Question about Acer Aspire 5500 5570-2609 Laptop
Bluetooth in acer aspire 5020
When I click on my bluetooth-button a green text appears on the screen saying "No Device". How can I fix it ?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 40 Answers
This is due to driver misssing you have to reinstall driver properly
steps for doing so.
  1. shut down your system
  2. turn on your system.
  3. switch on the button of blue tooth device
  4. now install the driver from the cd provided to you by acer.
restart you system.
this will solve your problem.
Posted on Apr 22, 2009
I am using xperia X10...and i want to connect to my HBH-GV435 bluetooth to this phone..but the HBH-GV435 blue tooth is already paired with some other phone.so i want to reset the bluetooth and connect it...
Headset-
1. Make sure the headset is fully charged, turned off and within 1 m (3 ft) of the phone.
2. Press and hold the On/Off button for at least five seconds, until you hear a long high-pitched beep and the light flashes red and green. The headset is now in pairing mode.
3. If your phone supports auto pairing, press "Yes" when the question Add device? appears in your phone. If it doesn't, continue with the next step.
4. Prepare your phone in accordance with the phone instructions for adding a Bluetooth device. Please note that for some phones you may need to enter a passcode. The headset passcode is 0000.
X10-
1. From the Home screen, tap the applications bar.
2. Tap Settings > Wireless controls > Bluetooth settings.
3. Mark the Bluetooth check box.
4. The phone starts to search for the device. Make sure that the device is in pairing mode. If needed, tap Scan for devices.
5. When the device becomes visible in the Bluetooth devices found list, tap to select it.
6. If needed, tap the text bar to enter the passcode (0000 by default) and tap OK.
7. You can now start using the paired Bluetooth device. The status of the pairing and connection is shown below the name of the Bluetooth device in the Bluetooth devices list.
Good Luck!
Mar 23, 2011 | Sony Ericsson HBH-GV435 Bluetooth Headset...
Garmin Nuvi 650
1. Browse here and install the latest version of WebUpdater:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
2. Turn on your Nuvi, press view map, press speed, press and hold the middle of the speedometer (the circle that says 0.0mph in it). After five seconds (maybe a bit longer), the engineering menu will appear.
3. Press "Next" five times (once for each page). You will arrive at the "Bluetooth Status" page.
4. Press "Clear". Confirm by pressing "yes".
5. Press "Updt PR". Confirm by pressing "yes".
6. This probably did _nothing_ for you, but to be thorough, I've included the steps.
7. Connect the Nuvi to your computer. Run the webupdater and if the latest version is already detected on your Nuvi, simply proceed and browse the list of further updates.
8. If "Bluetooth Firmware Update..." (or similar text) DOES NOT APPEAR skip to step 10 below, otherwise complete your fix with the next step, step 9.
9. If the "Bluetooth Firmware Update..." (or similar text) appears in your list, select this update and agree to term of service, and have the updater load the firmware onto your device. Unplug your device. It should powerup automatically. Power off. Power back on. Your BT should be back in business. Do NOT continue with the next steps. You are done.
10. If "Bluetooth Firmware Update..." (or similar text) DOES NOT APPEAR in the list, then you need to remove the offending update that is making WebUpdater believe that your Nuvi is up-to-date.
11. You can access the Nuvi by clicking on "My Computer" and double clicking the Nuvi link.
12. Click the "Garmin" folder.
13. Click the "RemoteSW" folder.
14. DELETE "006B055301.GCD". This file will be one of two GCD files in the directory: <DRIVE>:\Garmin\RemoteSW. The file without the "Date Modified" is the original firmware. The other file is the new firmware that the Nuvi believes is installed. By deleting the newer of the two files, WebUpdater will see that your Nuvi is out-of-date. Return to step 8 to continue your fix.
This should resolve all permutations of this nasty bug.
Feb 26, 2008 | Garmin GPSMAP 60CSx
Tip
How to turn Bluetooth on and off on a BlackBerry Tour
The BlackBerry Tour comes with Bluetooth capability, but in order to connect to a Bluetooth device, you have to enable the Bluetooth functionality. When you're not using a Bluetooth connection, disable Bluetooth to avoid other devices from connecting to your BlackBerry.
- To turn Bluetooth on:
From the main home screen, press the BlackBerry button (to the left of the trackball) to go to your Home folder. Scroll down until you see the antenna icon for Manage Connections and click on it. A pop up list will appear; find Bluetooth on the list and click it to put a check in the box next to it. "On" will appear next to Bluetooth, and the Bluetooth icon will be displayed in the upper right corner of the screen. Your BlackBerry is now in Bluetooth mode, where it can connect and pair with other Bluetooth-capable devices.
