Speed is not recording
Hi, my computer just stopped recording today after working for about two weeks. the computer still has power, however will not pick up the speed. I have moved the sensors to 1mm apart and this has not worked. Any ideas of what may be wrong
  • Herminio Halili, Jr.
    Herminio Halili, Jr. May 11, 2010
    please indicate or a detail what component of the computer you having a problem, cd / dvd writer? or the computer (pc cpu) itself.
  • 375 Answers
You need to be much more specific about the make, model, operating system, application or hardware that is at fault.
"Speed is not recording" does not make any sense whatsoever.
Speed is a rate or a measure of the rate of motion
You have said efffectively the same thing as if you had said "52 km/h is not recording"
Be much more specific about your problem and make sure you put it in the right area.
Posted on Jul 31, 2009
Am in process tranferring vinyl to cd using sony compact disc recorder and not computer,ran out of audio discs last week purchased some verbatim discs high speed rw but will not work on my machine can you...
Hi raymackie265
You are right , don't use cds for computer ( cdroms ) but well audio cds . Pay attention to this point when purchasing new stuff . Regarding the issue with cd-Rw , it's a compatibility issue with your Sony device and you need to check if the recorder will accept CD-RWs . If yes ( and it should be yes ) , try to find lower speed discs but you need to find audio cds . I ' m using a Pioneer recorder and it works fine with any kind of audio cds , not with cdroms .
Best regards ,
fanaudi .
Aug 30, 2011 | Verbatim 10PK CDRW 80 MIN 700MB 4X12X...
Have Panasonic omnivision VHS PV-D4743S-k 4 head Hi Fi stereo and am having problems setting the timer. Could you help please?
To set the time do the following:
Press PROG*
to display Program.
To set record DATE,
press
to select:
1~31= one time, or
DAILY= MON~ FRI, or
WEEKLY= same time
each week and
press SET.
To set remaining items,
press
to select and
press SET
to set START/ STOP times,
CH (channel) or LINE
input (p. 35), and tape
speed (SP, LP, SLP).
Press PROG
to end programming.
To Enter More Programs,
press
to select and
press SET
to set an unused program
number, and then repeat
step 2.
Or
Press PROG
to exit.
The “Timer” Indicator lights up on DECK.
• You can do Timer Recording with the power on or off.
• “TIMER REC WILL START SOON” appears on-screen for 2 minutes
before Timer Recording starts. If DECK is in DVD mode, no message
appears, but the VCR REC Indicator, the VCR mode indicator and
“REC” will flash on Multi function Display.
Hope this helps!
Brad Nelson
Mar 17, 2008 | Televison & Video
The HVAC blower fan on my 2001 Pontiac Aztec stopped working on settings 1-3 several weeks ago. Last week it stopped working at setting 4 and today it stopped working all together. What is the most likely...
the blower not working on settings 1-3 is the blower motor resistor. this limits the power provided to the blower motor itself to change the speed. at setting 4 it is getting full power. since it quit on 4 also, i would still say the resistor needs to be replaced first, then see if the blower comes back. you may also need a blower motor. if you have a voltmeter you can just turn the switch to 4 and see if the motor is still getting 12 volts. if it is and doesn't run, it needs a blower motor too. if it's not, then its just the resistor
Feb 24, 2010 | 2001 Pontiac Aztek
Last week the heater blower motor stopped working on intermediate speeds and would only work on high. Today after working for a little while on high I lost all speeds of the blower motor. Is it the switch...
resistor for sure, the switch would have caused all speeds to fail as it only has one moving contact but the tapped wirewound resistor is a common part for this fault.
Jan 13, 2010 | 1995 Chevrolet C1500
The fan in my truck only turns on on high speed.
A bad blower motor resistor will cause it. It is located ny the blower motor p.s. below dash.
Sep 28, 2009 | 2000 Chevrolet Silverado
LG HDD DVD Recorder remote control not working with LG TV
I have a rh 265 remote and lg tv. It stopped controlling the tv. I hold the tv power button down on remote then pushed 1 at the same time. It reset it to work with my tv.
May 29, 2008 | LG DE9523P DVD Player
Weekly timer recording not working
Have you tried setting the clock to manual mode: Page 18 in the manual I think.
Jun 30, 2007 | LG DBRH197H DVD Player/HDD Recorder
DVD problem
I've had the same problem. Are you using x8 DVD-R? I had no problems with the old x4 discs, but had the (long) Self Check process and a failed dubbing occur between 1/100 and 2/100 in the dubbing process with the x8 discs. I've found two workarounds: 1) The problem doesn't seem to occur if the recordings are made with hi-speed dubbing enabled. I do this now as a default, but the loss of the ws tag is a pain . If I still get a dubbing failure with hi-speed dubbing, a quick power down/power on of the unit seems to rectify the situation. 2) If you record a "leader" in hi-speed dub mode of a minute or two, and dub it onto a x8 DVD-R first, you can then copy non-hi-speed dub recordings onto the disc. Not quite sure why this works, but it does - it's like the first minute or two being dubbed over needs to be hi-speed enabled to be written from the memory of the E-85 to the disc, but once that's done it dubs as it should. btw, another process that crashes the unit is if you try an change the thumbnails on a x8 DVD-R. Not the end of the world but again annoying on expensive equipment less than two years' old. DVD-RAMs are not affected by the problem in my experience. Apparently there's some firmware in the US that addresses the problem with x8 discs - http://www2.panasonic.com/webapp/wcs/stores/servlet/vDownloads?storeId=15001&langId=-1&page=DVDFirmware , but Panasonic UK don't distribute it. I think the E-85 is a good box but it has proven too buggy and I'm thinking of upgrading it, possibly when the new 85 is released by Panasonic in a few weeks. Good luck
May 14, 2006 | Panasonic DMR-E85H DVD Recorder
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
