Question about RTO Pit Bikes
Atomic 125cc pit bike oil screen?
I am trying to find the oil filter on my atomic 125cc.
Its a ducar motor.
i have taken the clutch cover off and it appears i may have to remove the clutch to get to it? Is that correct?
    Problem Solver:
  • 9 Answers
The oil filter is above the oil plug, you have to remove the clutch cover etc.. its just a piece of fine wire mesh
Posted on Oct 03, 2009
Hi i have a 4stroke 125cc pit bike it wont start tried bump start sorted turned over but when i reved it didnt respond then died any ideas
Tryd go to auto shop and check the carburator of your motor and clean your air filter adjust air setting in carburator and put a new fuel pump check fuel setting in carburator
Jan 18, 2014 | Motorcycles
Stomp 125 will not start
Hi, Jack the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
stomp 125 clutch wont engage new clutch all think Pit Bike Club
Clutch Adjusting
Pit bike Direct User Manuals
http://mypitbike.ru/downloads/ThumpstarServiceManual.pdf
http://www.wpbracing.co.uk/engine-parts
Oct 09, 2017 | Pit Bike 125cc 4 Stroke Dirt Bike
Pit bike starts, idle and revs good. But when I put it in any gear it cuts out. No electric starter, battery or kick stand switch!!? Help please?
does this happen as soon as you put it into gear or does it do it when you let the clutch out,as this sounds like the clutch plates are stuck together,you need to drain the oil then take the clutch cable off ,then take the clutch cover off remove the bolts and springs from the clucth basket make sure you do this evenly,then you take the clutch plates out if they all come out together then there locked up pry them apart and see if there is blueing of the steel plates and check the fibre plate for wear or cracks ,if the plates are bluing you may need to renew all of the steel and friction as this may have been caused by slipping the clutch or not having the clutch adjusted right and you may need a different type of oil that is suited to wet clutches.hopefully it could be just a matter of it sitting too long without being used.cheers hopes this helps
Sep 18, 2013 | Pit Bike 125cc 4 Stroke Dirt Bike
125cc pit pro, pit bike Kick start lever jammed
remove the cover that houses the kick starter and look for a failed return spring or some other reason that keeps the kick start dog engaged.
Jun 03, 2013 | Pit Bike 125cc 4 Stroke Dirt Bike
Dirt bike cuts out on second gear "!!
make sure it has oil, low oil can cause overheating and thermal cutout
Apr 29, 2013 | Pit Bike 125cc 4 Stroke Dirt Bike
Atomik Pit Bike
After hunting around the web for a few, it sounds like the spring is from the timing chain tensioner. It looks like there is a button on the end of the cylinder, that end goes in first, then the spring. See if the spring is the same on both ends, the picture looks like it's smaller at one end and that end goes into the tensioner, not the bolt. I'll include a screen shot of the picture.
Nov 26, 2011 | Pit Bike 125cc 4 Stroke Dirt Bike
When i hold the clutch in on my 125cc xsport pitbike there is a rattling noise in the engine like a ballbaring rolling round. help!
If it sounds like there's a ball bearing rattling around in your engine there probably is... take off the side cover and investigate it can't get any worse...if you keep riding it it'll only go bang and wreck the whole engine
Dec 16, 2010 | Pit Bike 125cc 4 Stroke Dirt Bike
RTO Pit Bikes Logo
1,086 people viewed this question
Top RTO Toys Experts
The Scrivener
Pete Bruk
rostit
Are you a RTO Toy Expert? Answer questions, earn points and help others
