Question about Hoshizaki Commercial Freezer KM-500MAH
KM-500MAH won't go into harvest mode
I replaced the bin control switch as well as the fuse and the water is on but the machine will not go into harvest to begin making ice. I also cleaned the machine. What else should I check
  • 1 more comment
  • dinopantelid May 06, 2009
    My machine goes into defrost mode, and the lines freeze up - water stops getting pumped into the evaporator but the machine still continues its cycle, assuming water is coming through
  • Dennis Boxerman May 11, 2010
    dinopantelid
    Not real clear. You say the lines frost over during defrost? Are you sure it's not the freeze cycle? How long does the pump stop? A few seconds, minutes? Exactly what is your model number?
    The cycle should start with the water coming in. Then the compressor should start and the unit is in the defrost mode. It should then go into the freeze mode. Is yours staying in the defrost mode? Is water coming in?
    Let's see if we can get it going.
    Guru:
  • 1,524 Answers
The float switch controls the harvest cycle.
Posted on Jun 07, 2009
My hoshizaki ice machine KM-900mrf model beeps 3 times and stop making ice. After reset it starts, but stats beeping again after an hour.
Have a look at the side of the evaporator; there is a probe (thermistor) attached to it that tells the control board when to initiate the harvest cycle. make sure it's clean and attached properly and doesn't need replacing. If hitting the float switch initiates the harvest cycle it sounds like you have a blocked/ scaled water tube or switch housing. take off the bottom of the switch assembly (black rubber bit) and clean through to the water chamber. run a cycle of descaler before trying again.
Jul 04, 2015 | Hoshizaki Freezer Commercial Ice Machines...
The ice is freezing into a solid slab and will not drop into the bin
You might need to deep clean Your machine. Might be float switch clogged.
Jul 05, 2014 | Hoshizaki Commercial Freezer KM-500MAH
Ice machine keeps freezing on the ice trays
If you are referring to the ice not clearing the evaporator plates, usually the defrost cycle is too short. Check that by watching the machine and when it goes into the harvest mode, see if all the ice comes off. If not, lengthen the cycle.
May 15, 2014 | Hoshizaki Commercial Freezer KM-500MAH
No power to curcuit board
Check your "Bin Stat" first as most all machine have power sent to the control board via this control. Start there.
Apr 10, 2014 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki km-650 mah keep dumping water nothing at all running.
really sounds like the board needs replacing. after 1 minute, if the float is doing it's job, the compressor is to come on provided the water level is correct and the float is doing what it was designed to do.
Nov 30, 2012 | Hoshizaki Commercial Freezer KM-500MAH
KM-500MAH water keeps cycling thru when in ice making mode.
if this is a water cooled machine, the head pressure flow controller need to be replace/adjusted.
Jul 12, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice machine KM500-MAE not sending water to harvest
I would not change the pump. If it runs for 3-5 minutes and stops, it has to be a control. The control board runs the freeze cycle for the first 5 minutes. This prevent "Short Cycling" of the freeze cycle. The board looks at the float after the first 5 minutes for the proper water level but should not effect the pump. If the pump does not run in the wash mode, check out the "Power/ Wash" switch. I would start there before I go spending hundreds on pump motor or control board. You may be able to get by on a $20 fix! Do this and get back to me. We will get it going.
Good Luck
May 06, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Harvest cycle on ice machines
My ice machine Hoshizaki km-500 mah is cycling to fast. Causing poor production of ice it's real small and it doesn't produce enough ice aswell. Wha seems to be the problem.
Jun 20, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Machine takes long to harvest
how many beeps this is a code telling you the machine has a problem Also about 90% of Ice Machine problems are due to the unit not being cleaned. Let me know the # of beeps and I will let you know the problem from the manual
May 20, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki Ice Machine Model KM-500MAF
(Quated From Hoshizaki Technical Bulletin)
An alarm code of 3 beeps
every 3 seconds means that the control board has shut
down on the 60 minute freeze cycle back up timer.
The “E” control board has a 60 minute timer that starts at
the beginning of the freeze cycle. If the float switch fails
to open and start the next harvest within 60 minutes, the
board will automatically start the harvest cycle. If this
occurs in two consecutive cycles, the control board will
shut the unit down on the manual reset, freeze cycle
back- up timer. The yellow fault LED marked “60 min.”
will illuminate. This safety is designed to help prevent a
freeze up of the evaporator.
Once you have identified the 60 minute alarm, there are
several things to check. Reset the alarm by depressing
the white reset button to the right of the fault LED’s.
This must be done with the power “ON”. Now check the
float switch to see if it is stuck in the up position. A stuck
float can occur if scale is present on the reed switch
shaft inside the housing. To check it, drain the water
reservoir, unplug the black float switch connector (K5)
from the control board and check it with an ohm meter
for a closed switch (zero ohms). If the float switch is
sticking, clean it with ice machine cleaner or replace it as
necessary.
An inlet water valve which is slowly leaking by during the
freeze cycle can cause a 60 minute alarm. If the inlet
water valve is stuck wide open, it is unlikely that any ice
will form on the evaporator. Check for a slow leak by
allowing the unit to cycle into the freeze cycle and
disconnecting the hose at the outlet of the water valve. If
water leaks by during the freeze cycle, the water valve
diaphragm is likely damaged or the small diaphragm bleed
port is clogged with scale. Clean the bleed port or replace
the diaphragm or entire water valve as necessary.
(I Recommend to get a refrigeration tech for this part).
Another possibility is a refrigeration system problem. You
should use normal refrigeration diagnosis procedures to
check for one of these problems. If the thermostatic
expansion valve is not feeding properly or the refrigerant
charge is low, the evaporator will not form ice as it should
and a long freeze cycle will occur. This could also be the
result of the hot gas valve not closing completely during
the freeze cycle or if the compressor valves are weak or
inefficient. An inefficient compressor however, will
usually show up first on the KM model through a longer
than normal harvest cycle. This is because of cooler
than normal discharge gas. Use proper refrigeration
practices to repair a refrigeration system problem.
While these are not the only reasons for a 60 minute
freeze cycle, they are the most common and should be
checked to resolve a 3 beep/yellow fault LED alarm.
Feb 27, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki Commercial Freezer KM-500MAH Logo
437 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
