My DVD player stop in the final part of film
My DVD player ( TELESYSTEM TS5.3VX ), show the film, but at 10 minuts from end, stop it, freezen image, and doesn't go over.
If I repeat, or play at 20x speed, the film stop in the same scene.
This for all DVD/films (non self writed, but original dvd purchased).
How to resolve?
I have open the case, and viewed that laser try to read versus external part of disk, an repeat more times, then stop, and last image stay frozen, alwais the same, for every film.
  • realmeteo Apr 22, 2009
    I have already done it, but doesn't resolve.
  • Lutte Lenzer May 02, 2013
    I have the same problem - sharp bdhp21s
  • 3,866 Answers
Try cleaning the DVD if there is scratches use a scrstch removal cleaning system or you can take it to a video store and most likly they will clean it for free for ya. if the DVD is free of scratches/dirt clean the player with a DVD cleaning kit.
Posted on Apr 22, 2009
I cannot play burned dvd's from this system in other dvd players becahse I cannot finalize the dvd. How do I finalize?
The recording may have used all the media on the disk because you let it run until it was full.
Now, there is no room to finalize the disk.
Play this back on the machine where it was recorded while recording it to another DVD recorder..
This time, BE THERE to stop the recording.
Set the recorder to a speed that leaves at least 10 minutes extra space for finalization.
Jan 31, 2011 | Pioneer DVR-RT500 DVD Recorder/VCR
Finalizing the DVD
Well this sounds like the disk was removed too fast from the camera before it had ended writing, you need to stop filming, wait at least 1 minute then remove disk because it ends the disk write not you yourself.
May 23, 2010 | Canon DC210 DVD Camcorder
I have a Magnavox ZV427MG9 DVD recorder. I follow instructions on how to finalize recorded DVD but it doesn't work. I set up to finalize at the beginning and it won't work. When I try to finalize at the...
what you do after you label the recording you play the dvd selecting the image and then play then stop it then select setup.
The instruction book doesn't follow through properly and I lost a dvd that way before I realized what it was after trying on a test DVD different things to get back to the setup screen that was supposed to have the finalize on it.
It's also a 1/4 inch to wide to fit on my shelf so it sits on top and blocks the remote sensor on the tv and makes tv control a bit difficult. The copies if you get them right at the fastest speed are very good though.
Many VCR's are protected from copy. Some start with that right away disabling the copy process others wait till thee film is half recorded. I understand some makes don't respect the copy proofing on tapes. I am not so experienced to say for sure that is so.
Feb 21, 2009 | Philips Magnavox DVD+R/+RW Recorder/VCR
Finalizing dvd
Unplug the device from the outlet and wait 15 seconds before plugging back in. This will reset the device and stop the process, but it will not complete the process so you will have another incomplete dvd. Once you plug the device back in, you should be able to open and remove the disc and all functions should be back to normal. Let me know if you need further assistance.
If you do not mind, please rate my help I would greatly appreciate it.Thanks
Aug 14, 2008 | Panasonic DMR-EZ17 DVD Recorder
Dub VHS to DVD
I am not sure why the DVD recorder is stopping after 25 mins of recording. However, once a disk is finalized all the remaining space is unrecordable. That is why your computer is showing the disk as full. The same applies when finalizing a CD. As for the first problem, check to see what record speed you are using. XP is 1 hr, SP 2hr and so on. But stopping after 25 minutes is weird. Even if you use a quick record button, (aka OTR) the recording is usually done in 30 minute increments. Try it again. If it still is only recording for 25 minutes, you may want to contact the manufacture's customer service or tech support. Hope it helps.
Mar 23, 2008 | Zenith XBR716
Centrios 1611304 Can no longer finilizing DVD !!!
Before you attempt to finalize, press the stop button 3 times. This will stop the disc from spinning in the tray. Then attempt to finalize from the menu. Sometimes this will not work, depending on your chosen brand of media. Some media just won't finalize (even if they are from the same package of discs that do finalize properly). I don't know why this recorder is so fussy about the media - sorry!
Dec 21, 2007 | Centrios EDW8020 DVD Recorder
Not recording a full film
1. Insert disc.
2. Press "DVD" button on remote.
3. Press "REC MODE/REC SPEED" button.
4. Keep pressing until desired recording speed.
I believe your problem is that the movie exceeds the 120 minute limit on the target disc at the default recording speed (SP). Try LP instead.
Nov 18, 2007 | Sharp DV-RW340U DVD Recorder/VCR
I cant view DivX Film Subtitle in Sony DVP-NS67P home DVD player
Hi Ramink..
Try the program Sub2Divx (I have the same DVD sony dvp-ns67p worked properly). It takes just 2 minutes to put the subtitle in divx and is not fixed, only appears when tight subtitle on the remote control. I have a link to a tutorial but it is in Portuguese. (http://www.forumpcs.com.br/viewtopic.php?t=195697)
[ ]'s
Ricardo Liu
Oct 07, 2007 | Sony DVP-NS575P DVD Player
Samsung R155 Recording from VHS Issues
The reason why you are having this problem is because you haven't finalized the disc. In able for you to play that Burned DVD that you have you need to Finalized the disc. Finalizing a recordable optical disc means writing the disc's lead-in (the Table of Contents or TOC) and lead-out information (blank data that fills up the unused space at the end of the disc) so that a DVD player will know where the various tracks begin and end. Without the TOC, a conventional DVD player will not be able to read the contents of the disc. Once the disc is finalized, no more information can be written to it. Finalizing takes about two or three minutes. To finalize a DVD-RW/DVD-R: 1. Press the Menu button with the disc stopped. 2. Select Disc Manager and press Enter or the right arrow. 3. Select Disc Finalize and press Enter or the right arrow. You will be asked twice if you are sure that you want to finalize the disc. Select Yes and press Enter. Once the disc is finalized, you cannot delete entries from the record list. After being finalized, the DVD-R/DVD-RW (video mode) operates in the same manner as a DVD-Video. Recorded discs must be finalized in order to play back in non-Samsung DVD players. A DVD-RW disc that has been recorded by DAO (disk-at-once mode) in a PC cannot be unfinalized. A DVD-RW disc that has been recorded in Video Mode on a non-Samsung recorder cannot be unfinalized by a Samsung recorder. A DVD-R disc cannot be unfinalized. Note: Finalization does not apply to DVD-RAM. If you cannot finalize a DVD-R or DVD-RW disc, make sure that Disc Protection is turned off. If you are still having difficulty, you may try calling technical support of SAMSUNG. Note: Do not turn the recorder off while it is finalizing the disc. Data on the disc will be damaged if the finalization process is interrupted.
Sep 17, 2007 | Samsung DVD-R155
Televison & Video Logo
178 people viewed this question
Top Televison & Video Experts
Electro Med Services...
