Question about Boating
I have a 25hp evanrude (1994)tiller steer,would like to ask if the knob at the end of the tiller is for the slow running mixture,if so how is it ajusted as my motor runs ok at speed but mucks up at low speed,,thanks, bernie....
  • 75 Answers
This knob is a low idle stop
loosen the knob set the throttle to slow but running ok then tighten the knob
now the throttle will not go lower than this set point and die out
hope this helps
Posted on Jul 08, 2009
The carburettor how to adjust the air and fuel mixture on the carburettor
Find the adjustment screws on the front of the carburetor. Then Start the engine and let it warm to normal operating.
Adjust both screws equally and find the right mixture.Bring both screws up slowly and listen until the engine purrs smoothly. Any raggedness or rattling is a sign of too lean a mixture. Keep turning until you find the sweet spot.
Sep 21, 2015 | Troy bilt Super Bronco Tiller 208cc
Why Tiller cranks but will not run when you need it to till?
If you don't have a manual, could can read/download it at this link.
If the engine stalls under load, the mixture may be too lean. There should be a mixture screw on the carburetor. Note its position, and turn it counter-clockwise 1/8 of a turn to see if there is any improvement in engine performance. Repeat this but don't exceed about a half turn.
The tank has a vent and this should be kept vertical under the cylinder cover in the small "pocket" in the cylinder cover.
Lack of power can be caused by a dirty air filter or blocked muffler screen.
See the article below for troubleshooting 2-cycle engines
String Trimmer Won Work 2 Stroke Engine and Carburetor Troubleshooting
May 30, 2014 | Mantis 2-Cycle Tiller
Motor runs on full choke only
could be slow running or mixture jets blocked give carb a good clean out
May 10, 2013 | Garden
Steering locks when turned ti extreme left or right
If your steering lock when turning extreme is because the ETO busher on the front axle is wear out. Try replacing it. It is on the end of the axle.
Thanks.
Jul 18, 2011 | Cub Cadet Riding Lawn Garden Tractor 25hp...
How do I tighten a loose tiller on the hs 580 mobility scooter?
The generic steps involved are :-
1.Locate the knob on the base of the tiller. Turn the knob counterclockwise to loosen the bolt.
2 Adjust the tiller to the desired position. Push it forward or pull it backwards until you achieve a comfortable steering position.
3 Tighten the knob on the base of the tiller. Turn the knob clockwise to tighten the tiller on the scooter.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 02, 2011 | Ctm Economy Scooter 4 wheel
My tiller will only idle with the choke on once I open the choke it dies out. I just replaced the diaphrams and gaskits but it won't idle without the choke. I attempted to adjust the mixture screws but...
If it has been sitting for a while empty fuel tank. Prepare fresh fuel/oil mixture to fuel tank. Add two ounces of 100% acetone (available at Walmart) and attempt to start several times. Let sit for several minutes. Repeat until it acts like it wants to start.
Then watch this video and do it:
http://www.alamia.us/mantis_parts_s/148.htm
Never let tiller sit with fuel for any prolonged period of time. Run it out of fuel before storing or sitting. Acteone will remove varnish from inside.
Oct 21, 2010 | Mantis Tiller
Tines run slow/stop even when engine is at full throttle
What is the task you are doing with the tiller? There are some uses where the tiller will stop.
Jun 16, 2010 | Honda 25cc 4-cycle Mini Tiller
Motor overheats and seizes.
what is your proper mixture?50:1?
Be sure you are mixing 2cycle oil to 1 gallon of fuel or whatever it takes to make this ratio
My reccomendations are run 40;1 3.2 OZ OF OIL TO ONE GALLON OF GAS
also you may have a lean out condition and the H on the carb, may need to be ritchened a little
Motor should not be screaming you should have a slight blubber when throttle is held wide open
May 25, 2009 | Mantis 2-Cycle Tiller
Boating Logo
144 people viewed this question
Top Boating Experts
ray gallant
Bill Boyd
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
