Question about HTC Touch P3452 Smartphone
Htc touch screen not getting aligned.needs to keep on aligning and still it asks for aligning.pls help
    President:
  • 1,223 Answers
Touch Panel Faulty !!
u have to get it replaced around 60-80 $ , u can also do it urself tell me ue region i will check the touch panel for u and let u know abt the procedure to change it urself this touch panel fault is frequent these days in all PDA's , i am sure abt it
pls rate me FIXYA i will provide u assistence in this matter no problem !
Posted on Apr 22, 2009
How do I calibrate my touch screen
Calibrate the g1 touch screen on the device by going to Start>Settings>System Tab>/Screen then Click Align Screen If you cannot get to the Screen Alignment utility using the menu’s, it can also be accessed by pressing the Volume Up and Center Navigation Buttons at the same time.
hope this helps, pls appreciate by rating as fixyaa
Jan 13, 2010 | HTC G1 Smartphone
Align screen problem on HTC P3650 Touch Cruise
try to hold the curser where ever it goes for some seconds after 3-4 tries ur device will start proceeding.
Sep 23, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Ican not align screen my htc touch hd
I can not align screen my touch HD
Jun 19, 2009 | HTC Touch HD Smartphone
Align screen
you should take the phone back and have it replaced if it is still under warranty or you may need to replace the LCD.
Jun 01, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Screen alignment could not be done
I accidentally click on something and my screen alignment for my HTC mobile phone has run significantly... When I tried to align the screen from the setting, it only write that tap firmly and accurately on the target. the target will continue to move until the screen is aligned. Till now, i tried many times but the alignment is still out
Mar 25, 2009 | HTC Touch HD Smartphone
Touch panel is not working
needs to be replaced , if it does not respong to ur taps have u tried aligning the screen does it work at all or no area is responsive on screen then u can try hard resetting it first but after that it will be guaranteed that ur touch panel is faulty which seems like to me
but one thing u shud now all data will be lost in factory reset process and if u touch panel is faulty u will stuck up in initial aligning process so pls backup first b4 going ahead sync contacts and sms calender an stuff then try this
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if u are stuck at align process then it is now pretty sure that ur TOUCH PANEL / also called DIGITIZER is faulty u can get it replaced around 60 $ or so
pls rate me fixya for my diagnosis if u like
Mar 06, 2009 | HTC Touch P3450 Smartphone
The touch screen does not appear to be working
needs to be replaced , if it does not respond to ur taps have u tried aligning the screen does it work at all or no area is responsive on screen then u can try hard resetting it first but after that it will be guaranteed that ur touch panel is faulty which seems like to me
but one thing u shud now do all data will be lost in factory reset process and if ur touch panel is faulty u will stuck up in initial aligning process so pls backup first b4 going ahead sync contacts and sms calender an stuff then try this
Mar 05, 2009 | HTC Touch P3450 Smartphone
I have HTC P3450 phone
so just do it carefully click between the cross hairs of the plus sign at five points one after another with a pointed object carefully then it will move on to the next screen for further setup ,
but if u r stuck at this point and u are gettin this alignment screen again and again in a loop then my friend its a hardware fault basically it is a faulty digitizer or touch panel u can say the front screen where u click with ur stylus it became faulty u need to replace it other wise it will stuck on this screen alignment process and will not go past, u need hardware replacement it is around 60 to 70 $ cost to replace just take to the service centre in ur area or find it on www.htc.com or tell me if u have somethin else to ask.........pls lemme know if it helps
Feb 22, 2009 | HTC Touch P3450 Smartphone
GETTING STARTED
To align the screen tap frimly with the stylus on the X that comes on the screen..it will keep moving its position..do it precisely each time..the screen should get aligned in a short while..hope it helps!regards..
Nov 25, 2008 | HTC Touch P3450 Smartphone
HTC Touch P3452 Smartphone Logo
141 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
