Question about Water Heaters
Water pump does not work when i turn on hot water tap
I empted the water system for the winter in the camper van, when i filled back up again i found the water pump worked when i turn the cold water taps on but not when i turn the hot taps on. There is no air or water coming out of the hot taps, it does sound as if the pump tries to start up at about 30 second intervals somone said it could be the none return valve or the filter needs cleaning (1) is the none return valvue on the outside of the van, (2) where is the filter found, (3) in the book it says to fill the tank up with water does this mean to the top or is it OK half filled, The water pump is carver cascade rapide. I have a book on the pump it tells you how to fit the pump and there is a section on troubleshooting and it tells you what what to do if somthing is wrong but not how to do it or where to find it. If we cant solve this between us i would like to thank you for your time.
  • ian_william_ Apr 23, 2009
    micaijh I have had a look no leaks no blockage not sure about the shut off valve will have a look i think i may not have shut the none return valve off before filling will try again thanks for taking the time to try to help me.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
Since the cold water works, the problem is not the pump. Look for a blockage or possibly a major leak in the hot water system. if you have a kitchen sink and bathroom sink, are both hot water outlets not working? Does the water heater have shut off valve , or is its drain still open from when you winterized it (and the water running out to the ground instead of to the faucet?
Posted on Apr 23, 2009
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Tank full of hot water,faucets deliver only cold,water trickels into tank with rapid intermittend pump action
1) Copy following link:
http://waterheatertimer.org/Crossover.html
2) Add comment with clear description of water heater, fuel type, and pump?
Is this a pump problem or water heater problem?
Is this a water well pump?
Are you getting good stream of cold water at tap?
Which water heater do you have?
Is the heater new?
Or older heater that stopped working.
Dec 27, 2012 | Atwood 10 Gallon Gas/Electric Water Heater...
I have to turn the hot water tap on full open to get hot water
Type of water heater is unknown
If you have single-handled faucet the faucet cartridge might be bad.
If you have recirculation system, then check valve might be bad.
Copy following links for troubleshoot.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Jul 16, 2012 | Water Heaters
I have a instantaneous water system 10H Hydropower ...did not get a manual when installed....I need to have hotter water as it's winter and the water is like warm...not sure what to adjust...opened...
take the cover off the 10 h unit light up the burner by turning on the tap turn the water flow tap on the front of unit (white knob) clock wise slowly feel hot water pipe coming out off unit when temp increases put cover back on check temp at sink if too hot turn knob anti clock wise
May 23, 2011 | Bosch Water Heaters
6 gal tank puts out only about 2 gal of very hot water. ADoes the same whether on gas or with electric hot rod.
Have you tried it with both (hot rod and Gas ) turned on at same time? Is tank well insulated? (looking from behind tank.)
Does temperature drop off quickly, or gradually? Did it supply hot water better before, or this is first time you really measured it out? Need to keep in mind that as hot goes out the top fitting to hot lines, cold is coming in the bottom fitting and beginning to mix with hot, which obvioulsy will cause hot to gradually become warm as it enters. 2 gallons out hot tap, 2 gals., at bottom of tank, then mixing as it flows in usually equals, about 2 gal or less of warm, then cold again. Get many complaints of only enough for a short shower when they have 6 gal tank. You can try adjusting temperature up a little to see if it helps. Keep an eye on pressure relief valve dripping excessively as well as shut pump off for 20min-30 min, then turn it back on before touching any taps, to see if it cycles at all, indicating a leak in the system. If pump doesn't cycle when turned back on, no leaks.
Jan 27, 2011 | RTO Atwood Water Heater - 6 Gal LP
Water turns cold very quickly
I had the EXACT same problem (installed my tankless last winter and worked fine, now this summer it fluctuates, have to turn the shower completely off and then on again to get any hot water and then it only lasts for a couple of minutes!) Argh - it is frustrating!
Here's what I found: the demand for hot water is lower during the summer (hot) months because the "cold" water coming in is already quite warm. You don't need as much hot water to make the shower temp comfortable. SO, my tankless was shutting off due to low flow demand. I've removed the flow restrictor from my shower head and it helped alot but didn't completely solve the prob. Next step is what has been recommended to me by several people but is much more expensive - change the pressure valve on your shower to a temperature valve. Or just wait til winter and it should work ok again :)
Jul 06, 2010 | Bosch & Tankless LP Hot Water Heater
Central heating and hot water have suddenly stopped working
not an engineer but maybe a heating compant,, it sounds like you have a relay that has gone bad, you have what we call a winter summer system your domestic water comes from a tank inside the boiler, you might want to think about splitting the system to save you some money in the long run, seperate the water heater from the boiler so you only heat up in the winter, right now you are heating the system that heats your house to get 30 or 40 gals of domestic hot water, it would cost you less by seperating them
May 17, 2009 | Water Heaters
Combi Boiler - Hot water pressure low
the coil inside got clogged
Dec 22, 2008 | Water Heaters
Water Heaters Logo
508 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
