Question about Mitsubishi CS-35707 35" TV
Mitsubishi 55511 picture bowed on sides
I have a Mits projection TV 55511 whose picture has begun bowing in on the sides, for a couple of months or so now. It is progressively getting worse as time goes. The picture is now bowed a foot or so on each side. At first, it quickly stretched back out to normal but as time goes by, it takes longer and longer for it to stretch back to normal. Any ideas on what is causing this? I'm a former electronics tech, micro-min certified, but haven't done any display troubleshooting for 20 years and don't know where to start on this. Any ideas are appreciated.
  • Mitsubishi Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the conMitsubishi 55511 picture bowed on sides - 69189a5.pngur need to fix it. See below for a fix
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Posted on Jun 06, 2010
There are 3 distinct color lines and the picture looks 3d. The lines are bowed and trying to adjust using the convergence grid doesn't work- the grid is bowed
Mitsubishis are notorious for bad solder connections on the convergence IC's. These are located on the big heat sinks on the main board. It's an easy fix if you know how to solder. Check for any play on the IC's when "wiggled".
Feb 06, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Picture is bowed and colors are not aligned
This called Projection TV convergence. Take a look on this site for a tip on Projection TV convergence.
Apr 19, 2010 | Mitsubishi WS-55819 55" Rear Projection...
The picture is showing a double image and is distored.
The problem you are refering to is more than likely a convergence problem. The convergence circuit in your tv is controlled by an IC (integrated circuit) stk392-110 and it makes the 3 colors (red, blue, green) line up/converge together to create a clear picture. You'll know when this part needs to be replaced because the picture you see is 3d looking and possibly bowed on the top or bottom or on the sides in any or all 3 colors.
Jan 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Color streaks at top of picture
This is a very common failure on Projection TV sets.
Screen looks 3D
You can see some example photos and find a solution here...
Sep 13, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Skewed picture
you need ned convergance chips
Mar 22, 2009 | Mitsubishi VS-60621 60" Rear Projection...
Bows on sides
Try degausing the set with the system software. if this doesnt fix it you will have to degause the set with a professional tool.
Jan 27, 2009 | Mitsubishi VS-55601 55" Rear Projection...
Ws 55511 convergence lines bowed down at bottom of screen
Check resistors might have cold solder joints are changed resistance values around replaced STK393-110
Pay attention to faded colored or fried resistors.
You can download service manual for WS-55511 from HERE to get schematics and technical info. (download all 3 parts of file and use WinRAR to extract file)
Good luck.
Dec 13, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi TV Picture Bowing
You will find a very good guide here and here to fix your TV.
This might not be a DIY if you do not feel comfortable. The repair shops charge about $350.00 to $400.00 for this type of repair.
Apr 19, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Problem with convergence
bad convergence ic's
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Distorted picture and multi-color words
ive got the same problem on mine ita a 2001 model and also mine when you turn it on it goes off by itself and wont stay on.also mine has multiple pictures one green and one red almost as if 3d im not sure what it cost to fix it but tvs have come down so much i might just buy a new one. good luck with yours
Aug 12, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
