Question about Compaq Computers & Internet
Trying to open DOS,it goes to restart mode
Unable to detect Audio device & goes in restart mode when trying to open DOS.
  • Maurice B Thomas
    Maurice B Thomas May 11, 2010
    I sure would like to help you with this one as DOS is a specialty, but I gotta know what OS you have on your Compaq®. Also has there been any system interference that seems suspiciously viral, or is your system subject to various corporate type security measures?
  • 371 Answers
Posted on May 08, 2009
  • 700 Answers
Is that windows dos? Or DOS that usually booted from a cd rom?
If this is windows DOS,seems to me a viral activity. It is commonly a symptoms of infection.
Leave additional info.Tnx
Posted on Apr 22, 2009
Desktop pc, trying to open attachment on email. file ends in dll. cant find program to open it. tried microsoft, said cant run program on dos mode. can you hep me?
There is a virus problem, you must work full scan of the device and clean it and then restart the machine again.......
Oct 02, 2013 | dll-files.com
ML 2240 printer not detected by Windows 7
Try installing it in safe mode.
To go to safe mode, do the following:
Restart and tap F8. Use the arrow keys to highlight safe mode with networking and hit enter. Install the driver from there and follow the on-screen instructions.
If no go, check the device manager of any question mark. There might be some outdated drivers that cause this problem. You can use RadarSync (free version) to scan your computer for outdated drivers.
After fixing all driver related issues, try installing the printer again.
I hope this helps!
David
Feb 25, 2013 | Samsung ML-2240 Laser Printer
It says unable to format and shows infinite symbol and more over it does not even delete the files from the card
if you are using it on a device like camera, try to format it through the device. if that does not work, try to format it using DOS mode in your OS and make sure none of its contents are opened. hope it helps
Apr 16, 2011 | SanDisk 1GB microSD Memory Card
The device has been detected but it is unable to open leaving an error message to insert a device even unable to format even in dos mode
control panel admistrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver or
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Jan 06, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to fix faulty hard drive?
Are you able to detect the hard drive in BIOS and windows? If yes format it and run scandisk/chkdsk to fix.
Jun 22, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
Operating system not working
I think you need to open it in dos Mode.. You have to restart it PRESS F8 when restart is starting And select open in command prompt ...
NOTE:You have to go BIOS option for selecting boot from USB too (To enter DOS mode you may press DEL key /F2 when booting is abt to starting or in progressing)
OR format XP using Xp cd
OR insert any boot able cd(strongly recommend that it can possible to enter in Dos MODE{Win 98 CD is ready to enter in DOS mode}) Now you can change to any Drive even USB By using command CD space drive letter
Mar 28, 2010 | Computers & Internet
My laptop unable to give sound out put why? it was running on windows 7 trail version, i bought my laptop with operating system on dos command is that any reason i cannot get right sound,get me some...
  • Hi, these instructions will help you with the Audio problem. These are the steps to setup and 'restore' the “Audio Drivers2_bing.gif" "Start" button, go to and click in the (right, pane) Control Panel. Scroll to find the Sound category; select “Audio Devices, and Sound Themes” click, “PlaybackNext, click on the Active "Speakers,” select “Configure” to "Audio channels." The (Speaker Setup) "wizard,” appear! Select (Test) click, Next, adjust "sound" (Level). Select the Enhancements button make changes. Open the Controller Information (block), open the Properties to "update" Drivers. Check to see if Device usage: (enable) if not?" Enable it. *Note: “After making all changes, click 'OK, 'Save," and apply!” before exiting. To finish: Restart the computer. “If the solution help ratings it is appreciated, thanks
Mar 20, 2010 | Toshiba Satellite Pro L300 Notebook
Device detection
Need to check bios first for any on board sound auido devices that are enabled and disable it. Try to restart windows and see if detects. If it doesn't work then try to move the sound card to another slot on motherboard and restart computer.
