Question about Brother MFC 210C All-In-One InkJet Printer
LCD dislpay on my MFC-885CW is saying unable to clean!What do i need to do ?
  • 2 more comments
  • lillymackell Apr 22, 2009
    My LCD screen on my MFC-885CW is displaying unable to clean 30! .
    Before my ink ran out it was working fine, I replace my ink and gently moved my printer for one table to another and it no longer works?
    Hi ,
    I have done all of what was instructed to do and nothing at all is stuck in the machine,
    I have reset it twice.
    It was fine until i changed the ink which i have removed them and made sure nothing was in their also and ensured it was clean.
    Sorry can you explain what you want me to try? that doesn't mean much to me!
    Thanks
    Thanks for your time.
    Brigadier General:
  • 7,191 Answers
The message "Unable to Clean" (followed by a two digit code) will appear
on the display if there is a mechanical malfunction of the Brother machine OR a foreign object, such as a paper clip or ripped
piece of paper is stuck in the machine.
First, check the machine for any foreign objects:
1. Lift the scanner cover using the plastic tabs located on the left and
right side of the machine until it locks securely into the open position. Look inside the Brother machine and remove any foreign
objects.
2. Lift the scanner cover to release the lock. Gently push the scanner
cover support down and close the scanner cover.
If the message continues to appear on the display the machine will need
to be reset. Resetting the machine will erase all faxes in memory and
the Fax Journal Report. However, there is a way to transfer faxes in
memory and the Fax Journal Report to another fax machine to print them
out.
NOTE: In order to transfer data from your fax machine to another, you
must have the Station ID programmed in your Brother machine, prior to
the message appearing on the LCD.
- To transfer faxes in memory to another fax machine continue to STEP 3.
- To transfer the Fax Journal Report go to STEP 4.
3. Verifying and transferring faxes stored in memory:
a. Press Menu, 9, 0, 1. Note: This menu option will only appear if the
LCD is displaying an error message (example: No Paper Fed, Unable to
Clean, etc). The menu option will NOT appear if a status message is
displayed on the LCD (example: Ink Empty).
b. If there are NO faxes in memory, the LCD will display NO DATA.
Continue to STEP 5.
c. If there ARE faxes in memory, the LCD will prompt you to enter a fax
number. Enter the fax number where you want to receive and print the
faxes.
d. Press Black Start. Once the machine has transferred the stored faxes
continue to STEP 5.
4. Transferring the Fax Journal Report
a. Press Menu, 9, 0, 2.
b. Enter the fax number where you want to receive and print the faxes.
c. Press Black Start. Once the machine has transferred the stored Fax
Journal Report continue to STEP 5.
5. To reset the machine, unplug the Brother machine from the power
outlet for several seconds and then plug it back in.
- If the #Unable to Clean# message reappears your machine will require
service.
Posted on Apr 22, 2009
  • AliTech110
    AliTech110 Apr 22, 2009
    Have you checked for any foreign / unwanted object, or any piece of paper stuck inside the machine? If no objects are found, I suggest that you should reset the machine as per the earlier instructions.
  • AliTech110
    Looks as your machine has developed a mechanical malfunction and it requires service.
    You can locate the Authorized Service centers here:
    http://www.brother-usa.com/service/defau...
    Thanks
  • 483 Answers
We can finally try reset absorbers counter, b'fore calling support.
Thanks
Fame !
I purchased this machine mfc 885cw from someone their infor for wireless is in there and i do not know how to remove it. also i do not have the install cd
Go to the manufacturers website and download the installation and setup files. If you do a setup from scratch it will apply your settings and wipe out theirs.
May 23, 2016 | Brother MFC-885CW Used
MFC-8870dw 30ppm Wireless Network Multifunction Laser Printer with Duplex Printing, Copying,...: How do I connect my Brother MFC-885CW printer to m...
Connect the printer with a USB cord to the computer. Switch off the printer and install the driver in to your computer , during installation the software will tell you to switch-on the . Do so and finish the installation .
This is the procedure to connect the printer with your computer.
May 17, 2010 | Brother MFC-8870dw Wireless Multifunction...
I have a Brother MFC-885CW printer. A friend
I have a Brother MFC-885CW also and I have changed the colour inks no problem but now I have just changed the black it will not print black.
Oct 14, 2009 | Brother Multi-Function Center MFC-240C...
Hi I would like to know if the mfc 885cw has an answerphone & how to set it. Thanks
The MFC 885CW does NOT have a built-in answerphone. It will connect to an external machine if you like.
Here is a link to the owners manual and if you like, you can download it. The section dealing with answerphone starts on page 55
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_685cw_885CW_EN_1339.PDF
Sep 22, 2009 | Office Equipment & Supplies
Clean Unable 46
Clean unable 46 means that the ink tank is full. You need a replacement tank installed and the count reset. This is a holder inside for the used ink,best to be a shop repair.
Jun 23, 2009 | Brother MFC 240C All-In-One InkJet Printer
Scanner bar will not reset, error "unable to Init. AF"
the problem might be the connection from the mother board of the printer to the scanner maybe due to lost contact and the ribbon was broken you might just have to reconnect it or it might be broken and need replacement
May 10, 2009 | Office Equipment & Supplies
Brother MFC-885CW Wireless keeps saying it's not connected to the computer yet it printed yesterday fine
hai ,salva,just finish to install mfc-885cw,wireless,when i try to install mfl-pro suite,at the end evething is fine except the printer,is not install.problemwith root directory of cd-rom.can you help please
Nov 13, 2008 | Brother Office Equipment & Supplies
Unable to connect handset on brother mfc-885cw
Plug a regular phone into the wall jack and listen for a dial tone.
Oct 16, 2008 | Office Equipment & Supplies
Brother MFC 210C All-In-One InkJet Printer Logo
70 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
