Question about Sony VPL-CX85 Multimedia Projector
Menu flipped on screen
Hi Guys, Can I flip the menu on a CX85 or CX 86 when I am running it in a flipped horizontal mode. I am not rear projecting. I am running a mirror image of the same image on two projectors. cheers Andy
  • larkrise Apr 22, 2009
    Hi Nic,
    I'm fine with inverting and flipping the image.
    My question is 'if the image is flipped horizontally or vertically the menu is also flipped. eg the text is reversed.'
    This is fine if you rear project but when they sit side by side and one is flipped the above menu problem appears on the one that is flipped. In this case, horizontally.
    Do I remedy that in the menu settings?
    cheers
    Andy
    Hi M8 and Nic,
    Thanks for the info.
    I'll have a look at the full manual and see if I can come up with a workaround.
    cheers
    Andy
    President:
  • 1,073 Answers
Hi Andy!
Yepp, you can do that, each and one of your projectors have separete settings. So you can run one hanging from the roof and the other one standing on a table if you want. How the picture is showing depends on how you set up the the settings in the specific projector. The the signal that comes to the projectors are always the same, its only the settings on the projector that can change that.
Good luck
Nic
Posted on Apr 22, 2009
Words are showing backwards
Your projector has been set up for rear projection - you need to change it to front projection. Access the setup menu, then use the option to flip the image horizontally. Viewing the image in a mirror may make it easier for you while navigating through the menu options
Mar 27, 2014 | InFocus Office Equipment & Supplies
Need to know how to invert a picture on a epson projector
You didn't give your model, but on the Epson I have (a PowerLite S1), the projection mode is controlled through the "Settings" menu. This may not be right for your model, but I'd think another Epson would be similar.
On mine, this is how it works:
1) Press "Menu" on the projector (or remote, which will work the same way)
2) Use the "V" (down arrow) to highlight "Setting"
3) Press "Enter" to select the "Setting" menu
4) Press "Enter" to select the "Screen" sub-menu
5) Down-arrow to "Projection" and press "Enter" to select it
6) Use the up- and down-arrows to highlight the arrangement you want from the choices offered:
  • "Front": normal use
  • "Front/Ceiling": image is vertically flipped
  • "Rear": image is horizontally flipped
  • "Rear/Ceiling": image is flipped both horizontally and vertically
7) Press "Enter" to select
8) Press "Menu" to exit the menus
I hope this works for you, or at least gives you a starting point. Good luck, and thanks for using Fixya!
Apr 23, 2011 | Computers & Internet
Image is upside down on the screen
Alot of projectors (being all projectors that are designed to be hung from a roof) have an image flip function. This is because when you install a projector in a roof you have to flip the projector upside down so the projector doesn't have to be pointed down and doesn't cause any problems with keystoning.
If you have just bought a new projector and installed it in the roof or perhaps bought it second hand and are projecting from the floor (when the previous owner may have had it in the roof), you will need to go through the menu screen until you find this setting. I don't know exactly what Epson call this function but it should be in there somewhere. If you have it on the floor you want image flip off, if you have it in the roof you want vertical image flip on, horizontal image flip is for when your projecting onto a special screen surface from behind the screen.
Mar 24, 2011 | Epson PowerLite 3LCD Projector
My project image is flipped horizontally on the screen, but displays normally on my laptop. How do I fix my projector image?
The projector may have a menu function for flipping the image dependent on whether it is merely set on a desk, or mounted upside down on the ceiling. See the manual, printed or online.
Feb 02, 2011 | ViewSonic PJD6211 Projector
How can i mirror image on the ce100, the directions in manual are not working. are there updates to capibilities?
As far as I remember there was no function "Flip hor./ver." in Futura 1.0.0.x. You could upgrade your software to version 2.5.0.x which is working with ce100/200 sewing machine models and contains functionality as newer models have. In this software version you will find function "Flip" in the context menu of Select mode (select design or color blocks you'd like to mirror, click right mouse button and select in the menu "Flip horizontally" or "Flip vertically").
Jan 31, 2010 | Singer CE-100 Futura Computerized Sewing...
How to print mirror image with Cannon Pixma ip2000
  1. Click the Printer and Paper tab.
  2. Under Paper, in the Size box, select Letter.
  3. Click OK.
  4. Do one of the following:
    • If your design is a picture, clip art, or WordArt, flip it horizontally.
    default.aspx?assetid=za790050011033How?
    1. On the Arrange menu, point to Rotate or Flip.
    2. Click Flip Horizontal.
    • If your design includes text in a text box or table, turn it into a picture first, and then flip it horizontally.
    1. Select the text in the text box or table in your design.
    2. On the Edit menu, click Cut.
    3. On the Objects toolbar (toolbar: A bar with buttons and options that you use to carry out commands. To display a toolbar, click Customize on the Tools menu, and then click the Toolbars tab.), click Insert WordArt default.aspx?assetid=za060452451033.
    4. Under Select a WordArt style, click a style, and then click OK.
    5. Press CTRL+V to paste your text into the WordArt Text box.
    6. Format the text, and then click OK.
    7. If necessary, resize the WordArt, or use the WordArt toolbar to format it, and place it in the design.
    8. Select all the objects in the design, including the WordArt.
    9. Click Group Objects default.aspx?assetid=za060447801033.
    10. On the Arrange menu, point to Rotate or Flip, and then click Flip Horizontal.
  5. Print your design on plain paper first to make sure it looks the way you want it to.
  6. Make any adjustments to your design after seeing the test printout.
  7. Make sure thermal t-shirt transfer paper is in the printer.
  8. On the File menu, click Print.
  9. Select the options you want.
  10. Click OK.
Source
Cheers
Jun 20, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Changing settings
Hi cajun51man
If you go into the User Menu of the Projector look for a subfolder that reads either Flip Image or Mirror.
Scroll down to it and scroll left or right - this will switch between the image features.
May 26, 2008 | Sharp Notevision XG-C50X Multimedia...
LG SCREEN RUNS BACKWARDS
in your menu there is a couple of options, one for use with mirror that flips the picture, another that flips the pic for mounting upside down. and another for flipping it upside down with mirror.
please select normal in this option as your prob just mounting it on a desk or table.
good luck
Apr 25, 2008 | LG RU-52SZ51D 52" Rear Projection...
Sony VPL-CX85 Multimedia Projector Logo
154 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
