Question about Mitsubishi WD-52525 52" Rear Projection HDTV
MITSUBISHI DLP TELEVISION
GREEN TIMER FLASHING LIGHT. TV WON'T WORK. WHAT DO I DO?
  • wolf60 Nov 08, 2007
    I had an yellow light indicating that the light bulb is gone.Actually the picture was just flickering.
    I bought a new light bulb and replace it.It did not solve the problem.Now after I turn the tv on the green light comes on and stay for about a minute or little bit more.Then the red light is coming on.
    I really do not know what is the problem.Can somebody help me?
  • 3 Answers
Urn on you tv after it goes off
go to front press menu and device at same time
it will recycle and the green will start flashing
count the cycles a three flash pause and than a 7 flash
will mean a bad fan
there is fan in the back that cools a heat sink
it is easy to get to
sometimes the connection goes bad
you can check your fan
dont order one from mit
this is a standard 3 wire 50mm x50mm computer heat sink fan
take yours out and find one to match
cost about 6-8 dollars unless you have laying form old computers
you have to take off the plastic cover in the back no big deal
with cover off yu will see a metal cover looks like a tunnel at the bottom
three screws removes it wires are under
after removal you will see the fan and heat sink
put you filter on the side back on with the two screws
so that the tv will start plug it back in turn power and see if the fan spins
if not check connects no run after that
than replace this fan
mine worked fine with new fan
if need more help you email me at tileman22@comcast.net
Posted on Nov 05, 2007
  • 3 Answers
After power-on, if the green LED does not stop blinking after 70 seconds, it may be either the card reader (p/n # 299P271010) or the DM board (p/n 934C116002).  You could try checking the DM board for swollen capacitors.
Posted on Oct 12, 2007
Hit the reset button. The light will flash for about 20 seconds.. when it goes out. turn the TV on. That should work. If not. then it may be the lamp
Posted on Oct 11, 2007
    Genius:
  • 1,694 Answers
Try replacing lamp as first best guess,then go from there.
Posted on Oct 09, 2007
4 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: Constant green blinking timer light
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
Suspect the DM PCB part # 934C116002
Posted on Jan 07, 2008
Slinteriors
  • 8617 Answers
SOURCE: 52" DLP Mitsubishi HD TV;
you need the V26 DM repair kit available at the following link, which contains the replacement high temp capacitors and instructions. Its listed under the repair Kit category.
http://servicemanuals.vstore.ca/
Posted on Sep 25, 2008
SOURCE: Mitsubishi dlp tv green timer light blinking
timer light keeps blinking tv does not turn on
Posted on Nov 29, 2008
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi DLP 60" - power
Unplug the television, let it sit for an hour an try to plug it back in. That should resolve the problem. if it still flashes green after you do this, use the "reset" button again. Let me know if that works.
Nov 23, 2010 | Televison & Video
Green blinking timer light, TV won't turn on
Common to mitsubishi dlp tv's,you have a bad signal ***'y (power supply,formater board) lots of bad electrolytic capacitors,
Mar 22, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62627 62" DLP TV
Try this:
1) turn on the TV
2) from the remote control press MENU 2,4,7,0 then ENTER
3) tv will state on screen that it is INITIALIZING
4) when done press the front reset button.
5) should be good to go!
Oct 26, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have a mitsubishi tv model # WD 52525 DLP and the timer light just keeps flashing and the TV will not go on
i have a mitsubishi ws-55859 rear projection tv. the green timer light just keeps flashing and the tv will not turn on.
Aug 09, 2009 | Televison & Video
Flashing Green "Timer" light on my Mitsubishi WD-62525
My Sony had the same problem. Unplug from the wall for 36 hours and it should solve the problem
Mar 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
the dlp will most likely need a qualified mits repair center to take over for you. repairing that set is pretty involved. and the parts you would need are not available to the public.
on your 48" CRT projection check the DM module for 4 vented 1000mf 16v capacitors. replacement should get you tv working great
Feb 20, 2008 | Mitsubishi WS-48513 48" Rear Projection...
Jan 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
681 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
