Question about Zelco (1410580) Air Purifier
How much ozone does this produce.
Most devices (like the Zelco Air Purifier) are rated for different ozone levels. Does this device put off too much ozone?
  • 363 Answers
The Food and Drug Administration requires the ozone that is given off by medical devices that are used indoors to be no more than 0.05 ppm. If you have a manual, does it specify the amount of ozone given off? I'd be interested in the figure.
Posted on Sep 24, 2007
SOURCE:
How do I read the graduations on the purifier control & what do the 1 or 2 red plate settings tell me?
The graduations are incremental for your ozone output for the purifier control. Generally, the machine can put out enough ozone to cover 3000 sq ft. (when the control is moved all the way to the right, about 5 o'clock.) Half way should be about 1500 sq ft or 12 o'clock. For general air cleansing, you should set the purifier control to produce enough ozone so you smell it when walking into the room (after home) for about 30 seconds. The ozone smell should disappear after that. If it lingers, you've got it set too high. For more severe odor control you can set it higher but remember that some of us are more sensitive to the odor no matter what the setting. It may need some adjustment based on your individual preferences.
I'm confused about the 'red plates' as you mentioned. The original machine comes w/ 2 ozone plates (made of glass) and doesn't produce ozone when one of the plates is removed. I'm guessing that the lines may tell you when you're engaging both plates to work, i.e. more ozone being produced & blown into the room or less only calling on one plate to produce ozone. If you send me a close up pic of the control panel I may be able to tell you more.
Feb 24, 2014 | Alpine Air XL-15 Air Purifier
I was considering Biozone for restrooms etc and I assumed,as your info.says that it would be odour free?Some I have seen are not odour free.Is it just a uv lamp system or is there some form of ozone...
the UV lamp does produce some ozone .. this one specifies .04 ppm .. thats not very much but might be detectable as a slight fresh air odor .. some other types use electrostatic filtering and some even have strong ozone generators .. ozone does kill bacteria, fungus and such and will freshen the air removing many odors but is not considered healthy in large or concentrated amounts or for prolonged periods .. the UV lamp will also kill bacteria and fungus without producing so much ozone.
Purifying Method: Photoplasma, UV, ions, and ozone.
Oct 09, 2010 | Biozone 500 Air Purifier
I need an ionization wire for my ioninc breeze quadra air purifier where can I find one?
Any system using electric currents are deadly OZONE producers if your ozone producing machine is broken pleas don't fix it replace it look for any system with a filter not a electric current burning all the dust
Jun 28, 2010 | Sharper Image Ionic Breeze GP SI720 Air...
No ozone smell
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
May 19, 2010 | Ecoquest Flair Air Purifier
Ozone not working
Mar 24, 2010 | Ecoquest Fresh Air Air Purifier
Ecoquest fresh air
Yes it will. But do not run it on ozone mode while you or pets are present.
Mar 05, 2010 | Ecoquest Fresh Air Air Purifier
Xl-115 Automatic setting not working?
your sensor board has failed , a realy common problem , most if not all are dead and no parts are made for it ...... you do not need the sensor anyway it was only installed as a knee **** reaction to fda worrys of ozone levels over 0.05 ppm in bedrooms . so the board was installed to cut at 0.05 ...... it was a failure , so a bypass switch was added to get around the problem board ... just set on man , adjust for your sq ft ... you will be fine
Sep 08, 2009 | Ecoquest Living Air Classic Air Purifier
THE WET DOG SMELL
try soaking the grid plate in ammonia
Jan 11, 2009 | Ecoquest Flair Air Purifier
No Ozone
Mine has a switch lower right hand side that will stop the ozone.
Aug 31, 2008 | Ecoquest Living Air Classic Air Purifier
Zelco (1410580) Air Purifier Logo
289 people viewed this question
Top Zelco Air Purifiers Experts
Marvin
Marvin
Michael Youngman
Michael Youngman
Are you a Zelco Air Purifier Expert? Answer questions, earn points and help others