Aug 09, 2008 | Aureal MTC Vortex Advantage PCI Sound Card
Unable to load
How to get to a MS-DOS prompt.
Reason: If Windows or the computer is not operating properly, it may be necessary to get to a MS-DOS prompt to diagnose and to perform additional troubleshooting on the computer.
Solution: MS-DOS users
Windows 3.x users
Windows 95, 98 and ME users
Windows NT, 2000 and XP users
Windows Vista users
Other PC Operating System users
MS-DOS users If you are running MS-DOS with no other operating systems, the computer should be booting into a MS-DOS prompt automatically unless you have a shell or other program loading automatically. If the computer is not getting you to a MS-DOS prompt, reboot the computer and as the computer is booting, press the F5 key when you see the message "Starting MS-DOS" or the MS-DOS version. This will load the default standard MS-DOS. If you successfully get to a MS-DOS prompt and would like to prevent the computer from loading the program that is preventing you from getting to a MS-DOS prompt, or if you would like to fix possible error messages you may be receiving when booting the computer, edit the autoexec.bat and/or the config.sys files.
Windows 95, 98, and ME users If you are able to get into Windows 95, 98 or ME, you can get to a MS-DOS prompt by following the below steps.
  1. Click Start
  2. Click Run
  3. Type "command" and press enter.
This will open a MS-DOS shell. However, if you are attempting to troubleshoot an issue with the computer and are using Microsoft Windows 95 or Windows 98we suggest you restart the computer into MS-DOS. To do this follow the below steps.
  1. Click Start
  2. Click Shutdown
  3. Choose the option to restart the computer into a MS-DOS prompt.
If you are unable to get into Windows 95 or Windows 98 to get into a MS-DOS prompt, follow the below instructions (Windows ME does not have this option).
  1. Reboot the computer
  2. As the computer is booting, press the F8 key when you hear a beep or when you see "Starting Windows 95" or "Starting Windows 98". Windows 98 users sometimes may find it easier to press and hold the left CTRL key as the computer is booting.
  3. If done properly the user should get to a screen similar to the below screen.
Microsoft Windows 95 Startup Menu
============================= 1. Normal
2. Logged (\BOOTLOG.TXT)
3. Safe mode
4. Step-by-step confirmation
5. Command prompt only
6. Safe mode command prompt only
Enter a choice: 1
F5=Safe Mode Shift+F5=Command prompt Shift+F8= Step-by-step confirmation [N]
4. Select the option for Safe mode command prompt only.
Windows NT, 2000, XP, and Vista users If you're running Windows NT, 2000, or Windows XP and need to get to MS-DOS prompt follow the below steps.
  1. Click Start
  2. Click Run or click in the "Start Search" field if you're running Vista
  3. Type "cmd" or "command" and press enter.
Additional information about the difference between "cmd" and "command" can be found on document CH000395. If you're attempting to get into a MS-DOS prompt to troubleshoot the computer boot the computer into safe mode. Additional information about how to get into safe mode can be found on document CHSAFE. Windows 2000, XP, and Vista users who are unable to boot the computer into Normal Windows mode or Safe mode can also enter the recovery console to manage their computer from a prompt. Additional information about how to do this can be found on document CH000627. Finally, if you are experiencing issues getting into Windows NT, 2000, or XP, it may be necessary to run troubleshooting steps from a MS-DOS prompt. It is recommended that the Network Administrator get into the MS-DOS prompt by using either a standard MS-DOS boot diskette (note: will not be able to access data using a standard MS-DOS bootable diskette) or the ERD diskettes created after the installation of Windows NT, or boot from the Windows XP CD.
Index
Category:
MS-DOS Q&A
Companies:
Microsoft
Related Pages:
MS-DOS
Safe Mode
Resolved
Were you able to locate the answer to your questions?
Dec 06, 2007 | Microsoft Windows XP Home Edition
Computers & Internet Logo
153 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
