Question about 2wire Wireless-G 802.11g ADSL Gateway
Dear all can I connect a hd dvr to my gate 2 wire wireless modem and get so access over the network to the hd dvr?
I connect my HDD to my computer then I allow other computers to authenticate with my computer in the network. So they can access the drive when they want to.
Posted on May 15, 2009
Powerline adapter wont work with directv dvr
Different modems have different configurations - your new provider should be able to assist you in getting connected.
Sep 14, 2017 | Powerline Ethernet Network Adapter
How to install d link 802.11G wireless access
Connect modem lan cable to Router Wan / Internet port. From Router Lan port you can either connect your system or switch . wireless : Scan for wireless network from your wireless system. If it shows, connect to your wifi network
Thanks
Mar 25, 2011 | D-Link 802.11g Wireless Router WBR-1310...
We switched from cox Cable to Direct TV. The BD390 works normally through an Apple Airport Express with an Ethernet connection to a Motorola SB 6120 modem. The system does everything it is supposed to...
So practically you want to use the BR390 as an access point, to route the data from the Apple to the DVR. No, this isn't possible since the player doesn't have routing capabilities.
But you can do something else: instead of the Apple (which is just a very simple router with some minor extra capabilities sold ad an outrageous price) you could get a way better normal router for a lot less than $100 and connect all devices thru LAN cables in an local network.
Aug 17, 2010 | LG BD390 Blu-Ray Player
Changed from AT&T to a cable company for DSL. Trying to set up
You need to "fool" your cable box into thinking that the wireless router is the computer. This just means that the modem is locking into the first ip address it can get... it tends to block out all others. Here's how to remedy and allow everything to get access...
1 Shut off computers, routers, everything.
2. Turn on your wireless router FIRST... leave everything else off until you see it's completely booted.
3. Then with the cable connected to the modem/cable box and the router, turn on the cable box/modem and let it cycle up. This should allow the cable modem to "find" the wifi ip address as the main ip.
After that, turn on any other routers, and the computers...
This should allow you access to the net by any of your computers because the wifi router should give all the other comptuers and routers on the system inddividual ip addresses and all should be well...
Give it a try and let me know!
K
Aug 28, 2009 | 2wire (1000-400108-001) Router
I purchased a Verizon wireless card to connect to the internet when I am out of my house, I pay $60.00 per month. What I would like to know is the following: 1. Can I connect the wireless card to a...
Cox is robbers :-)
I pay the $40 to Vz and $35 to Time Worthless (tm).
You can do it, but I don't think you'll like it. You need the 175 modem and Vz caps the service. The key is a new Netgear product http://www.google.com/products?q=netgear+mbr624gu-100nas&rls=com.microsoft:*&oe=UTF-8&um=1&ie=UTF-8&ei=FC5RSsT1JJqltgeo-vTWAQ&sa=X&oi=product_result_group&ct=title&resnum=4
Best advice, call Cox and threaten to leave if they don't give you a "deal." We worked out TWC bill to $157 for the "triple play" and 2 movie channel services and 2 DVR's that I went out and got a TiVO 500 G HD for $65 at Bust Buy to increase the storage to a gazillion hours.
Carl
Jul 05, 2009 | Computers & Internet
Use Netgear WGR614 as an access point
Right, it won't work. The 614 doesn't have the software to make it into a BRIDGE or AP CLIENT. It can only be made into an Access Point, meaning it needs a wired connection INTO it.
A TP-Link http://www.tp-link.com/products/product_spe.asp?id=36 WA501G costs under $40 and gives you the ability to go from wireless to wired. It takes about 15 minutes to set up, and will plug into your DVR's ethernet port to extend your wireless network. It's programmed by setting the mode, AP, CLIENT, BRIDGE, etc. We use them in areas where we want to extend a wireless signal for distances like across parking lots, but it also will work across a room or two.
There are also wired ethernet extenders that use house wiring like the Netgear XE-102, about $80, that look like two wall transformers with ethernet jacks. You plug one into the router/switch and the other into the DVR.
Carl
Apr 21, 2009 | NetGear WGR614 Wireless Router
2wire modem and a hd dvr.
Yes and no.
You can't make it completely wireless.
But, you don't have to drag cable from your router either. You'll need something like this:
http://www.iogear.com/product/GHPB32W4/
Feb 20, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
Got wireless signal but no internet connection
You can try to power cycle your entire network (refresh).
This often happens when you have a large network.
  1. power down ALL Computers and disconnect the desktop from the D-Link Switch.
  2. turn off all SLAVE AP's first.
  3. Turn off the Master AP and disconnect one end of the Ethernet.
  4. Turn off the D-Link Switch and disconnect one end of the Ethernet.
  5. Now, turn off your modem.
Leave them for about 10 to 15 minutes, depending on your urgency.
Turn on and connect all devices in the EXACT order.
  1. Turn on the modem. wait 2 minutes.
  2. Turn on the D-Link Switch and wait 1 minute. Then connect the Ethernet to the MODEM.
  3. Turn on the Master AP and wait 1 minute. Then connect the Ethernet to the D-Link Switch.
  4. Turn ONE of the Slave AP's. Turn on your Laptop. try to connect to the Internet. If successful, Disconnect from the network on the computer and proceed to turn on the rest of the Slave AP's, Laptops, and Desktop. If its NOT successful, power on the Desktop and try to connect to the internet.
  • If the desktop connects to the Internet, Check your D-Link's homepage "192.168.1.1" (default) for any wrong settings. If it does not connect, check your DSL Modem's settings.
If the above does not work, post what you did the day before this happened. Probably something small might have messed with the network.
Aug 15, 2008 | D-Link AirPlus DI-524 Wireless Router
Linksys Wireless WRT54G vs. WET54G
For what it is worth, I fhave found streaming video does not function well using a wireless connection. The options of multipale routers will work as long as you configure them as to not have conflicting IP address assignment's via DHCP, and the routers do not have matching IP address's. Never fear all is possible with paticence. BPCS
Jan 20, 2008 | Linksys Wireless-G WRT54G Router
Open Questions:
See all 2wire Wireless-G 802.11g ADSL Gateway Questions
2wire Wireless-G 802.11g ADSL Gateway Logo
195 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
