Question about kawasaki Full Suspension Mountain Bike Men
No spark we have rebuild the bottom end and now have no spark bike was running before we rebuilt it
  • tassie35 Apr 30, 2009
    kx125 2001
  • Douglas Woody May 11, 2010
    WHAT UNIT ARE WE TALKING ABOUT
    President:
  • 1,167 Answers
Hi mate disconnect the cut out switch and try kicking it over if still no spark check connections are pushed together propally there buggers sometimes and push the plug to the cdi in also consider replacing spark plug and try the coil on a different bike and see if it works goood luck
Posted on Jul 08, 2009
Pulsar 220 Bike emits little smoke even after Rebuild, how do I fix?
Did you clean the bore REALLY REALLY good with hot soapy water and a brush before assembly? Need to remove all the grit from the honing process. Test by rubbing hard with a white cloth.It MUST still be white after rubbing. If not then clean it again. It will wear out the rings quickly if it's not right. Solvent will not clean it properly.
Jun 24, 2015 | 2007 Bajaj Pulsar 180
Coolant leak in Cylinider
You have to have a torque wrench to start with. Without it you are wasting your time. You can also damage the head. You can buy a torque wrench at Harbor Freight for a very good price with a lifetime warranty. I would not attempt to do it again without the torque wrench. You also might want to have the head resurfaced at the machine shop. Aluminum tends to warp when over heated. I hope this was helpful. Good luck.
Mar 14, 2013 | Motorcycles
Rm 250 starting issues
This may help you determine the problem.
1. is sprkplug oil fouled? wet? dry? superhot and white electrode?
A sparkplug will always tell you whats going on.
if its too wet then its not burning all the fuel and oil and flooding out.
if its extremely hot and white, then its running lean , and needs more fuel.
also make sure your running 50:1 fuel oil mix.
a hot two stroke is hard to start.
if plug is dry, then its not getting enough fuel.
2. make sure your fuel oil mixture is 50:1.
to much oil is okay but it may smoke alot
way to much oil will oil foul the plug and plug will have oil on it.
to little oil will make the bike run hot and start damaging the bottom end crank bearings as well as your rings , then piston and cylinder walls.
the plug will be whitish and hot.
3. as for the timing , the rotor is resting on a keyway on the crankshaft and will only move out of time if the keyway is sheared.
4. make sure you have good spark when bike wont start.
a coil that is going bad will work cold but may not when it gets warmed up
to sum it up check to make sure you have correct fuel mixture
check you sparkplug to see how its burning
if you have good spark, good fuel, good compression, then it should start within 2 kicks everytime.
i have a blaster 2 stoke 4 wheeler, starts everytimesince i rebuilt it.
i hope this helps you out and you can enjoy the rest of the summer with your dirtbike.
best regards
Big Al
Aug 02, 2012 | Suzuki RM 250 Motorcycles
When i crank my bike it runs but when i hit the gas it bogs down and dies nless i let off of it. why does it do that?
my 03 yz125 does the exact same thing... its driving me insane... i got a new spark plug for it and that still didnt fix it.. i dont know why its doin that.. i think it needs a bottom end rebuild, which is retarted coz i already forked out to pay for a rebuild not long ago
Sep 18, 2010 | 2003 Yamaha YZ 125
Yz 125 2001. starting ploblem after top end rebuild
Kinda sounds like your needle valve is sticking in your carb and it is giving it to much fuel
Jun 03, 2010 | 2003 Yamaha YZ 125
My 97 suzuki gsxr 1100. start but that is it Help.
Rebuild the top end? Run screaming from that shop. The fact that they said they couldn't sync the carbs should have been your first clue. I would have been suggesting a fuel problem anyway but take it to a shop that knows what it's doing and you should be fine but you will probably have to replace th spark plugs because of the fuel problem.
Feb 25, 2010 | 2008 Suzuki GSX-R 600
Spark plug, gas, oil?
i have the same bike and love it. i use a ngk iridium plug and it works perfectly. i run mid grade gas 89 or 93 with royal purple 2 stroke oil and i also use royal purple crankcase oil for the bottom end. never had an issue.
i am a mechanic and own my own shop and use royal purple in all my rebuilt engines and race engines.
good luck and love that bike man.
Feb 01, 2010 | 2004 kawasaki KX 125
I recently rebuilt the topend on my son's 01 kx 100 new cylinder and all. The bike runs great at low to mid rpm but when up in the topend range of the power band it looses all power and runs very rough! My...
I'd bet you 10 to 1 it's not the coil. It sounds like it is starving for fuel and needs a carburetor adjustment. When you rebuilt the top end, did you put a bigger jug and piston? If so, your problem most definitely is the carburetor needs to be re-jetted.
What caused you to rebuild it? Did it seize, or quit running? Was it losing power before the rebuild?
That's where my money is but if you still believe it is the coil, you can check it with a spark checker. This is a handy little tool you can find at AutoZone, Harbor Freight, etc. It's a one piece tool that connects between the plug and the coil. The plug stays in but you remove the wire and put the checker on, one side connects to the plug, the other side you connect the plug wire. There is a light in the middle that will flicker when you crank the engine if it has a good coil.
Put the checker on and start the bike and see if you are losing spark...if the light stops flickering at top end, then you do have a coil issue...but like I said before, having seen this problem hundreds of times, my money will be on re-jetting the carburetor.
Nov 08, 2009 | 2001 kawasaki KMX 125
1997 yz 125 wont start, please help
2 stroke bike are very dependent on compression. and being a bike that is 12 years old my best educated guess is that the top end needs to be rebuilt. i usually have to have the top end done on my honda about every three years.
Jan 12, 2009 | 2003 Yamaha YZ 125
kawasaki Full Suspension Mountain Bike Men Logo
113 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Phillip Edwin
Level 1 Expert
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
