Question about Nor-Lake Freezer Norlake Refrigeration 6' x 6' Kold Locker Walk-In Freezer - 6' 7'' High w/Floor
I would like to know the standard temperature for a freezer
  • 10,865 Answers
The factory presets your temperatures to the MID / MID setting of 0ºF for the freezer.
Posted on Apr 23, 2009
With deluxe Electronic Temperature Control Freezer control panel shows "OF" and I can't restart the freezer
Search Results
    Freezer electronic temperature control manual... ' Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jul 5, 2012 - I have a Kenmore elite freezer with electronic temperature control. ...my freezer was delivered yesterday, the control panel is stuck on of, ... an electronic control on front. the display is showing hi temp and door ajar. also an l in ...
    Control Panel is not working right - Samsung
    www.samsung.com/sa_en/support/skp/faq/239315
    Samsung ElectronicsSep 3, 2015 - In case of wrong temperature display, possibly door opens so inside ... If the control panel is still not lit up after you plug the refrigerator back in, it may ... When initial installation, Temperature will show current temperature for a ... When the refrigerator/ freezer reach the set temperature, the blinking will stop.
    Adjusting Side-bySide Refrigerator Temp Controls - Actual ...
    ? 3:50
    https://www.youtube.com/watch?v=DFzTGKVo79g
    Jun 27, 2010 - Uploaded by GE Appliances
    CAN I TURN OFF THE DIGITAL CONTROL ON FREEZER AREA ONLY. ... I need to know How to reset this kind of refigirator, same front panel ... When you try to set the actual temperature, does your control show your new ...
    Electronic Temperature Controls - ManualsLib
Feb 03, 2016 | Freezers
Does the green light on my freezer need to be on at all times and temp set to normal
Good Afternoon Friend,
I understand that you want to know if the green light has to be on at all times and the temperature set to normal on your Frigidaire freezer, model# FFU2124D. The green light will always be on. This is letting you know that there is power going to your freezer. You do not have to leave to temperatures set on normal. You are able to choose any temperature that works for you and keeps your food frozen. When changing temperature settings, turn the knob slightly in the direction you want, and wait 24 hours for temperatures to stabilize. If you want to change the temperatures more, again wait another 24 hours after changing them, for the temperature to stabilize. Hope this is helpful.
-Best Regards-
WP
May 22, 2014 | Frigidaire 20.6 cu. ft. / 583 liter...
First the freezer alarm beeping with red light flashing, inside light went out and freezer standard electronic temperature control display unit no longer lights up.
Hi Loretta, I am happy to assist you!
Based on the symptoms you are describing, it sounds like your freezer may possibly have a communication problem with the control board, a potential wiring failure, or faulty temperature control. Before reaching out to a professional, let's try resetting your freezer. This can be done by either unplugging it or flipping off the circuit breaker. It is important to wait approximately ten minutes. If it proves ineffective, In this regard, I would suggest contacting an Authorized Service Technician that will be able to assist you in the exact diagnosis of the appliance.
Best regards!
Jan 31, 2014 | Frigidaire Freezers
Doesn't stop running but is very cold
the cold control is probably stuck closed. if you have a meter, you could pull the control out to check continuity. if nothing else throw in a thermometer, standard freezer temperature is +5 to -5 degrees F.
Nov 06, 2013 | Arctic Air 22 cu. ft. Commercial Freezer...
Need to adjust my temperature differential on my carrier pulse freezer mod#ULG50BC-5
Is this a digital or standard model . That helps me in figuring this out.
Mar 01, 2013 | Carrier Freezers
Amana freezer on the bottom not keeping temperature
Hi, If you had ice, there is a drain plugged in the freezer. If you had a frost build up, there is a problem with the automatic defrost.
I can help in either case. Please let me know if you need more assistance.
Thakns
Vic
May 13, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Freezers Logo
183 people viewed this question
Top Nor-Lake Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Nor-Lake Freezer Expert? Answer questions, earn points and help others
