Question about Marantz SR-5200 Receiver
Total loss of sound...what to do?
Been using my marantz sr-5200 for awhile with no problems. Recently began to make occasional popping/hissing noise then would stop. Now getting no sound at all on any setting. Power is on, lights function...but no sound. Fuses all appear ok. Any ideas?
  • pyxl Sep 23, 2007
    Oh, yeah..tried unplugging it..letting it rest (reset) overnight. No help.
  • ibantxo28 Dec 28, 2008
    I have the same problem. It does not matter the input selected (analog, optical digital, coaxial digital): sometimes the Receptor starts outputing pops, noise... I have tried everything. I think it is a hardware failure.
    The problem is that not always happens... so I cannot send the device for reparing...
  • 682 Answers
Please repeat your setting first- and then disconnect all speaker out.
connect your speaker one by one until you find the bad one and change it-you can also apply contact cleaner spray over volume control and move it many times-please do not forget yo unplug headphone jack first.
Posted on Jul 06, 2008
Marantz problems
my sound on my marantz av surround receiver sr5003 stopped working, i need help to restore it:
Jan 01, 2014 | Televison & Video
My marantz sr 5200 has stuck in "Mute on" situation
Your mute switch has been broken some how,End will have to be replaced.
Oct 11, 2012 | Marantz SR-5200 Receiver
No surround modes produce any sound . only have sound on s direct mode. marantz sr 5200
Not having the ability to look at it on the bench, more than likely your DSP chip is bad. If you have a local repair house that is willing to confirm that is the problem without charging you an arm and a leg, that's your best bet. It is an expensive repair, anywhere between 300 to 500. At that point, I would say to replace the unit. Sorry for the bad news, but that's my "best guess" The only other thing to check would be your "Audio input Settings" Make sure it's either on "Auto" or whichever type you are using. "Digital Coaxial", "Optical", or "Analog" (RCA) hope this helps! If you have any further questions, just post a reply and I can help further. Best of luck!
Jun 03, 2010 | Marantz SR-5200 Receiver
My marantz sr5200 dont reproduce dobly digital signals , maybe junt 2 channels.
I have the Marantz SR5200, unable to get the Set-up / t.tone button to work, don't have the instructions,
Mar 19, 2010 | Marantz SR-5200 Receiver
Hi ,Marantz SR7200 , i am getting an audible hiss on phono inputs and digital optical inputs . If a connect something to the front phono inputs , however there is no hiss , any ideas ? Thanks in advance .
if your hooking up a phono input lead to a digital input lead it won't work analog and digital totally different setup. when you connect the leads up it just kills the input amp so there is no noise.
Jul 10, 2009 | Marantz SR-7200 Receiver
Hissing noise
This is mostly caused by the speakers being turned up causing feedback. If you use headphones it should eliminate this problem.
Hope this helps. Bud
Dec 01, 2008 | Logitech QuickCam Webcam
Marantz SR-5200 - Analog inputs only play the right channel
please invert your cable and watch if the problem moved the problem in your cable change it with new one.from any radio shack near you or any electronic store.
Jul 05, 2008 | Marantz SR-5200 Receiver
SR-5200 owners manual
Jun 26, 2008 | Marantz SR-5200 Receiver
Statics and hissing...
I also have the same fault, The static noise is coming out
of ic720 [ cs4391 or cs4392 ]on digi pcb which is D-A converter
this ic maybe faulty, i have ordered a replacement ic and will
post here if solves problem
Dec 10, 2007 | Marantz SR-5200 Receiver
Loss of volume on left channel
Marantz SR 5200/6200 lost audio or crackling on left or right channel except in mode s-direct is now fixed !
The root cause is a defective inegrated circuit on DSP board (the one with digital inputs). To fix it change the chip CS4391 by a new one or better by the improved version CS4392. On my device a capacitor was cut close to this IC : replace one 1uF after changing the IC. For any question search me with my callsing "F5RCT"; i have a spare IC for the one who is able to change it !
I'm amateur radio and engineer
Oct 15, 2007 | Marantz SR-5200 Receiver
Marantz SR-5200 Receiver Logo
487 people viewed this question
Top Marantz Audio Players & Recorders Experts
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
