Question about GE Heating & Cooling
Mistakedly pluged in to 220v outlet, heard pop and now will not power up
  • 374 Answers
well,since there is an overload protection in your unit,we can't sure the most important parts of your has been affected,but if you have circuit breaker this might not be affected thats why we have the safety device.reset circuit breaker and also overload relay if there is,its like a lever to push it be sure to connect it acquired or exact volt rating eg. 110v.then switch on if still not run.we have to isolate check up mostly the important part.
but in this case this should be done by service a/c technician
they have to check the compressor and fan motor if has been affected on burning out.also the control board they have to check
the relay where the compressor get source to run.you can call up check the service manual your service center.if still under warranty
claim your warranty for lesser cost.have a nice day
Posted on Apr 22, 2009
I have a 440v 50 amp and a 220v 30amp main breaker box outside my house. the 440 goez to the inside of the house and i have to unplug the 440 and plug in myown 440 plug i connected to another breaker box...
Some of these numbers don't make sense?
I have Never heard of 440v and 220v in a residential application, they are two different systems, 480 volt is typically 3 phase power, and 240v is typically single phase, more in likely you have a 200- 400 amp main service, and a 100- 200 amp secondary service for the welder, that can't be 110 @ 200 amps?
I would need more info, and pictures of actual nameplates of the equipment,
and then I could advise a safe NEC electrical code answer...
Mar 17, 2015 | Electrical Supplies
DC9310 charger was pluged into a 220v by mistake. What fried and can I replace it?
Most likely all of the power control circuitry, charging circuitry, and voltage regulating circuitry. At this point, your best bet would be to look for a used one on line.
Sep 04, 2014 | Dewalt Dc9310 7.2 Volt To 18 Volt Nicd /...
I plugged my 120V Sony dvd p[layer into the 220V outlet. I didn't check it out. Anyway, I heard the fuse of the AVR popped and it turned off. I removed from the main outlet. I smelled it and touched it and...
you have just fried your power supply and it will need replacing, that doesnt mean that is all that will need replacing, depends on how well protected the main board is from the power circuit
Apr 03, 2011 | Televison & Video
I have both washer n dryer that are 220v 4 prong each but theres only one 220v 4 prong wall outlet. do they make splitters for this ?
I would say no. I have never heard of a 220V washing machine, as a washing machine has no need for 220V. In any case though you would need to get the appropriate wire, cord and outlet and install a separate circuit for the washing machine.
Nov 02, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Pops power supply fuse when I plug it in
Check to fuse box to see if the fuse is working properly. Next, see if the TV "pops" the power supply when pluged into a different outlet in a different power supply area. If the TV works without poping the fuse, the fuse with the original outlet needs replacing. If both outlets "pop", either the electrical system needs checking. Or if this is a new problem that started when you first tried the TV, the TV could be wanting more power than the electrical system will allow. Check the power requiremnets in the TV manual.
Jul 28, 2009 | Recoton Advent Advent TS2066A TV
Plugged my US made PC into a 220v outlet!
Hi
You need to change power supply unit. You can find a guide with screenshots here
May 03, 2009 | E-Machines eMachines Desktop PC
Plugged my computer into a 220 outlet!
You burned the Power supply you don't need to switch motherboard out just knew power supply. And in the future there is a switch located on the back of them that will make them a 220v powersupply. But usually only a high end PC for gamers will need that so just put in a new powersupply and you should be good
May 03, 2009 | Logitech R-20 Computer Speakers
I pluged my american stanton T60X (125V) to 225V. Any solution?
if you can find a fuse or reset switch, replace/reset that first. look around where the power cable enters the device.
if it has no fuse, you've probably cooked the transformer which converts outlet voltage (mains) to whatever the voltage the device is designed to run on. if that's the case, then you'll just need to swap in a transformer that matches the requirements of the deck to the output voltage of whatever country you want to use it in.
if this sounds too daunting and you're not confident with taking electrical stuff apart, go to a shop and get them to sort it for you.
long and short, don't ditch your deck just yet, Chet.
Apr 05, 2009 | Stanton ST-150 Turntable
Plugged in 220v by mistake
Did you check trafo? Do you get any power on secondary coil?
Oct 09, 2007 | Aiwa AV-X200
Plugged into 220V outlet by mistake! Help!
I don't know for sure, but I suspect that if you open it up, there should be a fuse near the power supply portion of the unit. It may have taken the hit for you and can perhaps be replaced easily. (As a disclaimer... be sure the unit is not plugged in when you open the case! And only replace the fuse with another of equal rating.) If it's not a fuse, then you probably smoked the primary winding of the transformer. If it got past that, you may have popped the rectifier and/or capacitor(s) in the power supply.
Oct 20, 2006 | Technics SA-DX930 Receiver
Heating & Cooling Logo
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
