Question about Zanussi ZWF1630 Front Load Washer
Light comes on but nothing else is happening on machine No lights working on the programmes Zanussi electrolux jet system progress 1600 any help appreciated KD
  • slimchops May 03, 2009
    Mine just went too!! Zanussi 1437w - did you get it fixed or found out what problem is?
kjmac
  • 97 Answers
SOURCE: Zanussi FC1200W
have you checked the filter behind the flap on the front of the machine, this could be blocked. if the machine is full of water though you will have to manually drain it by putting the grey outlet hose into a bucket or a washing up bowl. you will also need one or two towels to place on the floor because there wil still be a bit of water left in the ipes even though the drum is empty.
hope this helps
Posted on Jul 28, 2008
  • 17 Answers
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
SOURCE: ZANUSSI WASHING MACHINE
I have taken out the filter and washed it thoroughly! Also flushed the out pipe to make sure the whole system was clean. This resolved the problem
Posted on Feb 08, 2009
SOURCE: Zanussi Jet Stream 1600 is displaying E10 as it
I found that the water pipes were frozen! so I have 'gently' defrosted them and we are now working...
Thanks
Posted on Jan 11, 2010
SOURCE: Zanussi Progress 1600. Keeps showing E20 error
does not drain,does notspin drum not turning,belt intact,shown e20 at one stage,is this the motor?
Posted on Mar 13, 2010
Zanussi jet stream 1600 door locked
SOUNDS LIKE THE LATCH IS NOT WORKING AS IT SHOUD. I WOULD START BY REPLACING IT FIRST.
May 23, 2014 | Zanussi IZ161S Front Load Washer
I have a Zanussi 1600 Jet System Washing Machine, it has started the cycle and 4 mins into it, an E10 error reads on the display, have turned the machine off, and back on, checked pipes, can see you...
This error code relates to water pressure check that the pipes are not kinked,check the water valves are fully on also check if the little filters in the end of the hoses are cleaned.Make sure that the mains water pressure has not been reduced.There could still be a fault with one of the inlet valves but it is most probably the little gauze filters
Apr 26, 2010 | Zanussi IZ161S Front Load Washer
Zanussi Aquapulse DE6854 dishwahser programe lights not working
hi
got same probleme with my aquapulse 4744 slimline
Oct 07, 2009 | Electrolux Dishwashers
I have a Zanussi Electrolux Jetsystem Progress ZSF 6161 Dishwasher which, no matter what programme I use, stops after 2 seconds and a -10 flashes.
I have a Zanussi Jetsystem Progress ZSF 6161 Dishwasher stops after a few seconds and flashes -30 Any ideas? thanks!
Jul 28, 2009 | Zanussi Dishwashers
Just wont work
  1. Turn it off.
  2. Unplug it.
  3. Wait 5 or 10 minutes.
  4. Plug it in.
  5. Turn it on.
Apr 09, 2008 | Washing Machines
Zanussi electrolux aquacycle 1400 xc 6 fx1465 w
i have a problem with my zanussi aquacycle 1400 xtra capacity. some times it works ans some times not like there is a problem with the power the alternater? should i change this part? please help as my wife is driving me crazy.
Mar 20, 2007 | Zanussi F1245W Front Load Washer
assuming you had correct value fuse, fuse blowing may have been caused by a machine fault.after power outage, cycle should resume.
Open Questions:
Zanussi ZWF1630 Front Load Washer Logo
61 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
