Question about Toshiba MV13P2 13 in. TV/VCR Combo
TV - Color Issues
After a bad storm knocked the power out, two of my four TV's have red & green in the corners and it isnt going away! As a temporary fix, I taped magnets in all four corners and the picture is fine. What could the problem be? Is there a more permanent fix?? (One TV is the Toshiba & the other is a Sharp - dont know the model #)
Unplug it and plug it back in. this should fix it
Posted on Sep 23, 2007
SOURCE:
Noisy jumping red pixels in the upper right corner
You are right, this is caused by a faulty power supply that gives you bad voltages. So it can get worse in time.
Oct 10, 2014 | Samsung PN50B860 Plasma TV
Apparently there was a bad lightning storm last night that knocked out our power. Bad thing is, when the power came back on our cable box won't turn on and neither will our tv. The tv power button just...
please call a specialist in that for assistance.
As of now and future: Follow what everyone says: "Turn off the modem and TV during a lightning storm".
Jul 25, 2013 | Televison & Video
I have a Gateway 310 XL H desk top PC. After the storm, Isaac, It won't power on. The red and green lights come on, the red goes off after a short time. The monitor flashes a manfacture logo then
The system is powered up if green light on, the hard disk is powered up if red-light on for a few seconds then goes off, but I assume it's not loading up after that. You have no output to video.
Try holding f2 or f4 to load default bios when turning on. If that doesnt work then That would point to me that there is a problem with either:
1) processor burnt out, or needs refitting following a knock to the case causing a bad connection.
2) ram burnt out or not correctly installed. Try refitting the ram or using a different combination of ram.
3. Bios chip burnt out. Sometimes you can literally see the chip is slightly melted.
4. Other motherboard fault, look for melted chip or damaged component.
5. Psu faulty or not connected properly. Check connections, or bench test with another psu.
Have you moved the pc recently? Sometimes dust builds up under processor or along ram, and when moving pc giving it a slight knock can cause bad connection. If dusty, remove clean and re install.
Hope it helps.
Sep 05, 2012 | Gateway 310 S PC Desktop
Change the colour
CLICK HERE for a PDF copy of your owner's manual.
Page 17 States to change the display color -
Setting the Multicolor Illumination
ILLUMI BLUE (Initial setting) / ILLUMI GREEN/ILLUMI AMBER /
ILLUMI RED
You can change the lighting color of the following four buttons:
SOURCE/POWER, BAND, (left << arrows) and (right >> arrows).
BLUE > GREEN > AMBER > RED > BLUE
• According to the lighting color of the above four buttons, the color
of the other buttons also changes. When the color of the four
buttons is AMBER/RED, the color of the others is AMBER. When
the color of the four buttons is BLUE/GREEN, the others are also
GREEN.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 20, 2009 | Alpine CDA-9847 CD Player
Screen has green corner at first and may changeto pinks and green
It sounds like the De-gauss circuit isnt working. It demagnetizes the TV tube.
It's something only a tech can fix though.
Jan 02, 2009 | Zenith C27V36 27" TV
Sony kd 34xs955 green color in corner of screen
Is their a speaker or something electronic or electrical near the tv? Move it away, if there is, and see what happens.
Jun 12, 2008 | Sony FD Trinitron KD-34XS955 34" TV
Loss of color after lightning storm
In tradition televisions, each color has its own gun, convergence and control circuit. One or more of these are most likely bad. Repairs on standard CRT TVs nowadays are usually cost prohibitive.
Jun 09, 2008 | Televison & Video
Color distortion
Move any speakers or electrical devices away from the set. It could also be anything electronic or magnetic. Anything near the set that generates a magnetic or electromagnetic field could be causing the distortion.
Jun 04, 2008 | Zenith A36B41W 36" TV
Color issues in the lower right corner
Unplug the set overnight and plug back in and turn the set on . If the spot goes away alittle then do this again. Up to three days > if that dosent fix the problem then you have a problem in the deguissing coil curcuit. Probably a cod joint on the thermister or a bad relay , a bad coil . Not a big deal repair. Good luck
Apr 24, 2006 | Sony KV-27S42 27" TV
Toshiba MV13P2 13 in. TV/VCR Combo Logo
79 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
