use it to print small jewelery tags. It prints the vertical 90o bar codes fine but when I try to... (More)
Answer
how to configure eltron 2844 thermal printer for usps label use
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Zebra Eltron TLP 2844 Thermal...:
Top Printer Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
