Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Programme stuck I can't change the programme for the top drawer of my DD603 - its on the rinse cycle and won't move to anything else. Can anyone help?
  • 144 Answers
Try swapping the motor controllers (computers) over between the two drawers to see if the fault moves while doing this give the touch buttons at clean. Any questions feel free to ask. Cheers
Posted on May 13, 2009
How do i repair fisher paykel dd603 problem top drawer stuck on fast cycle, bottom drawe stuck on normal cycle
you will need to replace both draws control boards, with the dd603 control boards they have a small touch button panel on the top of the board which they didn't put a protective layer or plastic over and basically what happens is steam gets on the copper tracking and corrodes it hence the fact it doesn't work anymore, all new control boards even the replacement for yours comes with a plastic strip over the board. hope this helped
Oct 06, 2014 | Fisher and Paykel Dishwashers
DD603 top draw cycle getting stuck on 73min??????
Normally if you started the rinse cycle with water already in the base of the dishwasher it will immediately go into circulating the water through the wash arms. Do you hear the wash arms running when the washer is stuck at 11mins? Also when the washer is stuck at 73 mins are the wash arms running all the time or do you hear the pump operate at some stage?
If you have the dishwasher manual available make sure the water pressure setting is at HI or LO depending on your rated mains water pressure.
Apr 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
DD-603 cycle and draining problems.
check your kitchen drain as it might be blocked or if you have a garbage disposal (kitchen insinkerator) make sure it is cleared before running the dishwasher.
Jul 18, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer DD603 won't drain. Filters all cleaned now but were very dirty when we took possession . Can;t find the drain hose to see if it is blocked or kinked. Any help please? zancol
After we removed the center blue rotor from ours we put about 4 inches of warm water in the dishwasher, then took our shop vac and vacuumed from the center hole where the rotor was and the suction cleaned out the passageway from the filter area to the rotor area. Then we ran it on the "rinse" cycle and it was running perfectly again. I hope this helps you.
Aug 04, 2011 | Fisher and Paykel 23 in. DS603H W Built-in...
I have a Fisher and Paykel 2-drawer dishwasher. The top drawer is stuck in the rinse cycle and I cannot change it to another cycle. Please advise.
Assuming the controller of the top drawer is still ok, take a clean damp cloth and wipe the top panel where the program keys are located.
If nothing happens, you will have to check if the controller connector is not loose. Take the front cover off and check the controller connectors.
Please rate this solution to help fixya serve you better in future.
Sep 16, 2010 | Fisher and Paykel 23 in. DD603H SS...
Appliance: Fisher&Paykel DD603 Draining
You may want to check up if the water collects in the bottom drawer when the top drawer is in wash cycle (ie, taking water from the inlet) or during the drain cycle when it is draining water out. Leave the bottom drawer open and check while the top drawer is running.
Jul 27, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a dish drawer DD603 purchased in 2005. It
I presume you have a double drawer model.
Does this problem occur with both drawers?
Jan 18, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Three cycles On
Take a clean damp cloth and wipe the touch swithes and the side and top edges of the dishwasher drawer.
please post a comment to report back if anything changed. Will try to solve it for you.
Jan 08, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
F&P double drawer (DD603) won't empty
Ok you need to remove the motor rotor it's under the spray arm and comes out like a light bulb from the top draw and check for anyting stuck under it or any damage done to it. Try swapping it with the one out of the bottome drawer and see if that works. When you first start the washer does it drain all the water?? if still no luck try swapping the motor contoller modules (computer board) from the top drawer to the bottom drawer and retry both drawers ,if the fault moves drawers with the part, then that part is faulty cheers
Mar 18, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher paykel DD603 top drawer starts cycle then stops and beeps and doesn't go thru cycle
When it stops and beeps can you tell me all lights that are on when you open the drawer cheers. also check to see if the water in the tub is hot if not you have a heating issue. either a faulty element or Mtr Controller module. try swapping the Mtr Controller module (computer board) from the top drawer to the bottom drawer and see if that moves the fault. cheers
Mar 07, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
363 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
