Question about Nokia N82 Handheld
N82 - general lagging
The last few weeks I've seen my n82 to turn from a well functioning decive to an inanimate object perhaps more suitable to use as a hammer.
The response time for the phone's functions is ridiculously long, often taking 30 secs to open an incoming sms. This behaviour is pervasive for most of the phone's features, but especially when opening/executing features (closing them down or, for instance, entering digits or other non-demanding tasks, is on the other hand hardly affected at all).
My firmware version is: V 20.0.062
  • Nokia Expert
  • 141 Answers
My phone isn't very well, so I wanted to find an app to clear junk and cache, now I found it! That's LEO Privacy, it uses a little storage, and with it, I also make my phone light. LEO Privacy Applock Boost Hide Android Apps on Google Play
Posted on Oct 14, 2016
  • 436 Answers
The hanging of your phone may be due to very low phone memory or due to virus attacks.So check your phone memory and delete unnecessary files.
Posted on Sep 16, 2009
Expant Shield does not connect anymore. One day it worked fine and since about a week it does not connect anymore. No changes to location, computer, internet connection, etc. Possible that my ISP (I live...
That is a typical problem/issue. What happens is the ip block gets blacklisted and no longer works. All you need to do is wait a few days and it should work again. I think the longest I've seen it down lately is about 4 days or so. Hotspot is pretty proactive on fixing the connections so it usually is much faster. There are a few things you can try such as disconnecting, wait a minute and then reconnect to get a different ip. If the ip is out of the blacklisted range you should be able to watch the BBC/IT4 etc again right away. If not then about all you can do is wait and keep trying to connect. The disconnects I've seen recently are very short compared to when they first started. Those lasted weeks sometimes.
Oct 15, 2011 | AnchorFree Expat Shield
Turn the key and the car makes a buzzing sound but will not start lights are ok and radio plays. Last three weeks there seemed to be a lag when turning the key and the car starting
your battery is drained too low to start the engine. Has the battery light been on for a while before this happened? If yes, you probably need a new alternator. If no, perhaps the battery has gone bad.
Please see my tip at . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
Oct 24, 2010 | Toyota Camry Cars & Trucks
Wall mounted CBN30T, pilot goes out
IF its balance flue it could be blocked . Burner or orifice blocked lack of air to pilot slightly blocked thermocouple defective .
Mar 03, 2017 | Desa International CBN20T Heater
I also have the problem of pictures not in focus. I have made a point to lock in first by pushing halfway down before snapping the picture. It's ridiculous that a picture of an inanimate object is not in...
Set the camera on a firm surface or a tripod and take a few test shots...are they better? If so, that means that you are moving when pressing the shutter.
Oct 29, 2009 | Nikon COOLPIX L100 Digital Camera
I set the date and after one week he jump two days
You have a software problem but apply first code- *#7370# or *#7780# other wise contact your nearest mob-ph-repairing centre.
Aug 25, 2009 | Nokia N82 Handheld
Try *#7370# to set it to factory default. All your thied party SW and settings will be removed and your phone will become as if it is brand new. SO remove your card from it before you dial this code. Also set the profile as General.
Aug 05, 2009 | Nokia N82 Handheld
Whirlpool washer won't drain or spin.
Bra, thong sand coin or other inanimate object in pump. Easy fix. Check out the GUIDE
Jun 14, 2009 | Kenmore 22422 Top Load Washer
1998 Dodge 1500 Extended cab 4wd 5.9 Magnum motor Approx 115k miles. Mostly highway driving Check engine light, was coming on and then clearing by itself after a week or so. Started a few months ago. Was...
there may be a software update for the powertrain control module for mis-fire monitor. check with your local dealer. but if thats not the case,these engines are known at least in my experience of having the heads crack between the valves and cause mild mis-fires. try compression testing all the cylinders and performing a leakdown test on them as well.
May 12, 2009 | 1998 Dodge Ram 1500 4WD
PSP running slow
I'm not sure if there is a VHS menu on normal firmware, but if your running custom most likely the problem is your last update. Here is how to fix:
Click Select->Select CPU Clock XMB->Toggle To Default->Exit Menu
Because your PSP is running on something like 20/10 and lagging real bad it may freeze when you open the menu, if so turn your PSP off by holding the power button up and forcing the shutdown, keep trying until you can get the menu working. It will also not respond to your commands properly, when you click down it will move through like 3 options because of the lag, be patient wait till it lands on CPU Clock XMB and follow the instructions. Happy Gaming!
Mar 11, 2008 | Sony PlayStation Portable (PSP) Console
Nokia N82 Handheld Logo
162 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
