Question about Protron PLTV3250 32 in. LCD Television
Dig sig hey folks...bought a pltv3250 about 4 months ago. The cable guy said that I have a digital signal when he set me up...but when we hooked up the cable to the 'digital ant' input it could not find any digitals channels.It only works when I hook it to analog ant.The cable guy said that it should work. Am I missing something in the instructions? thanks,paul
It only has an ATSC tuner, and no clear-QAMuning options
Posted on Oct 09, 2007
Hi, I have a sony bravia tv ( klv20G300A) which was bought in Hong Kong about3 years ago . I haven't been able to get it to work with the uk digital signal. I am wondering about it's compatibility-...
This tv has analog tuner and you need digital tuner in tv to get digital signal in UK, alternate way is to hook cable box with this tv that will convert digital signal into AV output that will connect to AV input of tv to get cable channels.
Aug 03, 2011 | Sony BRAVIA KLV20G300 20 in. EDTV-Ready...
Rca 20F514TD blue screen
What to do if you have an all snowy picture (blue screen or the TV displays unusable signal-no signal or no sync)
1 – If you are using a digital cable box or satellite receiver (make sure it’s on) and be sure your TV is set for either CH3 or CH4 (which ever you usually view it on). If you usually view it through video inputs (video1 or 2 etc.) make sure the appropriate input is selected.
If you still don’t get a signal see if you get picture using the DVD or VCR (if available) if you do than plug the satellite or Dig. Box temporarily into the place of the DVD (unplug DVD) you may have to use some A/V cables (RCA yel./red/wht like the ones on the DVD) to hook to the tv from the sat./dig. box. If you get a signal then the sat./dig box is ok. If not the Sat./dig box is not sending a signal and is either defective or needs to be rebooted (unplug wait 5 min try again).
2 – If you are using standard cable or antenna (source) if possible check that the source is good by connecting to another TV. Otherwise try running the source into a VCR and then out to the TV using video inputs (RCA yel./red/wht like the ones on the DVD) and then selecting the appropriate input. Try seeing if the VCR plays using standard CH3 (or CH4)
If the VCR plays on video input but not when connected to CH3 (CH4) then the tuner of the TV may be defective – see if you can use the VCR to change channel using the VCR remote.
Be sure to vote/rate me if this helped Thanks!
Nov 05, 2009 | RCA 20F514TD 20" TV
Blue screen. No audio or video through the cable hook up. RCA model #32V420T
Oct 25, 2009 | RCA 27F534T TV
My marantz DV 9500 doesnt output digital signal for audio cd anymore but outputs audio for dvd,sacd,dvd audio. Does it need servicing
Make sure your playing componet like CD player have a digital output socket. Connect this to a digital port on the amp witk a single RCA or Optical cable if output available on CD. Make sure the digital assingment in amp is set for cd function and corresponding input(example cd plyer connected on dig 4 input on amp, press menu, setup, assignment, go to cd player, make sure setting on dig 4 or change input to dig 4, go to next component to memorise setting.and exit, see manual to assist you) if still no sound take dvd cable for instance that is working and put that in dig 4 port. if that works check in cd player that settings spdif/raw/pcm is correct one for yor digital output if still no sound soun pc board faulty.
Aug 11, 2009 | Marantz DV-9500 DVD Player
Cable won't work on new tv
When I plug in all of the cables the tv says no signal. I have tried it on all different input settings and my cable provider tried sending me a stronger signal. Could I be doing something wrong and is there anything else I can try?On the back the tv has no receptor what else is there i can use?
Aug 03, 2009 | Insignia Televison & Video
PS3 not working on reg tv's after HDMI use on LCD HD tv
Shelley,  the fix for this is simple! Hold down the power button for about 5 seconds and the system will beep. This resets the video setting for your ps3 from HD too whatever the current cables are that you are using too hook up too the tv. This works on my PS3 which I just bought about 3 months ago and should work with the older ones.
Jun 05, 2009 | LG 37LC2D Television
No dolby digital signal
Put your optical cables into the amp and not the tv,also make sure the ps3 audio is set to bitstream.
hope this helps.
CABLE GUY.
Jul 12, 2008 | Audio Players & Recorders
DVD Upconverters???
Greetings jhays82,
Some DVD players can upconvert DVD signals to resolutions that match those of HDTVs, and send them to a compatible TV via a digital video connection. HDMI (High-Definition Media Interface) and DVI (Digital Visual Interface) both offer high-quality digital transmission of standard- and high-definition video signals. HDMI can also carry multichannel audio, and is backwards compatible with DVI (video only). So in other words, to receive the full benefit from an upconvert, you would want to hook it up with HDMI or DVI.
Thank You,
Agent Dort,
Go Ahead. Use Us.
Apr 14, 2008 | Televison & Video
Line 3 dissapearance
in the manual does it describe how to reset to manufactory defaults and have you got your hook-up to your digi box via a fully wired scart if so this cable is causing double feed back wich means signal is senging info from dig box back to scramble setting use a one way signal scart to recorder this is the lead i use to eleminate settings from being scrambled and a clear signal from dig box this is also updates time automaticly when you get back to settings menu turn off auto clock set this will stop time from going on 1 hour hope this will help
Aug 10, 2007 | Sony (RDR-HX710) DVD±RW Dual Layer...
Protron PLTV3250 32 in. LCD Television Logo
98 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
