Question about MSI KM4M-V Motherboard
Can´t find my SATA-disk....
Hello! Problem with motherboard MSI KM 4M-V, chipset KM400A 8237 I have an new SATA-II disk 500GB and it will not be reconized in BIOS.
Not either when I try to install Win-XP which have raid-drivers for the RAID included. I have tryed to press F6 under installation of XP, but then it say it alredy have an newer version of driver itselv, but then it cant find any media to install WP to.
I have the latest BIOS-version installed for the motherboard.
Any suggestions?
Excuse me for my bad english...
Per Berglund
Sweden
  • per_ber Apr 22, 2009
    The disk is a
    Western Digital Green Power 500 Gb SATA300, 7200 rmp, 16 Mb
    I can´t find anything about how to set it to SATA-1 on the label on the disk. Only how to set the jumpers for 1,5 GB PHY , how to enable SSC, and how to enable PUIS.
    I, m not so good at computers......
    Thanks to lexian_phoen !
    I,ve solved my problem with your tips. I set a clip on the disk between pin5 and 6 wich enable 1,5 GB PHY and it did it.
    Many thanks to you!!!
    Per Berglund
    Sweden
  • 73 Answers
I'm sorry to say buddy but I checked ... Then checked some more, and I can't see anything about your motherboard supporting SATA-II. If you look about you should find a jumper setting on your HDD to limit it to SATA-I, which is about half the speed of sata-ii but I'm almost promising it will work.
Let me know if this solves it, If not I can find the jumper settings for you, But seeing as though you just bought it you should have a manual.
Posted on Apr 22, 2009
  • Starfish Phoenix Apr 22, 2009
    No problems ... All works fine now I guess so if theres anything else I can do for you just gimme a shout :D
MSI 760Gm-p23 version 3 Fx Desktop athlon II 640 cpu ,deskstar 500 gig 7200 3.5" sata II 16 MB cache hdd, mushkin 8 gig pc3-10600 essential ram, LG L49-8020 oem sata dvd rom post no issue but wont boo
make sure that the cables are right and are good make sure that the power cables are in the dvd and hard drive two cables to each one for board and one to power supply each
Mar 06, 2013 | MSI 760Gm-p23 Fx Desktop Motherboard Amd...
Mother board masi km4am-l H.D.D. 1 TRA WES 64MB when installing win xp hard not detected by win setup. I updated bios but not worked. advance thanks
you should not update the bios...the issue is the hard disk is on sata ...and you need a raid driver installed to detect the hdd...so ...either get into BIOS and under advanced features..look the place where the drives are detected..and select the hdd and look for a feature called AHCI ..and disable it ..and leave sata like ide..and save with f10 and restart ...after that the hdd will be seen ..
another way is to make a floppy disk with the raid driver on it (the one from the mothermoard drivers disk ) ..and when it ask you to press f6 for 3rd party software ...press it ..and insert the floppy ...it will pick up the raid driver and will go like a charm ..
if you do not have a floppy ..install a second cd drive ..and use a cd ..and after pressing f6 for 3rd party ..browse and point to the raid driver on the mobo driver cd ..
Jul 15, 2011 | MSI KM4AM-L VIA KM400A CHIPSET ULTRA...
How much total Hard Disk capasity supported by my motherboard
Since it supports 120GB, it will support any "large" SATA drive, such as 500GB or twice or three times that size.
Sep 20, 2009 | MSI K8MM-V Motherboard
Can´t find SATA-disk on my motherboard MS-7061 and chipset KM400A
If the Bios does not see the disk, the operating system will not see the disk, nor will the install -even if you do an f6 to load drivers. It is most likely a problem between the motherboard not recognising the SATA-II interface. So no real solution I'm afraid. I suggest you install a SATA-II interface card which the BIOS will see, and add the card driver at f6 to install XP.
Apr 22, 2009 | Computers & Internet
Switching from 40GB IDE HDD to 500GB SATA HDD. SATA won't boot.
Hi there
No there is no need to change any jumpers on a sata drive, go into the bios settings and tell the bios to boot from the western digital drive only.
Good luck and thanks for using Fixya!!!!
Feb 09, 2009 | VIA MSI: MSI PT8 NEO-LSR P4 PT800 DDR400...
Does My A8N-VM Motherboard support 500GB SATA or SATA II ?
Yes, your motherboard features 2x SATA II ports so you can add any sata II hardrive
Dec 16, 2008 | ASUS A8N-VM Motherboard
SATA drive not detected in BIOS and windows does not boot up
i have same problem with WD 250GB sata HDD. with same bord K8V-MX,  i all reday update BIOS with 0502 version.
plz plz plz help me.
CC me chepu_456@yahoo.co.in
Feb 21, 2008 | ASUS K8V-MX Motherboard
Sound
there is a problem of virus install anti virus.
manually, go to the device manager select the sound option and scan it, if the question mark in yellow appear mean not install, select it and right click it and select update driver go through it step by step select recommended process insert motherboard cd and define the path and click ok restart the system.
if u don't have the driver program then mail me u computer configuration.
Nov 21, 2007 | MSI KM3M-V Motherboard
MSI KM4M-V Motherboard Logo
623 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
