Question about Taco 265-1 / 563-2 Combination Analog 24 Hour Clock Timer/Temperature
Taco always indicating low speed in electrolux washer
  • igsamkim Apr 23, 2009
    tacho always indicating low speed
    what do you mean tacho ?
  • Ruth Baldwin
    Ruth Baldwin May 11, 2010
    Can I have a bit more info as to what you are referring to???
My Electrolux from load washer GLTR1670AS0 started making a load banging noise during the high speed rinse out
One or more of the washer drum shocks is broken and or the washer drum bearing is defective and has excessive play.
Jan 28, 2017 | Electrolux Washing Machines
Error 53 on electrolux front load model # EIFLW50LIWO
The E53 error code indicates low voltage to speed control board. Check the wiring between the main control board and the speed control board and if the wiring checks ok then replace the speed control board.
Jul 05, 2016 | Electrolux Washing Machines
I have an Electrolux Dishwasher that always starts on low rinse
Hello Friend, this is Z. Thank you for your post!
I see that your Electrolux dishwasher starts cycle on low rinse. This typically indicates your dishwasher has low rinse aid. The RINISING AGENT LOW light, typically located near the Rinse Only Pad, comes on at the end of cleaning cycle when the rinse agent reservoir is low. The light will remain on through 5 successive cycles or until the reservoir is filled. Also, using rinse aid will enhance dryer performance and reduces water sports and filming. Hope this helps!
Jun 04, 2014 | Electrolux Dishwashers
Electrolux washer displaying error code E5E
Communication problem. Check the wiring between the Main
Control Board and the Speed Control Board. Wiring bad, correct wiring problem. Wiring good, replace the Main Control Board. If the problem is not corrected, replace the Speed Control Board.
Dec 28, 2012 | Electrolux 134743500 Fridgidaire Washer...
Model fwt645rhso will agitate but won't drain out, on spin cycle washer spins one way, stops goes back the other way, but water will not drain out. Does not rapidly spin on final cycle. Any...
There's an auxiliary switch in the door lock.switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. The machine will NEVER advance to the spin cycle unless the auxiliary switch is activated as a safety feature to prevent the door from opening during a high-speed spin cycle that may result in physical injury. The drum tumbles back and forth while the machine control checks the auxiliary if activated but since it's not, the control will not command the motor speed control to spin the drum at high speed. These symptoms may indicate a faulty door lock/switch assembly and may need replacement. Click on the links below for the detailed troubleshooting instructions and replacement of the door lock/switch assembly.
Electrolux and Frigidaire Washers Door Lock/Switch Assembly Troubleshooting
Replacing the Door Lock/Switch Assembly on Electrolux and Frigidaire Washers
Jun 18, 2011 | Frigidaire GSTF1670A Front Load Washer
My electrolux 880 front loader won't spin anymore
One of two things ... door lock or a speed board... I have been a tech for 10 years and I can say 9 times out of 10 its the speed board ... Its the board down by the base of the washer
Mar 24, 2011 | Electrolux Washing Machines
What does the low light indicator mean
this symbol usually indicates that the radiator is low on coolant. on some cars a similar light means low washer fluid. so check both of them.
Feb 08, 2010 | 1994 Chevrolet Caprice Classic
I have a new electrolux front load washer. When
Mine only smell mildewy if I leave them in more than an hour before drying. My old top load washer did the same thing. I dont wash unless I can immediately switch to the dryer.
Nov 24, 2009 | Electrolux EW1000i Front Load Washer
To fast
if there is a taco on the end of the motor which detects speed it could be loose or broken of,(connections at motor plug for this could be broken also thus no feedback to motor module)the taco is 40mm dia by 10mm thick which takes its dc output from a magnet revolving on the motor,the motor control module have been known also to cause this fault-hope this helps
May 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washer lights are all flashing
Hi friend.....
It is an indication of an error code,,,,,,,did you see any error code on timer.........
thank u..........
May 03, 2009 | Electrolux EIFLW55HIW Front Load Washer...
Taco   265-1 / 563-2 Combination Analog 24 Hour Clock Timer/Temperature Logo
50 people viewed this question
Top Taco Hardware & Accessories Experts
deton8 von Splosion
Gene Haynes
Are you a Taco Hardware and Accessory Expert? Answer questions, earn points and help others
