Question about GPS
HUMMINBIRD FISH FINDER WON'T COME ON, IS THEIR AN IN LINE FUSE OR FUSE INSIDE?
  • fwsuttle Apr 22, 2009
    GREAT INFORMATION THANKYOU VERY MUCH
  • fwsuttle Apr 27, 2009
    hi,
    all sorted thankyou.
  • 10,515 Answers
Are you still facing any issue or it has been resolved?
Have you reset the device to factory settings?
If yes, kindly close the thread by selecting "Fixya".
Thanks.
Posted on Apr 26, 2009
    Sergeant:
  • 254 Answers
Yes there is a fuse.in the lower end at the baCK OF THE BNATTERY.
if the unit does not powers up check this as follows:--
1) check out whether the power cable is properly connected to fishfinder control head.
2)checkl out whether power cable is wired correctly ,with red to positive battery terminal and black to negative terminal or ground.
3)check out the fuse.
4)the battery voltage of the power connector should be atleast 10volts.if that is less then also it will not power up.or come on.
5)remove the battery check out the battery terminals if any corrison collected tpo its terminals then clkean it and recheck it.
6)if still the same problem after doinfg all this its probably the battery fault.the battery needs replacement.
note:-- if the unit is absolutely new and underwarranty, then contact company or the dealer from whom the unit has been bought so they will get the battery replaced for you absolutely free.
but if its out of warranty then replace it yourself.its a common problem not a major problem.
for more help this is the direct link of the manual just click the link directly
http://www.retrevo.com/support/Humminbird-525-GPS-manual/id/540ci476/t/2/
please do rate the solution.thank you for using fixya.
Posted on Apr 22, 2009
How to connect Humminbird fish finder to Motorguide trolling motor
I would use slip rings to tie existing cable to prop motor support shaft and mount transducer to motor housing. 'slip ring'--metal ring a little bigger than shaft with a nipple the size of the cable. OR call the bird at 1-800-633-1468 or www.humminbird.com/Category/Company/Contact-Us/ and use some southern/country slang when talking. Best of luck 'you all'.
Oct 03, 2016 | Humminbird Boating
What size fuse to use when connecting a Humminbird 596c HD DI to the battery? Best regards John
I put in a 3 amp fuse like recommended for these units and have had no problem. Either an auto fuse or glass fuse will work fine.
Aug 24, 2011 | Humminbird 596 c Series Fish Finder ()
Need to locate and print users manual for Humminbird Pironha Max 160 Fish finder
print users manual for Humminbird Pironha Max 160 Fish go to this link http://store.humminbird.com/media/document/PiranhaMAX_150-160-170-180-190c.pdf
Aug 13, 2011 | Humminbird GPS
Can i get a free manual for the matrix 97 combo fish finder / gps chartplotter.
Call our Customer Service Group at 800-633-1468 and they should be able to help you.
Joby
Humminbird
Feb 06, 2011 | Humminbird Matrix 97 Combo Fish Finder And...
I lost my directions and i can not figure out how to use my bottom line fishin buddy 2250
Humminbird manual for the 110 can be downloaded here.
http://store.humminbird.com/media/document/FB_110_140c.pdf
Good Fishin
Feb 01, 2011 | Humminbird 110 FISHIN' BUDDY Portable Fish...
Is there a free downloadable manual for a Humminbird LCR 4000 Fish finder?
type in hummingbird lcr 4000 fish finder manual pdf. it works for anything you want
Nov 04, 2009 | Humminbird Smartcast Rf 35 Dual Display...
I need a humming bird fish finder 4000 Manaul
http://www.humminbird.com/PDF/lcr4000.pdf
I hope this is the one you are looking for.
Mar 23, 2009 | Boating
Insructions for piranah fish finder at home,
Go to this webpage and click on the link of the manual of you finder and it will open up your manual.
http://www.humminbird.com/support/FAQ.aspx?faqid=72
Dec 29, 2008 | Humminbird Smartcast Rf 35 Dual Display...
I need a manual for humminbird wide 100 fish finder
You can find the manual you need at: http://www.humminbird.com/support/FAQ.aspx?faqid=72
It is listed in the legacy products area with the wide series of units.
Aug 06, 2008 | Boating
GPS Logo
122 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