Bluetooth can also be turned on from the Options folder, under the Home folder. Select Bluetooth from the list and when the screen comes up saying "Bluetooth: Disabled," press the BlackBerry button and then select Enable Bluetooth. If you've previously paired your Tour with other Bluetooth devices, the list of those devices will appear.
- To turn Bluetooth off:
From the home screen, press the BlackBerry button. Scroll down to Manage Connections and select it. In the list that appears, click Bluetooth to uncheck it and disable Bluetooth functionality.
You can also turn Bluetooth off by clicking Options in the Home folder, selecting Bluetooth from the list of options, then pressing the BlackBerry button and choosing Disable Bluetooth.
on Jan 14, 2011 | RIM BlackBerry? Tour 9630 Smartphone
Tip
How to turn Bluetooth on and off on a Samsung Intensity
Like many other cell phones, the Samsung Intensity (SCH U450) is Bluetooth-capable. Turning Bluetooth on and off on the Intensity is easy to do, as is configuring the phone's various Bluetooth options and setting up new connections.
To turn Bluetooth on, press the Menu button (the round button in the upper center of the numeric keypad). On the main menu screen, select the Settings & Tools submenu in the lower right hand corner. Then scroll down to item #3 (Bluetooth Menu) and select it.
If Bluetooth is currently disabled, the option in the lower left corner of the screen will say "Turn On." Press the left option button to turn Bluetooth on; you'll see a box pop up that says "Bluetooth power on." Now you can pair your phone with other Bluetooth devices, either by initiating a connection (choose Add New Device from the Bluetooth menu, or if you've paired with the device before, select it from the list of devices) or by making your phone discoverable (click the right option button, select Discovery Mode, and turn it on).
To disable Bluetooth, go back into the Bluetooth menu and just hit the left option button ("Turn Off"). A box will appear that says "Bluetooth power off."
If you're not sure if Bluetooth is on or off at any given time, just look at the status bar at the top of your Intensity's main screen. If you see the Bluetooth icon -- a sharply-angled white "B" on the blue background -- then Bluetooth is currently enabled.
on Oct 16, 2010 | Samsung SCH-U450 Cell Phone
How do I bluetooth pair my i9 phone with my Ford SYNC
On your Ford Sync board, press the phone button. It will start to search for already paired devices. If none is found, press the arrow buttons until you find 'Add Bluetooth Device'. Then, press OK. You'll see it will generante a PIN. Now, make your phone's bluetooth application look for new devices. After a while, the Ford Sync device will appear on the phone screen. Select it, and make the the bluetooth application proceed. When a PIN (or pairing code, or passkey) is requested, enter the PIN generated by the Ford Sync device.
Hope it works for you.
Regards, Carlos
May 20, 2010 | Cell Phones
What is the pairng code for mouse 5000 ?
  1. Windows XP
  2. Click Start, and then click Run.
  3. Copy and then paste (or type) the following command in the Open box, and then press ENTER: services.msc
  4. Double-click the Bluetooth Support service.
  5. If the Bluetooth Support service is stopped, click Start.
  6. On the Startup type list, click Automatic.
  7. Click the Log On tab.
  8. Click Local System account.
  9. Click OK.
  10. If you prompted to restart the computer, click Yes.
How to connect the Bluetooth device to the computer loadTOCNode(3, 'moreinformation');
  1. Press and hold the Connect button on the bottom of the mouse. If your device has a battery indication light, it will blink and alternate between red and green to indicate that the device is discoverable.
  2. On the computer, open the Bluetooth software. The Bluetooth software is typically located in Control Panel. For more information about opening the Bluetooth software, see the "How to open the Bluetooth software" section.
  3. Click the Devices tab, and then click Add.
  4. Follow the instructions that appear on the screen.
    A Microsoft Bluetooth mouse does not require a passkey to connect to the computer. If you are prompted for a passkey, select No passkey. If you do not get the No Passkey option, try to enter 0000 as a passkey by using your keyboard.
Apr 20, 2010 | Microsoft Bluetooth 5000 Mouse
Blinking red and green
Oct 28, 2009 | Microsoft Bluetooth 5000 Mouse
My bluetooth is not working on my acer aspire 5738
this problem is due to the improper driver for bluetooth module in your laptop . pls install proper driver and software .your problem will be solved .
thanks
Aug 26, 2009 | Acer Aspire 5720-6661 Notebook PC
Do i have bluetooth?
Well the Acer site says that it has built-in bluetooth!(Aspire 1690) If you go to device manager (Right click on my computer, click on manage. Under System Tools in the left pane click on device manager) you should see one of the device categories there as Bluetooth, if you don't see it and see a yellow icon that means you might need to install the bluetooth drivers! If you don't either you might need another component(bluetooth hardware) for the bluetooth to work! hope this was helpful regards, babb
May 03, 2007 | Acer Aspire 1690 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
448 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
