Not long after purchase my canon laser printer ran out of toner (or so it told me), I was surprised but still went and replaced it.Now again it but i also note that the message says ! No Toner Cartridge. Open the top cover and insert a toner cartridge. Which is impossible because there is a new toner that was working just fine a second ago. So i'm assuming no problem with toner cartridge but something with the printer itself. Any ideas Thanks
-   I have same problem as well.The printer was working fine for more than six months. Suddenly it is giving me the toner massage. I replaced the toner with an original new toner and the message never went away. I think I need to call the reseller as well. I have LBP 2900.-   whiletrue
Apr 01, 2009
-   I just bought it a week ago and have the same problem. When this error message popped up first time, I opened up the top cover and reinserted the same cartridge with couple of tries and it worked but only once. Then again I faced the same problem and never worked in one hour try. Well, I will contact the seller of this printer.
-   The same happens with my Canon LBP 2900-   Guest
Sep 10, 2008
-   i have the same problem in that I purchased a new toner catridge for the canon LBP printer howver now that I have inserted it it says open lid and place new toner catrdige even though i have. any ideas?-   Guest
My IT guru at the place I work found an AMAZINGLY SIMPLE SOLUTION.
Remove the paper, then remove and replace the toner cartridge. Now put
the paper back in, and you are ready to go. Our IT man rocks!
Hi everyone,
Would like to know whether the printer Samsung ML-4050n is reliable. Thank you for...
(More)
Hi everyone,
Would like to know whether the printer Samsung ML-4050n is reliable. Thank you for your help.
I make a lot of copies, but I also want one to make nice pictures. Will this one do it for me?
I...
(More)
I also need a fax that will work right and will turn off when I don't need it on. My Canon MP730 keeps causing this fax problem for me.
I have a P3150 Lexmark printer and I can't make it communicate with my computer. Why can't I make...
(More)
I have a P3150 Lexmark printer and I can't make it communicate with my computer. Why can't I make the printer work, I've already downloaded the driver and still it does not work. I have windows XP. Please help
i have refilled the ink cartidges, nothing is printing. i have a solid red and solid green...
(More)
i have refilled the ink cartidges, nothing is printing. i have a solid red and solid green light--it still indicates that the ink is empty on one color, it won't run a test sheet or nozzle check. help! i heard that these cartidges have a chip in them that has to be reset? is that true and how is that done if so? thanks!
