Inability to remove wrong-sized ink cartridges from Canon Pixma MP780
I have a Canon Pixma MP780 (5years old). I have unwittingly loaded the wrong sized ink cartriges into the printer and now cannot get them out!! The screen keeps saying 'Wrong cartridges'. But when I try to have the carriage return to the centre to unload the bad cartridges, it wont return to the middle no matter what I do. The carriage holding the ink cartridges stays to the right side of the machine. If I could centre it I could get the cartridges out and put the new ones in. The machine was fine until this. Can you help? Trish
    Brigadier General:
  • 8,619 Answers
Hi
Please take a flat head screw driver and insert it between the carriage and the cartridge then try to pull out the cartridge. If it still doesnt come out then you will need to disassemble the printer and then get the carriage removed and replaced . Using too much force and pressure can cause the carriage to break . Please check this link for user manual for further assistance:
Canon Pixma MP780
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Posted on Apr 24, 2009
How to remove ink?
Depending on the exact Canon Pixma model (there are many, for example, Pixma MX340, Pixma MP280, Pixma MG3220), the method varies.
Here are three YouTube videos on how to change the ink of 3-different Canon Pixma printers:
Changing Ink Canon Pixma MX340
Canon Pixma MP280 How to replace printer ink cartridges
Canon Pixma MG3150 How to set up and install ink cartridges
Jun 06, 2014 | Canon PIXMA Office Equipment & Supplies
Please describe your what size ink cartridge do i need for pixma mp160 printer problem:
The following cartridges are compatible with Canon MP160:
Canon PG 40 Black Ink Cartridge Black Ink Cartridge
Canon PG 50 High Capacity Black Ink Cartridge
Black FINE Cartridge, High Capacity
Canon CL 41 Tri Color Ink Cartridge
1 Cartridge of Cyan, Magenta, and Yellow
Canon CL 51 High Capacity Color Ink Cartridge
Color FINE Cartridge, High Capacity
Nov 23, 2010 | Office Equipment & Supplies
HOW TO REMOVE E5 EARROR
make sure you removed the orange tape from the cartridge.
usualy E5 is when the color cartridge is faulty but if the orange tape is on the cartridge it will show E5.
if you removed the orange tape an it still shows E5 go with the cartridge to the store where you purcess it for excange.
Nov 18, 2010 | Canon PIXMA MP150 All-In-One InkJet...
How to refile the cartridge of canon pixma ip1300 printer
Instructions :
  1. Remove the old ink jet cartridge from the printer following the manufacturer instructions. Close the lid on the printer to keep it free from dust and debris while you are refilling the Canon ink cartridge.
  2. Locate the ink tank on the cartridge. Put a 3mm drill bit in a drill. Drill a hole in the top of the ink tank on the cartridge.
  3. Gently insert the needle on the bottle of ink into the hole you just drilled in the ink cartridge. Avoid squeezing the bottle until the needle is completely inserted in the ink tank.
  4. Squeeze the ink bottle gently to refill the cartridge. Fill the tank with a little at a time until the cartridge is full.
  5. Remove the needle from the ink tank. Wipe the top of the Canon ink cartridge off with a paper towel. Place a small piece of duct tape over the drilled hole. Rub the tape to remove air bubbles and to make sure it adheres to the cartridge.
  6. Put the refilled ink cartridge back into the printer. Clean the head of the printer by running the printer software and following the instructions for head cleaning.
Good Luck!
Aug 28, 2010 | Canon PIXMA iP1300 Printer
Pixma i1200 it says cartridge is in wrong try several times also bottom light flashing
u may need to buy canon ink cartridges as some printers will not take generic ink or check to make sure u bought the right size for ur printer
Jul 26, 2010 | Canon Office Equipment & Supplies
Cant load the printer cartridges for the pixma mp190
If you are trying to figure out how to load your ink cartridge in you Canon Pixma follow these instructions.
Make sure you printer is powered on. Open the top cover including the key display.
  • Step 2 Allow the ink return to move to left and stop. Remove the old cartridge which should have a 40 Black or 40 color on it by pushing down and popping it out of the holder.
  • Step 3 Now open your new ink cartridge and tear off the protective stip from the ink cartridge.
  • Step 4 Place the new ink cartridge in at a downward angle and then push into a straight position by pushing the bottom into place.
  • Step 5 Close the top an allow for the printer to adjust into place. Do a test print to make sure the printer is working correctly.
  • Step 6 If you experience an error message refer to your canon guide book for troubleshooting tips. Be sure your new ink cartridge in placed in correctly. Should be next to the other ink cartridge in same alignment.
  • Mar 22, 2010 | Canon PIXMA MP190 All-In-One InkJet...
    How to load new ink into printer Canon Pixma 620B ? Thank you!
    Step 1.
    Open the hood of your printer; if the ink cartridge holder does not slide into view, check to make sure the printer is turned on.
  • Step 2 Remove any empty cartridges from the ink cartridge holder and dispose of them properly. Some Canon printers have a protective cartridge lid that must be opened before you can change a cartridge.
  • Step 3 Remove all protective tape and plastic film from the fresh cartridge. Canon uses a bright orange protective tape on its ink cartridges. Some Canon ink cartridges also have a bright orange protective cap over the ink nozzle that must be removed before installation.
  • Step 4 Insert the new cartridge into the ink cartridge holder. Tilt the cartridge up slightly and insert end-first into the proper slot; push down gently on the cartridge to lock it into place. Some Canon printers have an indicator light that will activate when the cartridge is firmly installed; other models have a cartridge cover that will lock into place when closed.
  • Step 5 Close the hood of the printer. The printer will indicate when it is ready for use with a message on the LCD screen or by blinking the LED indicator light.
  • Jan 22, 2010 | Canon Office Equipment & Supplies
    I changed ink my printer showing wrong cartridge
    Make sure you are using factory new Canon ink cartridges.
    If you purchased re-filled cartridges or third party cartridges that is most likely your problem.
    Don
    Jun 14, 2009 | Canon PIXMA MP130 All-In-One InkJet...
    Can't load ink cartridges for PIXMA MP780 printer
    Are you using OEM cartridges or refills?
    If you still have the old cartridges, put them in and see if the PC gives you status for the empty cartridges. If the system correctly statuses the old cartridges, check that the new cartridges the correct ones for your printer.
    May 02, 2009 | Canon PIXMA MP780 All-In-One InkJet...
    Ink cartage
    This printer will take either the PG-30 or PG-40 (larger size) cartridges for black ink, and either the CL-31 or CL-41 (larger size) cartridges for color ink.
    Jul 26, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
    50 people viewed this question
    k24674
